Hello all
ccvp_cicso
have  problem   as  incoming  call  failed  this  my   Toplogy     i have   branch A  with  ((  one pbx  and  cisco router_gateway --------  connected  via  Wan  to branche B gateway  connected  to  pBX )
call  to  brance  B failed but  call  for   outgoing  success
all  my  debug  was  done in  Brance  B gateway  i think  problem  in it  so  please   help me
also  all debug  done  during  call to branche B
*Jun  5 08:18:50.377: ISDN  Q921d: isdn_from_driver_process: QUEUE_EVENT
*Jun  5 08:18:50.377: ISDN Se0/1/0:15 Q921r: Net RX <-
*Jun  5 08:18:50.377:     000101B1--000000B3
*Jun  5 08:18:50.377: ISDN Se0/1/0:15 Q921d: process_rxdata: Frame sent to L2
*Jun  5 08:18:50.377: ISDN Se0/1/0:15 PACKET: L2IF_SendPkt:
    source_id (0x200), state (0x0),
    dest_id (0x20A), event (0x141),
    sapi (0x0), ces (0x0), call_id (0x0),
    chan_id (0x0), int_id (0x22D756F8), free_pkt (0x1),
    pkt (0x225E983C), msecs (0x0), priority (0xA)
*Jun  5 08:18:50.377: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(E7BEDD8), size (4)
*Jun  5 08:18:50.377: ISDN Se0/1/0:15 PACKET: L2IF_SendPkt: Sending from L2
    dest_id = 0, source_id = 512, prim = 141
    priv_ln = 4, int_id = 584537848
  datastart = E7BEDC8, netstart = E7BEDD8, datasize = 20
*Jun  5 08:18:50.377: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(E7BEDC8), size (20)
*Jun  5 08:18:50.381:     22D756F800000200014104AE00000A00000101B1--000003FA
*Jun  5 08:18:50.381: ISDN  Q921d: isdn_from_driver_process: event_count 1
*Jun  5 08:18:50.381: ISDN  L2_CODE: isdn_l2_process: QUEUE_EVENT state = 0
*Jun  5 08:18:50.381: ISDN Se0/1/0:15 PACKET: handle_mail: received:
    priv_ln = 4, int_id = 584537848, datasize = 20
*Jun  5 08:18:50.381: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(E7BEDD8), size (20)
*Jun  5 08:18:50.381:     000101B13B9840003C0629C08101671081656FFE--0000063D
*Jun  5 08:18:50.381: ISDN Se0/1/0:15 PACKET: handle_mail: received data =
*Jun  5 08:18:50.381:     000101B1--000000B3
*Jun  5 08:18:50.381: ISDN Se0/1/0:15 L2_CODE: L2IF_GetDriverID()
*Jun  5 08:18:50.381: ISDN Se0/1/0:15 PACKET: L2IF_SendprimPkt:
    source_id (0x20A), state (0x7), dest_id (0x200), event (0x140),
    sapi (0x0), ces (0x1),  call_id (0x0),
    chan_id (0x0), int_id (0x22D756F8), free_p (0x1), pkt (0x3D9DF778), msecs (0x0), priority (0xA)
*Jun  5 08:18:50.381: ISDN Se0/1/0:15 PACKET: L2IF_SendPkt:
    pkt (0x216AC764), msecs (0x0), priority (0xA)
*Jun  5 08:18:50.381: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(D9E6958), size (4)
*Jun  5 08:18:50.381:     0001016D--0000006F
*Jun  5 08:18:50.381: ISDN Se0/1/0:15 PACKET: L2IF_SendPkt: Sending from L2
    dest_id = 0, source_id = 522, prim = 140
  datastart = D9E6948, netstart = D9E6958, datasize = 20
*Jun  5 08:18:50.381: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(D9E6948), size (20)
*Jun  5 08:18:50.381:     22D756F80000020A014004AE00010A000001016D--000003C0
*Jun  5 08:18:50.381: ISDN  L2_CODE: isdn_l2_process: TIMER_EVENT
*Jun  5 08:18:50.381: ISDN  Q921d: isdn_l2d_srq_process: QUEUE_EVENT
*Jun  5 08:18:50.381: ISDN Se0/1/0:15 PACKET: handle_l2d_srq_mail: received:
    dest_id = 0x0000, source_id = 0x020A, prim = 0x0140
    priv_ln = 4, int_id = 0x22D756F8, datasize = 4
    line_status[0] = IF_ACTIVE
*Jun  5 08:18:50.381: ISDN Se0/1/0:15 Q921r: Net TX ->
*Jun  5 08:18:50.381: ISDN  Q921d: isdn_l2d_srq_process: event_count 1
*Jun  5 08:18:50.381: ISDN  L2_CODE: isdn_l2_process: state (0x0), event_count (1)
*Jun  5 08:18:57.677: ISDN  CDAPI: cdapi_find_tsm found a GTD message IAM,
PRN,isdn*,,QSIG*,
USI,rate,c,s,c,1
USI,lay1,alaw
TMR,00
CPN,00,,1,98555
CGN,00,,1,y,4,166
CPC,09
FCI,,,,,,,y,
GCI,f509b4e7ccef11e28fed001cf6d623b8
    end of gtd length is 164
*Jun  5 08:18:57.677: //-1/F509B4E78FED/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=98555
*Jun  5 08:18:57.677: //-1/F509B4E78FED/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
*Jun  5 08:18:57.677: //-1/F509B4E78FED/DPM/dpMatchCore:
   Dial String=98555, Expanded String=98555, Calling Number=
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
*Jun  5 08:18:57.677: //-1/F509B4E78FED/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=15 Is Matched
*Jun  5 08:18:57.677: H245 FS OLC INCOMING ENCODE BUFFER::= 0000000E000101800B050001005765BA3242DF80
*Jun  5 08:18:57.677: H245 FS OLC INCOMING PDU ::=
value OpenLogicalChannel ::=
      forwardLogicalChannelNumber 1
      forwardLogicalChannelParameters
        dataType audioData : g729wAnnexB : 2
        multiplexParameters h2250LogicalChannelParameters :
          sessionID 1
          mediaControlChannel unicastAddress : iPAddress :
            network '5765BA32'H
            tsapIdentifier 17119
          silenceSuppression TRUE
*Jun  5 08:18:57.677: H245 FS OLC INCOMING ENCODE BUFFER::= 400000060401004E0001018012150001005765BA3242DE005765BA3242DF80
        dataType nullData : NULL
        multiplexParameters none : NULL
      reverseLogicalChannelParameters
          sessionID 1
          mediaChannel unicastAddress : iPAddress :
            network '5765BA32'H
            tsapIdentifier 17118
            network '5765BA32'H
*Jun  5 08:18:57.681: //-1/F509B4E78FED/DPM/dpAssociateIncomingPeerCore:
*Jun  5 08:18:57.681: //-1/F509B4E78FED/DPM/dpMatchPeertype:
*Jun  5 08:18:57.681: //-1/F509B4E78FED/DPM/dpMatchCore:
*Jun  5 08:18:57.681: //-1/F509B4E78FED/DPM/MatchNextPeer:
*Jun  5 08:19:00.305: ISDN  Q921d: isdn_from_driver_process: QUEUE_EVENT
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 Q921r: Net RX <-
*Jun  5 08:19:00.305:     000101B1--000000B3
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 Q921d: process_rxdata: Frame sent to L2
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 PACKET: L2IF_SendPkt:
    pkt (0x22725350), msecs (0x0), priority (0xA)
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(E7BEC58), size (4)
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 PACKET: L2IF_SendPkt: Sending from L2
  datastart = E7BEC48, netstart = E7BEC58, datasize = 20
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(E7BEC48), size (20)
*Jun  5 08:19:00.305:     22D756F800000200014104AE00000A00000101B1--000003FA
*Jun  5 08:19:00.305: ISDN  Q921d: isdn_from_driver_process: event_count 1
*Jun  5 08:19:00.305: ISDN  L2_CODE: isdn_l2_process: QUEUE_EVENT state = 0
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 PACKET: handle_mail: received:
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(E7BEC58), size (20)
*Jun  5 08:19:00.305:     000101B13BB340003C0629A88101671081656FFE--00000640
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 PACKET: handle_mail: received data =
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 L2_CODE: L2IF_GetDriverID()
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 PACKET: L2IF_SendprimPkt:
    pkt (0x3CDCDF90), msecs (0x0), priority (0xA)
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(E7BFCD8), size (4)
*Jun  5 08:19:00.305:     0001016D--0000006F
  datastart = E7BFCC8, netstart = E7BFCD8, datasize = 20
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(E7BFCC8), size (20)
*Jun  5 08:19:00.305:     22D756F80000020A014004AE00010A000001016D--000003C0
*Jun  5 08:19:00.305: ISDN  L2_CODE: isdn_l2_process: TIMER_EVENT
*Jun  5 08:19:00.305: ISDN  Q921d: isdn_l2d_srq_process: QUEUE_EVENT
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 PACKET: handle_l2d_srq_mail: received:
*Jun  5 08:19:00.305: ISDN Se0/1/0:15 Q921r: Net TX ->
*Jun  5 08:19:00.305: ISDN  Q921d: isdn_l2d_srq_process: event_count 1
*Jun  5 08:19:00.305: ISDN  L2_CODE: isdn_l2_process: state (0x0), event_count (1)
*Jun  5 08:19:10.233: ISDN  Q921d: isdn_from_driver_process: QUEUE_EVENT
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 Q921r: Net RX <-
*Jun  5 08:19:10.233:     000101B1--000000B3
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 Q921d: process_rxdata: Frame sent to L2
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 PACKET: L2IF_SendPkt:
    pkt (0x224B29D8), msecs (0x0), priority (0xA)
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(E7BF258), size (4)
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 PACKET: L2IF_SendPkt: Sending from L2
  datastart = E7BF248, netstart = E7BF258, datasize = 20
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(E7BF248), size (20)
*Jun  5 08:19:10.233:     22D756F800000200014104AE00000A00000101B1--000003FA
*Jun  5 08:19:10.233: ISDN  Q921d: isdn_from_driver_process: event_count 1
*Jun  5 08:19:10.233: ISDN  L2_CODE: isdn_l2_process: QUEUE_EVENT state = 0
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 PACKET: handle_mail: received:
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(E7BF258), size (20)
*Jun  5 08:19:10.233:     000101B13BBD40003C06299E8101671081656FFE--00000640
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 PACKET: handle_mail: received data =
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 L2_CODE: L2IF_GetDriverID()
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 PACKET: L2IF_SendprimPkt:
    pkt (0x3D0A8F04), msecs (0x0), priority (0xA)
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(E7BF9D8), size (4)
*Jun  5 08:19:10.233:     0001016D--0000006F
  datastart = E7BF9C8, netstart = E7BF9D8, datasize = 20
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 PACKET: L2IF_DispPak: packet - start(E7BF9C8), size (20)
*Jun  5 08:19:10.233:     22D756F80000020A014004AE00010A000001016D--000003C0
*Jun  5 08:19:10.233: ISDN  L2_CODE: isdn_l2_process: TIMER_EVENT
*Jun  5 08:19:10.233: ISDN  Q921d: isdn_l2d_srq_process: QUEUE_EVENT
Rout_RWH#
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 PACKET: handle_l2d_srq_mail: received:
*Jun  5 08:19:10.233: ISDN Se0/1/0:15 Q921r: Net TX ->
*Jun  5 08:19:10.233: ISDN  Q921d: isdn_l2d_srq_process: event_count 1
*Jun  5 08:19:10.233: ISDN  L2_CODE: isdn_l2_process: state (0x0), event_count (1)
Rout_RWH#show dialplan number 98414
Macro Exp.: 98414
VoiceEncapPeer1
    peer type = voice, system default peer = FALSE, information type = voice,
    description = `',
    tag = 1, destination-pattern = `^98...$',
    voice reg type = 0, corresponding tag = 0,
    allow watch = FALSE
    answer-address = `', preference=0,
    CLID Restriction = None
    CLID Network Number = `'
    CLID Second Number sent
    CLID Override RDNIS = disabled,
    rtp-ssrc mux = system
    source carrier-id = `',    target carrier-id = `',
    source trunk-group-label = `',    target trunk-group-label = `',
    numbering Type = `unknown'
    group = 1, Admin state is up, Operation state is up,
    Outbound state is up,
    incoming called-number = `', connections/maximum = 0/unlimited,
    DTMF Relay = disabled,
    URI classes:
        Destination =
    huntstop = disabled,
    in bound application associated: 'DEFAULT'
    out bound application associated: ''
    dnis-map =
    permission :both
    incoming COR list:maximum capability
    outgoing COR list:minimum requirement
    Translation profile (Incoming):
    Translation profile (Outgoing):
    incoming call blocking:
    translation-profile = `'
        disconnect-cause = `no-service'
        advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
        mailbox selection policy: none
        type = pots, prefix = `',
        forward-digits 3
        session-target = `', voice-port = `0/1/0:15',
        direct-inward-dial = enabled,
        digit_strip = enabled,
        register E.164 number with H323 GK and/or SIP Registrar = TRUE
        fax rate = system,   payload size =  20 bytes
        supported-language = ''
        preemption level = `routine'
        bandwidth:
            maximum = 64 KBits/sec, minimum = 64 KBits/sec
        voice class called-number:
            inbound = `', outbound = `'
        dial tone generation after remote onhook = enabled
        mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
        snr calling-number local=disabled, snr ring-stop=disabled, snr answer-too-soon timer=0
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 660, Charged Units = 0,
        Successful Calls = 0, Failed Calls = 0, Incomplete Calls = 0
        Accepted Calls = 1, Refused Calls = 0,
        Last Disconnect Cause is "10  ",
        Last Disconnect Text is "normal call clearing (16)",
        Last Setup Time = 73770867.
        Last Disconnect Time = 73774470.
Matched: 98414   Digits: 4   Matched pattern: ^98...$
Target:
my configuration
Rout_RWH#show running-config
Building configuration...
Current configuration : 7942 bytes
! Last configuration change at 09:08:51 UTC Wed Jun 5 2013
version 15.3
hostname Rout_RWH
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.153-2.T.bin
boot-end-marker
card type e1 0 1
enable password lan12CZ%33
no aaa new-model
network-clock-participate wic 1
ip cef
no ip domain lookup
ip domain name cisco.rwh.gmc.com.sa
no ipv6 cef
isdn switch-type primary-qsig
isdn logging
crypto pki trustpoint TP-self-signed-1126290077
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1126290077
revocation-check none
rsakeypair TP-self-signed-1126290077
crypto pki certificate chain TP-self-signed-1126290077
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31313236 32393030 3737301E 170D3132 30363239 31303137
  31305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 31323632
  39303037 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009F65 490BDA15 D9548AB0 EFC22B7B D965D68B CAB38B89 7352955B 637ABFAE
  BB438824 84654369 DB6EEFCF 9B978464 A3B3B6D9 3B9438A7 C20C8A25 A23E9AD1
  4A172E5B 0FA2ABA6 E60C9AEF 9E4FCEA0 54EAAE92 D90EC78E E0696519 C1A85C99
  B425F088 3FDF4023 B68677CD 5E41214E AA62B943 99929C80 287FF1E7 8D2939F6
  11B70203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14AAE7C7 4D92628E 07F17D48 4D07BEC8 42F459C4 26301D06
  03551D0E 04160414 AAE7C74D 92628E07 F17D484D 07BEC842 F459C426 300D0609
  2A864886 F70D0101 05050003 8181003E 94051F89 97BD89D8 50378EF5 DB9D8600
  D1624F9A 559AC1E7 B3806480 140C6478 606BEAAB EFC17234 A3BD99EE BB940EFA
  9B3A394D BA52DEA6 413E079B 6C87B194 94331057 8775EDD9 93FCEA2A 7EAAF4BD
  81520758 56F631BC DBF9BD92 A9416D5C BE8E9DE8 EAA62339 F00555FE 1E4E2E77
  D5E64D4C 346E3200 DA54077A 02E2E0
        quit
voice-card 0
codec complexity high
voice service voip
allow-connections sip to sip
no supplementary-service sip moved-temporarily
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
voice class h323 1
  h225 timeout tcp establish 3
voice translation-profile income
translate called 1
license udi pid CISCO2901/K9 sn FCZ1626C5PH
hw-module pvdm 0/0
username cisco privilege 15 password 0 cisco
redundancy
controller E1 0/1/0
clock source internal
pri-group timeslots 1-6,16
controller E1 0/1/1
ip ftp username anonymous
interface Loopback0
ip address 172.30.8.1 255.255.255.0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description ***JED 12-JED12-IP98***$ETH-WAN$
ip address 87.101.203.138 255.255.255.252
duplex full
speed 100
interface GigabitEthernet0/1
ip address 129.101.111.254 255.255.0.0
duplex full
speed 100
interface Serial0/1/0:15
bandwidth 128
no ip address
encapsulation hdlc
isdn overlap-receiving T302 1000
isdn protocol-emulate network
isdn incoming-voice voice
router bgp 64537
bgp log-neighbor-changes
neighbor 87.101.191.101 remote-as 35753
neighbor 87.101.191.101 version 4
neighbor 87.101.203.137 remote-as 35753
neighbor 87.101.203.137 version 4
address-family ipv4
  redistribute connected
  neighbor 87.101.191.101 activate
  neighbor 87.101.203.137 activate
exit-address-family
ip default-gateway 129.101.111.254
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 129.101.103.1
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit any
control-plane
voice-port 0/1/0:15
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 2 voip
description Jeddah LL
destination-pattern 82
session target ipv4:172.30.1.1
codec g729br8
dial-peer voice 3 voip
description Riyadh
destination-pattern 91
session target ipv4:172.30.2.1
codec g729br8
dial-peer voice 4 voip
description Riyadh LL
destination-pattern 81
codec g729br8
dial-peer voice 5 voip
description Zahran
destination-pattern 93
session target ipv4:172.30.3.1
codec g729br8
dial-peer voice 6 voip
description Zahran LL
destination-pattern 83
codec g729br8
dial-peer voice 7 voip
description JWH
destination-pattern 97
session target ipv4:172.30.7.1
codec g729br8
dial-peer voice 8 voip
description JWH LL
destination-pattern 87
codec g729br8
dial-peer voice 12 voip
description Jeddah
destination-pattern 92...
incoming called-number 98...
codec g729br8
dial-peer voice 9 pots
description Local Line
destination-pattern 88
port 0/1/0:15
forward-digits 7
dial-peer voice 11 pots
description Warehouse LL
direct-inward-dial
port 0/1/0:15
forward-digits 7
dial-peer voice 1 pots
description to_PBX
destination-pattern ^98...$
direct-inward-dial
port 0/1/0:15
forward-digits 3
gatekeeper
shutdown
credentials
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
password lan12CZ%33
login
line aux 0
password lan12CZ%33
login
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 0 0
privilege level 15
password lan12CZ%33
logging synchronous
login
transport input telnet ssh
line vty 5 15
exec-timeout 0 0
password lan12CZ%33
login
transport input all
scheduler allocate 20000 1000
end
dsobrinho
Level 9
Level 9
Have you tried use an [incaming called-number .T] in dial peer?
dial-peer voice 10 pots
description [PBX_incoming_dialpeer]
incoming called-number .T
direct-inward-dial
port 0/1/0:15
Other information when you use dial-peer by default strip digit are enable. Please verifiy if the digits are goint to using the command
(show isdn history and show voice call status)
>#show isdn history
output:
                                ISDN CALL HISTORY
Call History contains all active calls, and a maximum of 100 inactive calls.
Inactive call data will be retained for a maximum of 15 minutes.
Call    Calling      Called       Remote  Seconds Seconds Seconds Charges
Type    Number       Number       Name    Used    Left    Idle    Units/Currency
best regards
Daniel
Daniel Sobrinho
