Fax through mgcp and sip in CUCM 11.5 = SIP/2.0 415 Unsupported Media Type
Hello colleagues.
Please help me to solve my problem.
I have a scheme:
City --- E1--- Cisco 3925 --- MGCP --- CUCM --- SIP --- FAX Server
When I trying to send fax from City to Fax Server, I have a problem
Cisco 3925 MGCP config
mgcp
mgcp call-agent MirUsw-UCMSub01.domain.ru 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp codec g711alaw packetization-period 20
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 nsf 000000
mgcp rtp payload-type cisco-pcm-switch-over-alaw 127
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
Screenshots of config CUCM and logs in attachments
Jonathan Unger
Level 7
Level 7
Hi There,
Just curious if you ever got this issue solved.
If so, did it have anything to do with the packetization period of the G711a stream?
