01-08-2012 06:54 AM - edited 03-16-2019 08:52 AM
we have cisco 2900 series H323 router with CUCM 7.1.5 in our office. Also we have 5 Analog CO Trunks which are terminated in FXO ports.
These 5 CO Trunks are used as backup incase the primary PRI failes. So that any ip phone can make/receive calls through this trunk. I have configured it. Can someone please check this and help how to configure properly. Im not receiving any calls through this FXO port.
Voice-port 0/1/0
trunk-group Lancaster
groundstart auto-tip
signal groundstart
input gain 12
connection plar opx immediate 7173977349
description 7173977349
caller-id enable
01-08-2012 10:49 PM
Hi Allwyn,
Per Paolo suggestion, I have moved your question from Small Business ATAs, Gateways, and Accessories into the IP telephony area.
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
01-09-2012 03:51 AM
May be a good idea to post your full config
For incoming calls from the PSTN you will need a voip dial peer
with a destination pattern that matches your PLAR number 7173977349
with the IP address of your CUCM.
This will also need to be a valid DN on your CUCM
Alex
