Jabber for Mac - Phone only Mode
Richard Venn
Afternoon,
I have often had to roll out J4W in phone only mode, but I have a customer whishing to use J4W and Jabber for Mac both in phone only mode.
I'm use to using the switch for installing J4W, but can't find anything that shows how to install J4M in phone only mode.  I don't have access to a Mac to try or have I ever used one to see the difference.
Can anybody provide any details on how to run J4M this way?
Many thanks in advance
Richard
Jaime Valencia
You've never had to do that (installation switches), Jabber can switch between full UC, IM only or phone only mode, based on the CUCM/IM&P configuration it receives.
If you want phone only, then you don't configure the IM&P portion in CUCM (assuming IM&P is present)
java
if this helps, please rate
Jaime Valencia
java
Jamie,
Many thanks for the response and confirmation!
Richard
