Hi All,
I am currently using CUCM 9.1, and I am trying to change the controlled devices in Route group members from H.323 GW to MGCP GW in Route Groups.I have exported the Route Group config from Bulk Administration > Import/Export(Route Group>check dependancy). I have changed the H.323 GW (IP) to MGCP GW(AALN/S0/SU2/0@test.cisco.com) in Route group.csv file and uploaded the .tar file to cucm. I have also validated imported .tar file and the result is success.
But when I run import configuration(Import/Export > Import Config > Tick Route Group > override the existing config) for the .tar file it results as below error.
Query :
IMPORT ROUTEGROUP IN routegroup.csv
Failure Details :
routegroup Error Code Error Description
test_cisco_RG Missing key in referenced table for referential constraint (informix.fk_routegroupdevicemap_fkroutegroup).
Is there any way that i can bulk admin to do it instead to config it one by one.
Where could I begin troubleshooting? Appreciate any help.
Thank you,
Raghav
