02-09-2009 01:09 PM - edited 03-15-2019 04:05 PM
What would cause this to appear on the IP Communicator phone on the PC.
Registration Rejected: Error DBConfig
Solved! Go to Solution.
02-10-2009 08:26 AM
Phone is still not working is there something more I need to do?
02-10-2009 08:24 AM
I made the change and reset the phone. I do not see that it has fixed the problem.
Does it take a while for it to make the change, os is there anything else I need to do?
02-10-2009 08:26 AM
close out of the CIPC and reopen it. It should register at this point.
02-10-2009 08:32 AM
Putting in the SEP in front of the MAC fixed it thank you very very much!
02-10-2009 08:33 AM
Glad all is well and takes for the nice rating. Have a good day..
02-10-2009 07:57 AM
When I go to the link below it says forbidden file and will not show it to me
02-10-2009 07:43 AM
I am still getting the Registration Rejected: Error DB Config
02-10-2009 07:53 AM
My 2 cents...
Are you using auto-registration for IPC?
Incase if the phone is not added to the CCM phone table, please add the phone to the CCM or check if you have enabled autoregistration.
Tx,
bala.
02-10-2009 07:58 AM
How do you check to see auto registration is enabled
02-11-2009 01:48 AM
To check if auto-registration is enabled, login to CCM admin page and go to System->Cisco Unified Call manager.
Click on the list of the CCMs displayed to check if auto-registration is enabled for the CCMs.
