Hookflash from IP phone to E1 cas trunk :- Is it possible ?
shahedvoicerite
I have the following setup
IP Phone (A). .....................IVR Script
2811-----E1 fxo/fxs loopstart--->2811
(ccme)
When I dial a call from my IP phone (A) over the E1 trunk, I get connected to a tcl script, which then connects me to an IP phone (B not shown above).
Now, I want to send a hookflash from my IP Phone (A).
The script on the other end is setup to detect hookflash events.
However, when I try to send a hookflash, the script on the other end, either sees no event, or sees a disconnect.
I have setup fxo hookflash under telephony services on the 2811 connected to IP Phone (A), and experimented with adjusting the hookflash timing on both ends.
Is it possible to send a hookflash in such a configuration ?
Hi, Thanks,
But I have all that setup.
I believe that the underlying platform, 2811 with VWIC-2MFT-E1 does not support hookflash detection on E1 CAS with FXS/FXO LOOPSTART signalling(it may on E&M wink-start)
I am just hoping someone can either confirm or deny this statement.
