04-22-2013 02:54 AM - edited 03-16-2019 04:55 PM
Hi ,
kindly let me know how to block incoming number on cisco phone.
i want to block a particuler number which is irritating me .
Is there any method via CUCM to block this number.
thanks in advance...
04-22-2013 02:57 AM
What gateway you are using.
In H.323 gateway you can use block pattern feature of voice translation rule.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
04-22-2013 03:00 AM
Hi Ronak,
Tnx for quick response .But we use MGCP gateway and two PRI links are connected on this gateway
04-22-2013 03:16 AM
What CUCM version are you running?
04-22-2013 03:33 AM
Hi Jaime,
CUCM version 8.6.
04-22-2013 03:20 AM
HI
See if below link helps you
https://supportforums.cisco.com/docs/DOC-19628
Ronak Patel
