FXS Port Config (Fax)
spencermoore
We're deploying 50 IP phones and a new 2921 gateway with an FXS card. I have all the phones configured, but need to add three analog fax machines to the gateway. These machines will be directly attached to the 2921 via FXS card. How can I configure this in CUCM? Steps I've taken:
1. Gateway>Module(slot1)>selected FXS
2. Configured port as loop start, assigned device pool, CSS and set "attendant DN" to last four digits of DID number (Telco providing 4 significant digits).
3. Set DN to same as "attendant DN" and assigned partition
Is this all their is to it? Is any additional configuration required? Unfortunately, I can't test yet as we are still on old gear. Trying to confirm the correct config prior to the cutover.
Edit: This is an MGCP gateway.
Ryan Huff
Level 4
Level 4
Since you referenced gateway control on the port, I assume you are using MGCP (please do not use SCCP for faxing).
Typically, for MGCP, I use T.38 and these are the typical MGCP configs I use for T.38 on IOS with MGCP:
  • no ccm-manager fax protocol cisco
  • no mgcp fax t38 inhibit
  • mgcp package-capability fxr-package
  • mgcp default-package fxr-package
  • no mgcp fax t38 ecm
Ryan
(: ... Please rate helpful posts ... :)
Ryan Huff
Level 4
Level 4
Ryan
Thanks! I'll add these to the GW. Have I setup everything correctly in CUCM as referenced above?
While it shouldn't hurt anything, you don't have to use the attendant DN field (it may be auto-filled in though -I can't recall), the DN field itself is sufficient.
Also, I would POTS on the FXS port, not Loop Start.
Ryan
With loop start it is a required field. I'll try POTS. Thanks!
