From filezilla, I am trying to connect cisco Prime, it is not connected
I am trying to connect PCD via sftp [ filezilla ], username - adminsftp, password - OS admin password of the PCD
the connection getting timeout as attached.
In firewall action - allowed, application - incomplete, session end reason - aged-out, screenshot attached, Please advice.
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
If you're doing this remotely, does this work with a laptop/SFTP client in the same network as PCD, does this work??
Are you setting the right options in filezilla??
java
if this helps, please rate
In Laptop running the filezilla, filezilla and PCD are in the different subnet, from laptop I am able to ping the PCD.
In FileZilla, giving the host IP address of PCD
password - OSadmin password.
Could Please let me know do I missing any config in filezilla
And the ping only indicates you have ICMP working, not that filezilla should work, your screenshot also shows port 21, that's FTP, not SFTP.
java
Recognize Your Peers
