IP communicator
Muralidharan.p
HI Everyone,
Is that possible to install 2 or more Cisco IP commnunicator in a computer? or its any different software is there? Im planning to bulid a small LAB with VMware. Please advice.
7 Replies 7
Ehab_Salem
unfortunately you cannot run multiple instances of CIPC on one machine, but you can do it with IP Blue.
Yes i tried that.. but all the IP blue phones are registering in same IP in the CUCM, im not able to make calls between the phones. Even i tried to change the MAC of the phones but still the phones are registering in the same IP.
Hi Imran,
I guess the document on the about link has deleted. Please upload the docement again if you have. Thanks in advance.
Murali
Hi Murali,
Here is the working link. Let me know if you need any further assistance on this. "Let me tell you that it works really great".
https://supportforums.cisco.com/community/netpro/collaboration-voice-video/others/blog/2012/11/30/run-multiple-cipcs-on-just-one-single-pc
Imran Ahmad
Cisco Systems
Also let me know how it works on you end......
Sure, I will let you konow and thanks a lot for the link.
Murali
