IP COMMUNICATOR DOES NOT REGISTER WHEN I'M ON VPN REMOTO ACCESS L2L
ernesto.sabi
good night dear
I'm having a problem, in my infrastructure, I'm using a CME on the Cisco 2811 Router, and on this Router I have also configured an L2L VPN with IPSEC, that is, this Router is a VPN Concentrator, it's also the CME. When I am inside my infrastructure, the IPCommunicator registers in seconds, when I am out of my infrastructure, I connect to the VPN, after connecting to the VPN, I can reach all the networks within my Infrastructure, but the IPcommunicator does not register, I usually ping to the TFTP Server, but unfortunately still the IPcommunicator does not register.
Can someone help me find the cause of the problem?
The version I am using in IPcommunicator is 7.0
The configuration I send below, for a brief analysis, and who knows quickly to find the problem.
Version 12.4(20)T4
crypto isakmp client configuration group SUKULIDER_VPN
key sukulider123
dns 10.0.1.1
pool vpnpool
acl 108
netmask 255.255.255.0
crypto ipsec security-association idle-time 1024
crypto ipsec transform-set myset esp-aes esp-md5-hmac
mode transport
crypto dynamic-map dynmap 10
set transform-set myset
reverse-route
crypto map clientmap client authentication list auth_vpn
crypto map clientmap isakmp authorization list groupvpn
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface FastEthernet0/0
description ### INTERFACE_REDE_INTERNA ###
no ip address
duplex auto
speed auto
interface FastEthernet0/0.2
description REDE_LAN_SUKULIDER
encapsulation dot1Q 2 native
ip address 10.0.1.1 255.0.0.0
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0.3
description REDE_VOZ
encapsulation dot1Q 3
ip address 192.168.30.254 255.255.255.0
ip nat inside
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.30.254
interface FastEthernet0/1
description ### INTERFACE WAN ###
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
ip local pool vpnpool 192.168.28.10 192.168.28.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 154.66.107.254
no ip http server
no ip http secure-server
no ip nat service sip udp port 5060
ip nat pool INTERNET 154.66.107.139 154.66.107.139 netmask 255.255.255.0
ip nat inside source list 111 interface FastEthernet0/1 overload
ip nat inside source static tcp 10.0.1.91 8081 154.66.107.139 8081 extendable
ip nat inside source static tcp 10.0.1.91 53 196.202.252.61 53 extendable
ip nat inside source static tcp 10.0.1.91 53 196.202.252.62 53 extendable
ip nat inside source static tcp 10.0.1.91 8081 196.202.254.67 8081 extendable
access-list 108 permit ip 10.0.1.0 0.0.0.255 192.168.28.0 0.0.0.255
access-list 108 permit ip 192.168.30.0 0.0.0.255 192.168.28.0 0.0.0.255
access-list 111 deny ip 10.0.1.0 0.0.0.255 192.168.28.0 0.0.0.255
access-list 111 permit ip any any
control-plane
voice-port 0/1/0
connection plar opx immediate 100
impedance complex1
description ### 222333421 ###
caller-id enable
voice-port 0/1/1
impedance complex1
description ### 222396179 ###
caller-id enable
voice-port 0/1/2
impedance complex1
caller-id enable
voice-port 0/1/3
impedance complex1
caller-id enable
dial-peer cor custom
name local
name DDD
name DDI
name internal
name internacional
name celular
dial-peer cor list AO-DDD
member DDD
dial-peer cor list AO-DDI
member DDI
dial-peer cor list CSS-local
member local
dial-peer cor list CSS-DDD
member local
member DDD
dial-peer cor list CSS-DDI
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-internacional
member internacional
dial-peer cor list call-celular
member celular
dial-peer cor list user-internal
member internal
dial-peer cor list user-local
member local
member internal
member celular
dial-peer cor list user-internacional
member local
member internal
member celular
dial-peer voice 1 pots
corlist outgoing call-internacional
description #### LIGACOES LOCAIS, CELULARES e INTERNACIONAL ####
preference 10
destination-pattern [2-9]........
incoming called-number T
direct-inward-dial
port 0/1/0
forward-digits all
dial-peer voice 2 pots
preference 5
direct-inward-dial
port 0/1/1
forward-digits all
sip-ua
sip-server ipv4:192.168.30.254
telephony-service
no auto-reg-ephone
max-ephones 42
max-dn 50
ip source-address 192.168.30.254 port 2000
timeouts interdigit 5
system message SUKULIDER
time-zone 21
time-format 24
date-format dd-mm-yy
keepalive 10
max-conferences 8 gain -6
web admin system name Admin secret 5 $1$YI8K$NDbuuDB4k59TQ4KXfATV50
time-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
call-waiting ring
number 100
description SECRETARIA
name SECRETARIA
corlist incoming user-internacional
ephone-dn 2
call-waiting ring
number 101
description PCA
name PCA - V.BAPTISTA
ephone-dn 3
call-waiting ring
number 103
description BALCAO
name BALCAO
corlist incoming user-internal
ephone-dn 4
call-waiting ring
number 104
description CASA FORTE
name CASA FORTE
ephone-dn 5
number 108
description JACINTO_INFORMATICA
name JACINTO_INFORMATICA
ephone-dn 6
number 106
description OPERATIVOS
name OPERATIVOS
ephone-dn 7
number 107
description Ana Silva
name Ana Silva
ephone-dn 8
number 108
description Lelia Silva
name Lelia Silva
ephone-dn 9
number 109
description Paloma Semedo
name Paloma Semedo
ephone-dn 10
number 120
description Admin
name Paloma Admin
ephone-dn 11
number 122
description Administrador
name Paloma Administrador
ephone 1
device-security-mode none
description description SECRETARIA
mac-address 001D.70FC.ED6A
type 7945
auto-line 2 answer-incoming
button 1:1
pin 4321
ephone 2
description PCA
mac-address 001D.70FC.ED32
type 7945
button 1:2
ephone 3
description BALCAO
mac-address B862.1F6C.A390
type 7945
button 1:3
ephone 4
mac-address 0024.C4BC.BE10
type 7941
auto-line incoming
button 1:4
pin 4321
ephone 5
description description JACINTO_INFORMATICA
mac-address F0DE.F157.3363
type CIPC
button 1:5
ephone 6
description description OPERATIVO
mac-address C471.FED7.51DD
max-calls-per-button 2
type 7921
button 1:6
ephone 7
mac-address 8852.FB45.C6C2
type CIPC
button 1:7
ephone 8
mac-address 40E2.300D.000F
type CIPC
button 1:7
ephone 9
mac-address FCAA.141C.1B29
type CIPC
button 1:9
ephone 10
description Admin
mac-address 5CC5.D42E.6837
type CIPC
ephone 11
mac-address D0E1.4090.440C
type CIPC
button 1:11
line con 0
line aux 0
line vty 0 4
password suk2016!!!
login local
scheduler allocate 20000 1000
end
RT-INTERNET-SUKULIDER#
Jaime Valencia
If you wish to use Portuguese, you should use the community dedicated to that language, click the Language option in the grey bar at the top of the page to reach it.
java
if this helps, please rate
Jaime Valencia
java
