03-01-2009 07:54 PM - edited 03-15-2019 04:32 PM
I'm using UCM 6.1. Whenever i press the directory button on the ip phone, it will display host not found.
What could be the cause of it?
Solved! Go to Solution.
03-01-2009 08:14 PM
In CM Administration-Go to Enterprise Parameters,change the URL paths with IP Address of Publisher instead of Hostname.Restart your Ip Phone and see.
03-01-2009 08:14 PM
03-01-2009 09:35 PM
thanks. that solved my problem. 1 more basic setup i like to ask you.
Currently my ip phone top right hand side shows the DN number instead of name
I tried many ways but can't able to change it. you have any clues? Thanks
03-02-2009 12:44 PM
Unfortunately you can't change that in CCM that's possible only in CM Express :)
03-03-2009 10:51 PM
You are welcome:
Try from CM Administration,Device-Phone and from the Line settings add the name in the Line Display field.
Have a nice day.
