I need to know if it is possible as below:-
Current Infrastructure :-
I'm having 2no.s 2801 router, where I will terminate 2 X 2MBS PRI ( 1 Pri in each router ) for voice traffic ( Local & Long Distance Telephone ) point to same ISP ( both PRI ). These 2 PRI will be used for Voice network.
I nned to introduce a Video Conference equipment from Tandberg or any other vendor, and the equpment will be connected via LAN ( No PRI will be terminated in the video eqipment )
Is it possible that, I can configure 1 of the existing PRI lines ( Terminated in the 2 routers ) in such way that, Video Conference will use the link and that point of that particualr PRI link ( 2 MBPS ) will be used for only VC, and the remaing 2MBPS link will be used for Voice Network. After finishing the VC, the entire 2 x 2 MBPS link will be again used for Voice Network.
I'm confused by the customer need, as they don't want to procure extra link for Video...please help me.
