04-27-2011 07:41 PM - edited 03-16-2019 04:42 AM
Can I integrate CUPC client with users devices if I don´t have CUPS? I have CUCMBE 5000 with CUWL licensing and CUCM 8.5.1 with Unity Connections coresident in the server.
Solved! Go to Solution.
04-28-2011 06:43 AM
No, you cannot:
The following servers are required for Cisco Unified Personal Communicator operation:
•Cisco Unified Communications Manager is installed in your network and configured to handle call processing and point to point video. It provides Cisco Unified IP Phone control through the Cisco Unified Communications Manager computer telephony interface (CTI). It is not required to enable IP telephony for Cisco Unified Personal Communicator users, but those users will not have telephony capabilities. For Cisco Unified Communications Manager details, see the following URL:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/tsd_products_support_series_home.html
•Cisco Unified Presence is installed and is operational. This server provides the Cisco Unified Personal Communicator client configuration and presence information. For Cisco Unified Presence details, see the following URL:
http://www.cisco.com/en/US/products/ps6837/tsd_products_support_series_home.html
•LDAP/Active Directory server
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cupc/8_5/english/release/notes/cupc85.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
04-28-2011 06:43 AM
No, you cannot:
java
04-28-2011 09:12 PM
Thanks for your answer. Just one more question. If I have CUCM 8.5.1 with CUC coresident in the server (MCS7828, CUCMBE 5000), can I install CUPS software on the same server? Or I require one aditional server?
04-29-2011 05:49 AM
You would need an addition server.
