Fujitsu 9600 and CUCM user migration
davidfranek
acampbell
David,
Have a look on the CUCM page for your mgcp gateway.
Endpoint configuration
The ECMA settings are available
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/b06gtway.html#wp1661078" rel=nofollow mcehref="http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/b06gtway.html#wp1661078">http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/b06gtway.html#wp1661078
QSIG Variant
To display the options in the QSIG Variant drop-down list box, choose QSIG from the Tunneled Protocol drop-down list box.
This parameter specifies the protocol profile that is sent in outbound QSIG facility information elements.
From the drop-down list box, choose one of the following options. Keep this parameter set to the default value unless a Cisco support engineer instructs otherwise.
http://www.cisco.com/en/US/i/templates/blank.gif" width=19 height=2 mcesrc="http://www.cisco.com/en/US/i/templates/blank.gif">No Changes
http://www.cisco.com/en/US/i/templates/blank.gif" width=19 height=2 mcesrc="http://www.cisco.com/en/US/i/templates/blank.gif">Not Selected
http://www.cisco.com/en/US/i/templates/blank.gif" width=19 height=2 mcesrc="http://www.cisco.com/en/US/i/templates/blank.gif">ECMA—If the QSIG Variant is set to ECMA (Protocol Profile 0x91), ensure the ASN.1 Rose OID Encoding service parameter is set to Use Global Value (ECMA).
http://www.cisco.com/en/US/i/templates/blank.gif" width=19 height=2 mcesrc="http://www.cisco.com/en/US/i/templates/blank.gif">ISO—(Default) If the QSIG Variant is set to ISO (Protocol Profile 0x9F), ensure the ASN.1 Rose OID Encoding service parameter is set to either Use Local Value or Use Global Value (ISO).
For more information, see the following information:
http://www.cisco.com/en/US/i/templates/blank.gif" width=19 height=2 mcesrc="http://www.cisco.com/en/US/i/templates/blank.gif">Be aware that the QSIG Variant can also be defined as a clusterwide parameter. For more information, see http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/b02svprm.html#wpxref88354" rel=nofollow mcehref="http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/b02svprm.html#wpxref88354">Chapter 22 "Service Parameter Configuration."
http://www.cisco.com/en/US/i/templates/blank.gif" width=19 height=2 mcesrc="http://www.cisco.com/en/US/i/templates/blank.gif">For information on QSIG support with Cisco Unified Communications Manager, see http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmsys/a08procl.html#wpxref78395" rel=nofollow mcehref="http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmsys/a08procl.html#wpxref78395">"Q.Signaling (QSIG)" in the http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmsys/a08procl.html#wpxref33733" rel=nofollow mcehref="http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmsys/a08procl.html#wpxref33733">"Understanding IP Telephony Protocols"chapter of the Cisco Unified Communications Manager System Guide.
ASN.1 ROSE OID Encoding
To display the options in the ASN.1 ROSE OID Encoding drop-down list box, choose QSIG from the Tunneled Protocol drop-down list box.
This parameter specifies how to encode the Invoke Object ID (OID) for remote operations service element (ROSE) operations.
From the drop-down list box, choose one of the following options:
http://www.cisco.com/en/US/i/templates/blank.gif" width=19 height=2 mcesrc="http://www.cisco.com/en/US/i/templates/blank.gif">No Changes.
http://www.cisco.com/en/US/i/templates/blank.gif" width=19 height=2 mcesrc="http://www.cisco.com/en/US/i/templates/blank.gif">Use Global Value (ISO)—Select this option only if the connected PBX does not support Local Value.
http://www.cisco.com/en/US/i/templates/blank.gif" width=19 height=2 mcesrc="http://www.cisco.com/en/US/i/templates/blank.gif">Use Global Value (ECMA)—Select this option only if the QSIG Variant service parameter is set to ECMA (Protocol Profile 0x91).
http://www.cisco.com/en/US/i/templates/blank.gif" width=19 height=2 mcesrc="http://www.cisco.com/en/US/i/templates/blank.gif">Use Local Value—(Default) This option gets supported by most telephony systems and should be used when the QSIG Variant service parameter is set to ISO (Protocol Profile 0x9F).
http://www.cisco.com/en/US/i/templates/blank.gif" width=19 height=2 mcesrc="http://www.cisco.com/en/US/i/templates/blank.gif">Be aware that ASN.1 ROSE OID Encoding can also be defined as a clusterwide parameter. For more information, see http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/b02svprm.html#wpxref88354" rel=nofollow mcehref="http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/b02svprm.html#wpxref88354">Chapter 22 "Service Parameter Configuration."
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
David,
QSIG Variant
Alex.
