Installing ES to CUCM 6.1(4a)
David Wolgast
TAC advised me to install an ES and sent me the download. I staged it on my SFTP server, along with some phone loads to update in advance.
What I note is that, while the phone loads show up as valid upgrades on all my servers (all running TFTP), the ES only shows up on my 2 publishers. Is this correct? Does the ES only get applied to the publisher?
There doesn't appear to be much in the way of installation instructions for the ES, so I wanted to make sure before I install.
Thanks much!!!
rkamatch
hi,
ES needs to be installed in all nodes in the CUCM cluster.
ES is suppose to be show up in all server for the upgrade. PUB needs to upgrade first followed by SUB's.
Try investigate the following :
1. SFTP Sever (Try restart SFTP Service)
2. investigate the connectivity from CUCM Server side.
3. check ES file extension.
RR
rkamatch
hi,
RR
MARTIN STREULE
Small question: what issue did/do you need to have fixed?
CSCta10219...Unicast Music on Hold fails after a short time.  Going to 6.1.4.2217-3 appears to have fixed the issue.
Thanks - hey that was FAST!!!
I had another problem with this release (and Unity Connection integration):
In the admin web pages the details for users with VoiceMail were not visible anymore (empty web page).
Was just wondering if you had the same issue...
