inbound calls via sip do not go to voicemail, inside calls do
viking762x51
When receiving inbound calls via our sip trunk the calls will not roll over to voicemail, the call just gets dropped.
If we call the voicemail pilots internally, or call each other and dont answer the calls go to voicemail correctly.
researching this it appears to be something with the dspfarm and transcoding, but I am still very new to this and not sure how this should be configured.
Here is our config and our hardware. I have two pvdm modules installed. when running show dspfarm i get that its down, not sure how/where to noshut these, or if these are our problem.
dspfarm
DSPFARM Configuration Information:
Admin State: DOWN, Oper Status: DOWN - Cause code: ADMIN_STATE_DOWN
Transcoding Sessions: 0(Avail: 0), Conferencing Sessions: 0 (Avail: 0)
Trans sessions for mixed-mode conf: 0 (Avail: 0), RTP Timeout: 600
Connection check interval 600 Codec G729 VAD: ENABLED
router1#sh run
Building configuration...
Current configuration : 5430 bytes
! Last configuration change at 13:42:23 UTC Tue Sep 9 2014
! NVRAM config last updated at 13:35:37 UTC Tue Sep 9 2014
version 15.1
hostname router1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.1.100.1 10.1.100.50
ip dhcp excluded-address 10.1.1.1 10.1.1.49
ip dhcp pool Data
 network 10.1.1.0 255.255.255.0
 dns-server 10.1.1.20
 option 150 ip 10.1.1.1
 default-router 10.1.1.1
ip domain name legacy.local
ip name-server 8.8.8.8
no ipv6 cef
voice service voip
 ip address trusted list
  ipv4 214.115.69.0 255.255.255.0
  ipv4 70.167.153.130 255.255.255.255
  ipv4 24.240.233.212 255.255.255.255
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service h450.3
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
  h225 h245-address on-connect
voice class codec 1
 codec preference 1 g729r8
 codec preference 2 g711ulaw
 codec preference 3 g711alaw
voice translation-rule 1
 rule 1 /^9/ //
voice translation-rule 2
 rule 1 /19729965165/ /102/
voice translation-profile inboundprofile
 translate called 2
voice-card 0
license udi pid CISCO2821 sn xx
redundancy
interface GigabitEthernet0/0
 ip address 10.1.1.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 duplex full
 speed 100
interface GigabitEthernet0/1
 ip address 71.170.37.123 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
 h323-gateway voip bind srcaddr 71.170.37.123
interface Service-Engine1/0
 ip unnumbered GigabitEthernet0/0
 service-module ip address 10.1.1.2 255.255.255.0
 service-module ip default-gateway 10.1.1.1
ip default-gateway 71.170.37.1
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/GUI
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source list 2 interface GigabitEthernet0/1 overload
ip nat inside source list 3 interface GigabitEthernet0/1 overload
ip nat inside source static tcp 10.1.1.22 25 71.170.37.123 25 extendable
ip nat inside source static tcp 10.1.1.22 443 71.170.37.123 443 extendable
ip nat inside source static tcp 10.1.1.20 1723 71.170.37.123 1723 extendable
ip route 0.0.0.0 0.0.0.0 71.170.37.1
ip route 10.1.1.2 255.255.255.255 Service-Engine1/0
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 2 permit 10.1.100.0 0.0.0.255
access-list 3 permit 10.1.200.0 0.0.0.255
tftp-server flash:/IP_Phones/7940_7960/Sccp/P0030801SR02.bin
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp profile default
dial-peer voice 2 voip
 destination-pattern 1[2-9].........
 translate-outgoing called 1
 session protocol sipv2
 session target dns:sip.flowroute.com
 voice-class codec 1
 dtmf-relay rtp-nte digit-drop
 dtmf-interworking standard
dial-peer voice 3 voip
 destination-pattern 2...
 session target ipv4:10.1.1.2
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 4 voip
 translation-profile incoming inboundprofile
 session target sip-server
 incoming called-number .%
sip-ua
 authentication username xx password 7 xx realm sip.flowroute.com
 calling-info pstn-to-sip from number set 19729965165
 no remote-party-id
 registrar dns:sip.flowroute.com expires 3600
telephony-service
 video
  maximum bit-rate 256
 max-ephones 58
 max-dn 192
 ip source-address 10.1.1.1 port 2000
 ip qos dscp af31 signal
 service phone videoCapability 1
 system message Legacy Vinyl Windows
 cnf-file perphone
 load 7960-7940 P0030801SR02
 time-zone 8
 voicemail 2000
 max-conferences 8 gain -6
 dn-webedit
 time-webedit
 transfer-system full-consult
 secondary-dialtone 9
 create cnf-files version-stamp 7960 Sep 03 2014 19:37:20
ephone-dn  1  dual-line
 number 110
 description Heath 110
 name Heath
 call-forward busy 2000
 call-forward noan 2000 timeout 10
ephone-dn  2  dual-line
 number 102
 description David
 name David
ephone-dn  98
 number 8001....
 mwi off
ephone-dn  99
 number 8000....
 mwi on
ephone  1
 device-security-mode none
 mac-address 9048.9A8C.25A5
 type CIPC
 button  1:1
ephone  2
 mac-address 0011.920E.11B7
 type 7940
 button  1:1
ephone  3
 mac-address 000E.D7D8.785C
 type 7940
 button  1:2
line con 0
line aux 0
line 66
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
ntp master
ntp update-calendar
ntp server pool.ntp.org
ntp server 0.us.pool.ntp.org
ntp server 2.us.pool.ntp.org
end
router1#
router1#sh diag
Slot 0:
        C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time 5d00h ago
        Onboard VPN             : v2.3.3
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC10314QF6
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-26921-02
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 03
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20060812
        Chassis Serial Number    : FTX1034A125
        Chassis MAC Address      : 0018.ba48.90a0
        MAC Address block size   : 32
        CLEI Code                : COM3D00BRA
        Product (FRU) Number     : CISCO2821
        Part Number              : 73-8853-04
        Version Identifier       : V03
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 30 33 31 34 51 46 36 40
          0x10: 03 E8 41 01 00 C0 46 03 20 00 69 29 02 42 41 30
          0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
          0x30: 09 87 83 01 32 1A 8C C2 8B 46 54 58 31 30 33 34
          0x40: 41 31 32 35 C3 06 00 18 BA 48 90 A0 43 00 20 C6
          0x50: 8A 43 4F 4D 33 44 30 30 42 52 41 CB 8F 43 49 53
          0x60: 43 4F 32 38 32 31 20 20 20 20 20 20 82 49 22 95
          0x70: 04 89 56 30 33 20 D9 02 40 C1 FF FF FF FF FF FF
        PVDM Slot 0:
        16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Hardware Revision        : 4.0
        Part Number              : 73-8538-05
        Board Revision           : B0
        Fab Version              : 04
        PCB Serial Number        : FOC12121LQ5
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-16
        Version Identifier       : V01
          0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 42 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 32 31 32
          0x20: 31 4C 51 35 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 31 36 89 56 30 31 20 D9 02
          0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 1:
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC1431212Y
        RMA History              : 00
        Processor type           : 00
          0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 43 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 34 33 31
          0x20: 32 31 32 59 03 00 81 00 00 00 00 04 00 09 00 CB
        WIC Slot 0:
        2nd generation - FXO Voice daughter card (4 port)
        Hardware Revision        : 5.0
        Top Assy. Part Number    : 800-21589-02
        Board Revision           : A0
        Deviation Number         : 0-0
        Fab Version              : 04
        PCB Serial Number        : FOC10333XN8
        RMA History              : 00
        Product (FRU) Number     : VIC2-4FXO
        CLEI Code                : CNUIAPRAAA
          0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 02
          0x10: 42 41 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 30 33 33 33 58 4E 38 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 31 20
          0x40: C6 8A 43 4E 55 49 41 50 52 41 41 41 FF FF FF FF
        WIC Slot 1:
        FXS Voice daughter card (4 port)
        Part Number              : 73-6918-01
        Board Revision           : 03
        Fab Version              : 01
        PCB Serial Number        : QuadDID-FXS
        RMA History              : 00
        Top Assy. Part Number    : 800-17016-01
        Connector Type           : 01
        Product (FRU) Number     : VIC-4FXS/DID=
          0x00: 04 FF 40 00 3A 41 01 00 82 49 1B 06 01 42 30 33
          0x10: 80 00 00 00 00 02 01 C1 8B 51 75 61 64 44 49 44
          0x20: 2D 46 58 53 03 00 81 00 00 00 00 04 00 C0 46 03
          0x30: 20 00 42 78 01 05 01 FF FF FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 1:
        Service Engine Port adapter, 1 port
        Top Assy. Part Number    : 800-21693-07
        Board Revision           : AO
        Deviation Number         : 93822
        Fab Version              : 02
        PCB Serial Number        : FOC115240BM
        RMA History              : 00
        Fab Part Number          : 28-5683-02
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        Field Diagnostics Data   : 00 00 00 00 00 00 00 00
        Product (FRU) Number     : NM-CUE
          0x00: 04 FF 40 03 AA 41 01 00 C0 46 03 20 00 54 BD 07
          0x10: 42 41 4F 88 00 01 6E 7E 02 02 C1 8B 46 4F 43 31
          0x20: 31 35 32 34 30 42 4D 03 00 81 00 00 00 00 04 00
          0x30: 85 1C 16 33 02 C4 08 00 00 00 00 00 00 00 00 C5
          0x40: 08 00 00 00 00 00 00 00 00 89 56 30 33 00 CB 86
          0x50: 4E 4D 2D 43 55 45 FF FF FF FF FF FF FF FF FF FF
        40GB IDE Disc Daughter Card
        Top Assy. Part Number    : 800-27583-02
        Board Revision           : A0
        Fab Version              : 01
        PCB Serial Number        : FOC11500M7G
        RMA History              : 00
        Fab Part Number          : 28-5685-01
          0x00: 04 FF 40 03 D8 41 01 00 C0 46 03 20 00 6B BF 02
          0x10: 42 41 30 80 00 00 00 00 02 01 C1 8B 46 4F 43 31
          0x20: 31 35 30 30 4D 37 47 03 00 81 00 00 00 00 04 00
          0x30: 85 1C 16 35 01 C4 08 00 00 00 00 00 00 00 00 C5
          0x40: 08 00 00 00 00 00 00 00 00 88 00 00 00 00 FF FF
router1#
15 Replies 15
I dont have any ACLs between the router and the service engine.
My routers ACL is listed above, are there any changes you suggest?
The router has 512mb of ram
