how to lock volume button in IP Phone 3905
ferly0001
Hello , i have 3905 ip phone series. i already tried to disable Setting Access parameter in callmanager but  volume button in 3905 ip phone series still work. Is there any option to lock volume buttom in 3905 ip phone series ?
aateek singh
There is NO option to lock volume button in Cisco 3905 ,as volume button is User preference menu.
Maximum you can control whether a phone has access to the Settings menu or to options on this menu by using the Settings Access field in the Cisco Unified CM Administration Phone Configuration window. The Settings Access field accepts these values:
Enabled: Allows access to the Settings menu.
Disabled: Prevents access to the Settings menu.
Restricted: Allows access to the User Preferences menu and allows volume changes to be saved. Prevents access to other options on the Settings menu.
Aateek Singh
Network Engineer
Spooster IT Services
aateek singh
Aateek Singh
Network Engineer
Hi Aateek Singh
Thanks bro for your answer and explanation.
Regads,
Ferly
Welcome Ferly
Aateek Singh
Network Engineer
