IP Communicator Initialization
Pedro Francezi
Level 3
Level 3
I'm implementing an environment where some users will work with IP COMMUNICATOR, but we
are facing some problems.
The installation occurs normally, but when we try to initialize, it do not finishes the
process.
I've try to uninstall and install it again, but the result is the same.
How should I solve this issue?
Thanks and regards.
Chris Deren
So, the IPC never come up? What are you seeing?
What version did you install, what is the version of CUCM, what is the OS version of the PC you are running the IPC on? Did you install it with admin privileges? Did you set the TFTP address?
Chris
Yeah, it never finishes the initialization.
I do have a printscreen of the IPC.
IPC Version: 8.6
Installed as Admin
OS: Windows 7
The TFTP was not set, because the IPC has not started.
I can send the Print on a e-mail, if you want to see it, let me know.
