Integrating CUCM and CUC on be6000
kgilkes92
When integrating cucm and cuc on a be6000 is a sip or sccp protocol required althought they both reside on the same UCS server?
Rajan
You could use either sccp or sip. But for current versions, SIP is the most used with simple configuration:
Please refer the below links for integration procedures:
https://supportforums.cisco.com/t5/collaboration-voice-and-video/how-to-configure-cucm-cuc-sip-integration/ba-p/3102384
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/integration/guide/cucm_sip/cucintcucmsip.html
Rajan
Pls rate all useful posts by clicking the stars below
