low frequency tones back to sender when leaving voicemail
TYLER WEST
I have a customer with a distributed CME and CUE setup across 3 sites.  Two locations have 2901s and the third has an 1860.  All voice functions to all sites work fine with one exception.  When placing a call from the site with the 1860 to the other sites and it rolls to voicemail on the remote CUE at the other sites, we get intermittent low frequency tones back in the direction of the calling party after the attendant stops speaking.  See the attached video.  We have not been able to find anything weird about the config and debugs don't seem to show anything.  A packet capture doesn't indicate any problems with the stream and it appears as though the tones have actually become part of the stream.  We have not been able to determine if the source is CUE itself or maybe transcoding or what.  All I am looking for is to see if anyone has experienced anything similar to what is shown in the video and what the source of the problem was.
We are a Cisco partner but are without our voice engineer and haven't been able to replace him yet.  So any guidance or direction you can give us would be much appreciated.
Tyler West
5 Replies 5
islam.kamal
Level 10
Level 10
can you share the configuration .Please make sure about CUE voice mail configuration :-
dial-peer voice 10 VOIP
destination-pattern xxxx ( number of voice mail).
session protocol sipv2
session targert IPV4:x.x.x.x    ( ip of cue).
dtmf-relay sip-notify
codec g711
no vad
Thank you.  I can share sections of the configuration.  Note that the 3rd site has no issue with leaving voicemails at this site.  Only the site with the 1860 has trouble leaving voicemails at the other site.  This config excerpt is from the 2901 with the CUE that is being called.
voice-card 0
dsp services dspfarm
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0.20
  bind media source-interface GigabitEthernet0/0.20
voice translation-rule 1
rule 1 /^\(239\)\(....\)/ /\2/
voice translation-rule 2
rule 1 /^\(....\)/ /615284\1/
voice translation-profile CLIDOUT
translate calling 2
voice translation-profile DIDIN
translate called 1
hw-module ism 0
hw-module pvdm 0/0
interface ISM0/0
description CFS-Nash-Voicemail
ip unnumbered GigabitEthernet0/0.20
service-module ip address 192.168.20.2 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 192.168.20.1
sccp local GigabitEthernet0/0.20
sccp ccm 192.168.20.1 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register CMECONF
dspfarm profile 1 conference
codec g711ulaw
maximum sessions 2
associate application SCCP
dial-peer voice 1 pots
translation-profile incoming DIDIN
incoming called-number .
direct-inward-dial
dial-peer voice 10 pots
destination-pattern 9911
port 0/0/0:23
forward-digits 4
dial-peer voice 11 pots
destination-pattern 9[2-9]......
port 0/0/0:23
forward-digits 8
dial-peer voice 12 pots
destination-pattern 91[2-9].........
port 0/0/0:23
forward-digits 12
dial-peer voice 8000 voip
description Voice mail dial-peer
destination-pattern 8000
session target ipv4:192.168.20.2
codec g711ulaw
no vad
dial-peer voice 8001 voip
description AA dial-peer
destination-pattern 8001
codec g711ulaw
no vad
dial-peer voice 8002 voip
description TUI dial-peer
destination-pattern 8002
codec g711ulaw
no vad
dial-peer voice 3901 pots
destination-pattern 3901
port 0/2/1
dial-peer voice 9000 voip
destination-pattern 5720
session target ipv4:192.168.51.1
codec g711ulaw
no vad
dial-peer voice 9001 voip
destination-pattern 5721
codec g711ulaw
no vad
dial-peer voice 13 pots
destination-pattern [1-8]...
port 0/0/0:23
forward-digits 4
dial-peer voice 9002 voip
destination-pattern 5722
codec g711ulaw
no vad
dial-peer voice 9003 voip
destination-pattern 5723
codec g711ulaw
no vad
dial-peer voice 14 pots
destination-pattern 0
port 0/0/0:23
forward-digits all
dial-peer voice 9004 voip
destination-pattern 6220
session target ipv4:192.168.61.1
codec g711ulaw
no vad
dial-peer voice 9005 voip
destination-pattern 6221
codec g711ulaw
no vad
dial-peer voice 9006 voip
destination-pattern 6223
codec g711ulaw
no vad
dial-peer voice 9007 voip
destination-pattern 6222
codec g711ulaw
no vad
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 4
sdspfarm tag 1 CMECONF
conference hardware
max-ephones 25
max-dn 50
ip source-address 192.168.20.1 port 2000
url services http://192.168.20.2/voiceview/common/login.do
url authentication http://192.168.20.1/CCMCIP/authenticate.asp
cnf-file perphone
load 7916-24 B016-1-0-3.SBN
load 7945 SCCP45.9-1-1SR1S
load 7965 SCCP45.9-1-1SR1S
time-zone 8
voicemail 8000
max-conferences 2 gain -6
moh music-on-hold.au
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
trunk optimization pre-connect
secondary-dialtone 9
after-hours block pattern 1 91900 7-24
after-hours block pattern 2 9011 7-24
after-hours block pattern 3 91242 7-24
after-hours block pattern 4 91264 7-24
after-hours block pattern 5 91268 7-24
after-hours block pattern 6 91284 7-24
after-hours block pattern 7 91340 7-24
after-hours block pattern 8 91345 7-24
after-hours block pattern 9 91441 7-24
after-hours block pattern 10 91473 7-24
after-hours block pattern 11 91649 7-24
after-hours block pattern 12 91664 7-24
after-hours block pattern 13 91721 7-24
after-hours block pattern 14 91758 7-24
after-hours block pattern 15 91767 7-24
after-hours block pattern 16 91784 7-24
after-hours block pattern 17 91787 7-24
after-hours block pattern 18 91809 7-24
after-hours block pattern 19 91829 7-24
after-hours block pattern 20 91849 7-24
after-hours block pattern 21 91868 7-24
after-hours block pattern 22 91869 7-24
after-hours block pattern 23 91876 7-24
after-hours block pattern 24 91939 7-24
create cnf-files version-stamp Jan 01 2002 00:00:00
The last thing , the site which has the problem . Please use this command and share the output
debug ccsip mess
Thank you
I have enabled the debug but will have to wait until people return to the site Monday to get the results.  It is already past business hours here.
I finally have the debugs.  Please don't pay attention to the date/time.  The two routers are about 4 minutes off and the customer doesn't do NTP.  The situation is extension 6221 at one site calling 3902 at the other site.  There are two calls.  The first call is picked up by 3902 and is a brief, but successful, voice conversation.  The second call rolls to voicemail and exhibits the problem.
The first set of output is from the router at the site the call is being placed from.
Feb 13 17:56:48.854: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SUBSCRIBE sip:5720@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFD00
To: <5720>
Call-ID: 92A90E7D-753D11E2-B3B3FC50-B0DDB200@192.168.61.1
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Date: Wed, 13 Feb 2013 17:56:48 GMT
User-Agent: Cisco-SIPGateway/IOS-12.x
Event: presence
Expires: 3600
Contact: <192.168.61.1:5060>
Accept:  application/pidf+xml
Content-Length: 0
Feb 13 17:56:48.866: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 202 Accepted
To: <5720>;tag=5DBCE484-608
Date: Wed, 13 Feb 2013 18:00:30 GMT
CSeq: 101 SUBSCRIBE
Content-Length: 0
Contact: <5720>
Expires: 3600
Feb 13 17:56:48.870: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:192.168.61.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A27FB0
To: <6221>;tag=2E52AF2C-D3F
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: presence
Subscription-State: active;expires=3600
Contact: <5720>
Content-Type: application/pidf+xml
Content-Length: 451
      Closed
      Closed
Feb 13 17:56:48.874: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
Feb 13 17:56:49.138: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFD1EC3
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Date: Wed, 13 Feb 2013 17:56:49 GMT
Event: presence
Expires: 0
Content-Length: 0
Feb 13 17:56:49.146: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 SUBSCRIBE
Content-Length: 0
Contact: <5720>
Expires: 0
Feb 13 17:56:49.150: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A282307
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: presence
Subscription-State: terminated;reason=timeout
Contact: <5720>
Content-Length: 451
      Closed
      Closed
Feb 13 17:56:49.154: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
Feb 13 17:56:55.626: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:5902@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFD2466
Remote-Party-ID: "Control" <6221>;party=calling;screen=no;privacy=off
To: <5902>
Date: Wed, 13 Feb 2013 17:56:55 GMT
Call-ID: 96B12A03-753D11E2-B3B9FC50-B0DDB200@192.168.61.1
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2519232860-1966936546-3014982736-2967319040
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1360778215
Contact: <6221>
Call-Info: <192.168.61.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 191
v=0
o=CiscoSystemsSIP-GW-UserAgent 3408 9051 IN IP4 192.168.61.1
s=SIP Call
c=IN IP4 192.168.61.1
t=0 0
m=audio 18540 RTP/AVP 0
a=rtpmap:0 PCMU/8000
a=ptime:20
Feb 13 17:56:55.642: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <5902>
Date: Wed, 13 Feb 2013 18:00:37 GMT
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Feb 13 17:56:55.686: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <5902>;tag=5DBCFF28-1589
CSeq: 101 INVITE
Require: 100rel
RSeq: 8898
Remote-Party-ID: <5902>;party=called;screen=no;privacy=off
Contact: <5902>
Call-Info: <192.168.20.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Supported: sdp-anat
Content-Length: 191
v=0
o=CiscoSystemsSIP-GW-UserAgent 3186 2655 IN IP4 192.168.20.1
s=SIP Call
c=IN IP4 192.168.20.1
t=0 0
m=audio 25326 RTP/AVP 0
a=ptime:20
Feb 13 17:56:55.698: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:5902@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFD30
CSeq: 102 PRACK
RAck: 8898 101 INVITE
Max-Forwards: 70
Content-Length: 0
Feb 13 17:56:55.706: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
Feb 13 17:57:17.566: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Contact: <5902>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 191
v=0
s=SIP Call
t=0 0
a=ptime:20
Feb 13 17:57:17.574: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFD491F
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Feb 13 17:57:22.542: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:5902@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFD520F9
Max-Forwards: 70
Timestamp: 1360778242
CSeq: 103 BYE
Reason: Q.850;cause=16
Content-Length: 0
Feb 13 17:57:22.618: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Wed, 13 Feb 2013 18:01:03 GMT
CSeq: 103 BYE
P-RTP-Stat: PS=1343,OS=214880,PR=1338,OR=214080,PL=0,JI=0,LA=6,DU=5
Content-Length: 0
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
CFS-HERM-1861W#
Feb 13 17:58:19.806: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SUBSCRIBE sip:3956@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFD6149E
To: <3956>
Call-ID: C8DE9EC5-753D11E2-B3BAFC50-B0DDB200@192.168.61.1
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Date: Wed, 13 Feb 2013 17:58:19 GMT
Event: presence
Expires: 3600
Content-Length: 0
Feb 13 17:58:19.814: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SUBSCRIBE sip:3902@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFD7606
To: <3902>
Call-ID: C8DFD714-753D11E2-B3BBFC50-B0DDB200@192.168.61.1
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 3600
Content-Length: 0
Sent:
SUBSCRIBE sip:3804@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFD80
To: <3804>
Call-ID: C8DFD714-753D11E2-B3BCFC50-B0DDB200@192.168.61.1
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 3600
Content-Length: 0
Feb 13 17:58:19.818: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SUBSCRIBE sip:3901@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFD9EA5
To: <3901>
Call-ID: C8E0733C-753D11E2-B3BDFC50-B0DDB200@192.168.61.1
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 3600
Content-Length: 0
Received:
To: <3956>;tag=5DBE47CC-14E2
Date: Wed, 13 Feb 2013 18:02:01 GMT
CSeq: 101 SUBSCRIBE
Content-Length: 0
Contact: <3956>
Expires: 3600
Received:
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A301140
To: <6221>;tag=2E541270-159B
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3956>
Content-Length: 447
      Open
      Open
Feb 13 17:58:19.834: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SUBSCRIBE sip:3592@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFDA12FF
To: <3592>
Call-ID: C8E2484D-753D11E2-B3BEFC50-B0DDB200@192.168.61.1
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 3600
Content-Length: 0
Sent:
SUBSCRIBE sip:3990@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFDB11A8
To: <3990>
Call-ID: C8E2E475-753D11E2-B3BFFC50-B0DDB200@192.168.61.1
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 3600
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
Feb 13 17:58:19.838: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <3902>;tag=5DBE47D4-1FED
CSeq: 101 SUBSCRIBE
Content-Length: 0
Contact: <3902>
Expires: 3600
Received:
To: <3804>;tag=5DBE47D8-13B4
CSeq: 101 SUBSCRIBE
Content-Length: 0
Contact: <3804>
Expires: 3600
Feb 13 17:58:19.842: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <3901>;tag=5DBE47DC-E4B
CSeq: 101 SUBSCRIBE
Content-Length: 0
Contact: <3901>
Expires: 3600
Received:
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A31202A
To: <6221>;tag=2E541278-2312
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3902>
Content-Length: 447
      Open
      Open
Feb 13 17:58:19.846: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A321E41
To: <6221>;tag=2E541278-B99
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3804>
Content-Length: 447
      Open
      Open
Feb 13 17:58:19.850: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A33B65
To: <6221>;tag=2E54127C-C6E
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3901>
Content-Length: 450
      Closed
      Closed
Feb 13 17:58:19.854: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <3592>;tag=5DBE47E8-141
CSeq: 101 SUBSCRIBE
Content-Length: 0
Contact: <3592>
Expires: 3600
Received:
To: <3990>;tag=5DBE47EC-22A3
CSeq: 101 SUBSCRIBE
Content-Length: 0
Contact: <3990>
Expires: 3600
Feb 13 17:58:19.858: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A349A2
To: <6221>;tag=2E54128C-1300
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3592>
Content-Length: 447
      Open
      Open
Received:
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A36165D
To: <6221>;tag=2E54128C-ECF
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3990>
Content-Length: 451
      Closed
      Closed
Feb 13 17:58:19.878: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
Feb 13 17:58:20.058: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFDC374
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Date: Wed, 13 Feb 2013 17:58:20 GMT
Event: presence
Expires: 0
Content-Length: 0
Feb 13 17:58:20.062: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFDDBB0
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 0
Content-Length: 0
Feb 13 17:58:20.066: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 SUBSCRIBE
Content-Length: 0
Contact: <3804>
Expires: 0
Feb 13 17:58:20.070: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A37EF
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3804>
Content-Length: 447
      Open
      Open
Feb 13 17:58:20.074: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
Received:
CSeq: 102 SUBSCRIBE
Content-Length: 0
Contact: <3592>
Expires: 0
Feb 13 17:58:20.078: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A38100E
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3592>
Content-Length: 447
      Open
      Open
Sent:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
Feb 13 17:58:20.498: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFDE241E
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 0
Content-Length: 0
Feb 13 17:58:20.510: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 SUBSCRIBE
Content-Length: 0
Contact: <3956>
Expires: 0
Received:
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A391202
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3956>
Content-Length: 447
      Open
      Open
Feb 13 17:58:20.514: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
Feb 13 17:58:21.510: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFDF269
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Date: Wed, 13 Feb 2013 17:58:21 GMT
Event: presence
Expires: 0
Content-Length: 0
Feb 13 17:58:21.518: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Date: Wed, 13 Feb 2013 18:02:02 GMT
CSeq: 102 SUBSCRIBE
Content-Length: 0
Contact: <3901>
Expires: 0
Feb 13 17:58:21.522: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A3AAA8
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3901>
Content-Length: 450
      Closed
      Closed
Feb 13 17:58:21.526: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
Feb 13 17:58:22.658: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFE01AEC
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Date: Wed, 13 Feb 2013 17:58:22 GMT
Event: presence
Expires: 0
Content-Length: 0
Feb 13 17:58:22.858: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Date: Wed, 13 Feb 2013 18:02:04 GMT
CSeq: 102 SUBSCRIBE
Content-Length: 0
Contact: <3902>
Expires: 0
Feb 13 17:58:22.862: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A3B25B
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3902>
Content-Length: 447
      Open
      Open
Sent:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
Feb 13 17:58:23.174: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:3902@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFE1AF9
To: <3902>
Date: Wed, 13 Feb 2013 17:58:23 GMT
Call-ID: CAE08A66-753D11E2-B3C5FC50-B0DDB200@192.168.61.1
Min-SE:  1800
Cisco-Guid: 3395033095-1966936546-3015769168-2967319040
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1360778303
Contact: <6221>
Expires: 180
Content-Length: 191
v=0
o=CiscoSystemsSIP-GW-UserAgent 1534 6899 IN IP4 192.168.61.1
s=SIP Call
t=0 0
m=audio 17210 RTP/AVP 0
a=ptime:20
Feb 13 17:58:23.198: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <3902>
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 180 Ringing
To: <3902>;tag=5DBE5500-1D3
CSeq: 101 INVITE
Require: 100rel
RSeq: 9013
Remote-Party-ID: "Paul Anderson 3902" <3902>;party=called;screen=no;privacy=off
Contact: <3902>
Content-Length: 0
Feb 13 17:58:23.202: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:3902@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFE21EAE
CSeq: 102 PRACK
RAck: 9013 101 INVITE
Max-Forwards: 70
Content-Length: 0
Feb 13 17:58:23.214: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
Feb 13 17:58:26.302: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Contact: <3902>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 191
v=0
o=CiscoSystemsSIP-GW-UserAgent 5082 6221 IN IP4 192.168.20.1
s=SIP Call
t=0 0
m=audio 31080 RTP/AVP 0
a=ptime:20
Feb 13 17:58:26.318: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFE321D7
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Feb 13 17:58:51.026: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:3902@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFE4B68
Max-Forwards: 70
Timestamp: 1360778331
CSeq: 103 BYE
Content-Length: 0
Feb 13 17:58:51.042: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Wed, 13 Feb 2013 18:02:32 GMT
CSeq: 103 BYE
P-RTP-Stat: PS=1229,OS=196640,PR=1230,OR=196800,PL=0,JI=0,LA=0,DU=24
Content-Length: 0
Feb 13 17:58:53.318: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFE5356
To: <3902>
Date: Wed, 13 Feb 2013 17:58:53 GMT
Call-ID: DCD789D7-753D11E2-B3CBFC50-B0DDB200@192.168.61.1
Min-SE:  1800
Cisco-Guid: 3698952875-1966936546-3016162384-2967319040
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1360778333
Contact: <6221>
Expires: 180
Content-Length: 191
v=0
o=CiscoSystemsSIP-GW-UserAgent 2823 7919 IN IP4 192.168.61.1
s=SIP Call
t=0 0
m=audio 18198 RTP/AVP 0
a=ptime:20
Feb 13 17:58:53.342: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <3902>
Date: Wed, 13 Feb 2013 18:02:34 GMT
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 180 Ringing
To: <3902>;tag=5DBECAC0-1FAB
CSeq: 101 INVITE
Require: 100rel
RSeq: 7094
Contact: <3902>
Content-Length: 0
Feb 13 17:58:53.346: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFE696D
CSeq: 102 PRACK
RAck: 7094 101 INVITE
Max-Forwards: 70
Content-Length: 0
Feb 13 17:58:53.358: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
Feb 13 17:58:54.806: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 300 Multiple Choices
CSeq: 101 INVITE
Diversion: <3902>;reason=no-answer;counter=1
Contact: <8000>,<8000>
Content-Length: 0
Feb 13 17:58:54.810: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Feb 13 17:58:54.814: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:8000@192.168.20.2:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFE7D1B
To: <3902>
Date: Wed, 13 Feb 2013 17:58:54 GMT
Min-SE:  1800
CSeq: 103 INVITE
Max-Forwards: 70
Timestamp: 1360778334
Contact: <6221>
Expires: 180
Content-Length: 191
v=0
s=SIP Call
t=0 0
a=ptime:20
Feb 13 17:58:54.822: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <3902>
CSeq: 103 INVITE
Content-Length: 0
Feb 13 17:58:54.842: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <3902>;tag=dscb56c964
CSeq: 103 INVITE
Content-Length: 0
Contact: <3902>
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: DCD789D7-753D11E2-B3CBFC50-B0DDB200@192.168.61.1
Feb 13 17:58:54.866: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 103 INVITE
Content-Length: 132
Contact: <3902>
Call-Info: <192.168.20.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
v=0
o=CUE 12120929 2 IN IP4 192.168.20.2
s=SIP Call
c=IN IP4 192.168.20.2
t=0 0
m=audio 21358 RTP/AVP 0
Feb 13 17:58:54.882: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:3902@192.168.20.2:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFE81BF5
Max-Forwards: 70
CSeq: 103 ACK
Content-Length: 0
Feb 13 17:59:51.446: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:3902@192.168.20.2:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.61.1:5060;branch=z9hG4bKFE91D79
Max-Forwards: 70
Timestamp: 1360778391
CSeq: 104 BYE
Content-Length: 0
Feb 13 17:59:51.454: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 104 BYE
Content-Length: 0
The second set of output is from the router at the site being called.
054673: Feb 13 18:00:30.287: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <5720>
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 3600
Content-Length: 0
054674: Feb 13 18:00:30.291: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 SUBSCRIBE
Content-Length: 0
Contact: <5720>
Expires: 3600
054675: Feb 13 18:00:30.291: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <5720>
Content-Length: 451
      Closed
      Closed
054676: Feb 13 18:00:30.307: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
054677: Feb 13 18:00:30.571: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 0
Content-Length: 0
054678: Feb 13 18:00:30.571: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 SUBSCRIBE
Content-Length: 0
Contact: <5720>
Expires: 0
054679: Feb 13 18:00:30.571: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <5720>
Content-Length: 451
      Closed
      Closed
054680: Feb 13 18:00:30.587: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
054681: Feb 13 18:00:37.059: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <5902>
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <6221>
Expires: 180
Content-Length: 191
v=0
s=SIP Call
t=0 0
a=ptime:20
054682: Feb 13 18:00:37.067: //123336/9628715CB3B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <5902>
CSeq: 101 INVITE
Content-Length: 0
054683: Feb 13 18:00:37.111: //123336/9628715CB3B4/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 INVITE
Require: 100rel
RSeq: 8898
Contact: <5902>
Supported: sdp-anat
Content-Length: 191
v=0
s=SIP Call
t=0 0
a=ptime:20
054684: Feb 13 18:00:37.131: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 PRACK
Max-Forwards: 70
Content-Length: 0
054685: Feb 13 18:00:37.131: //123336/9628715CB3B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
054686: Feb 13 18:00:58.987: %ISDN-6-CONNECT: Interface Serial0/0/0:21 is now connected to 5902 N/A
054687: Feb 13 18:00:58.991: //123336/9628715CB3B4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Contact: <5902>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 191
v=0
s=SIP Call
t=0 0
a=ptime:20
054688: Feb 13 18:00:59.011: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
054689: Feb 13 18:01:02.883: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 97943333 N/A
054690: Feb 13 18:01:03.983: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 BYE
Content-Length: 0
054691: Feb 13 18:01:04.043: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 103 BYE
Content-Length: 0
054692: Feb 13 18:01:04.063: %ISDN-6-DISCONNECT: Interface Serial0/0/0:21  disconnected from 5902 , call lasted 5 seconds
054693: Feb 13 18:01:11.055: %ISDN-6-DISCONNECT: Interface Serial0/0/0:22  disconnected from 97943333 , call lasted 8 seconds
054694: Feb 13 18:01:15.955: //123339/31DD762BB4E8/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:8001@192.168.20.2:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A296F3
Remote-Party-ID: "LOCAL  2" <6155506350>;party=calling;screen=yes;privacy=off
To: <8001>
Date: Wed, 13 Feb 2013 18:01:15 GMT
Call-ID: 31DD762B-753E11E2-B4ECABC7-25BAF94E@192.168.20.1
Min-SE:  1800
Cisco-Guid: 0836597291-1967002082-3035147207-0633010510
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1360778475
Contact: <6155506350>
Diversion: <7537>;privacy=off;reason=unconditional;counter=1;screen=no
Expires: 180
Content-Length: 191
v=0
o=CiscoSystemsSIP-GW-UserAgent 3259 5023 IN IP4 192.168.20.1
s=SIP Call
t=0 0
m=audio 26830 RTP/AVP 0
a=ptime:20
054695: Feb 13 18:01:15.963: //123339/31DD762BB4E8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <8001>
CSeq: 101 INVITE
Content-Length: 0
054696: Feb 13 18:01:15.975: //123339/31DD762BB4E8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <8001>;tag=ds4d2a8fbc
CSeq: 101 INVITE
Content-Length: 0
Contact: <8001>
Cisco-Gcid: 31DD762B-753E11E2-B4ECABC7-25BAF94E@192.168.20.1
054697: Feb 13 18:01:15.995: //123339/31DD762BB4E8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 132
Contact: <8001>
v=0
o=CUE 12040635 2 IN IP4 192.168.20.2
s=SIP Call
t=0 0
m=audio 20818 RTP/AVP 0
054698: Feb 13 18:01:16.003: //123339/31DD762BB4E8/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:8001@192.168.20.2:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A2A42E
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
054699: Feb 13 18:01:16.043: %ISDN-6-CONNECT: Interface Serial0/0/0:6 is now connected to 6155506350 N/A
054700: Feb 13 18:01:30.111: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Sending: Binary Message Body
054701: Feb 13 18:01:30.111: Content-Type: audio/telephone-event
01 00 07 D0
054702: Feb 13 18:01:30.111: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:8001@192.168.20.2:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A2BB9
CSeq: 102 NOTIFY
Max-Forwards: 70
Date: Wed, 13 Feb 2013 18:01:30 GMT
Event: telephone-event
Contact: <192.168.20.1:5060>
Content-Length: 4
.P
054703: Feb 13 18:01:30.111: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 NOTIFY
Content-Length: 0
Allow-Events: refer
Allow-Events: message-summary
054704: Feb 13 18:01:30.307: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
054705: Feb 13 18:01:30.311: Content-Type: audio/telephone-event
01 80 00 E8
054706: Feb 13 18:01:30.311: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A2C652
CSeq: 103 NOTIFY
Max-Forwards: 70
Content-Length: 4
.h
054707: Feb 13 18:01:30.311: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 103 NOTIFY
Content-Length: 0
Allow-Events: refer
054708: Feb 13 18:01:33.355: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:6155506350@192.168.20.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.20.2:5060;branch=z9hG4bKPNQs9w9ljJ95Xox.Eup+dg~~18923
Max-Forwards: 70
To: <6155506350>;tag=5DBD96E4-1326
CSeq: 2 BYE
Content-Length: 0
Also: <4170>
054709: Feb 13 18:01:33.359: //123339/31DD762BB4E8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "LOCAL  2" <6155506350>;tag=5DBD96E4-1326
Date: Wed, 13 Feb 2013 18:01:33 GMT
CSeq: 2 BYE
P-RTP-Stat: PS=852,OS=136320,PR=718,OR=114721,PL=0,JI=0,LA=0,DU=17
Content-Length: 0
054710: Feb 13 18:01:33.363: //123341/3C3D1ACCB4ED/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A2D140
To: <8000>
Call-ID: 3C3DB6F4-753E11E2-B4F1ABC7-25BAF94E@192.168.20.1
Min-SE:  1800
Cisco-Guid: 1010637516-1967002082-3035474887-0633010510
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1360778493
Diversion: <4170>;privacy=off;reason=unconditional;counter=1;screen=no
Expires: 180
Content-Length: 191
v=0
o=CiscoSystemsSIP-GW-UserAgent 9844 8977 IN IP4 192.168.20.1
s=SIP Call
t=0 0
m=audio 18000 RTP/AVP 0
a=ptime:20
054711: Feb 13 18:01:33.367: //123341/3C3D1ACCB4ED/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <8000>
CSeq: 101 INVITE
Content-Length: 0
054712: Feb 13 18:01:33.407: //123341/3C3D1ACCB4ED/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <8000>;tag=ds3cc1d3d2
CSeq: 101 INVITE
Content-Length: 0
Contact: <8000>
Cisco-Gcid: 3C3DB6F4-753E11E2-B4F1ABC7-25BAF94E@192.168.20.1
054713: Feb 13 18:01:33.431: //123341/3C3D1ACCB4ED/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 132
Contact: <8000>
v=0
o=CUE 12058044 2 IN IP4 192.168.20.2
s=SIP Call
t=0 0
m=audio 21096 RTP/AVP 0
054714: Feb 13 18:01:33.435: //123341/3C3D1ACCB4ED/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:8000@192.168.20.2:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A2E247F
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
CFS_Nash_2901#
054715: Feb 13 18:02:00.527: %ISDN-6-DISCONNECT: Interface Serial0/0/0:6  disconnected from 6155506350 , call lasted 44 seconds
054716: Feb 13 18:02:00.539: //123341/3C3D1ACCB4ED/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:8000@192.168.20.2:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.20.1:5060;branch=z9hG4bK18A2F1F0E
Max-Forwards: 70
Timestamp: 1360778520
CSeq: 102 BYE
P-RTP-Stat: PS=1354,OS=216640,PR=1323,OR=211203,PL=0,JI=0,LA=0,DU=27
Content-Length: 0
054717: Feb 13 18:02:00.539: //123341/3C3D1ACCB4ED/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 BYE
Content-Length: 0
054718: Feb 13 18:02:01.239: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <3956>
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 3600
Content-Length: 0
054719: Feb 13 18:02:01.243: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 SUBSCRIBE
Content-Length: 0
Contact: <3956>
Expires: 3600
054720: Feb 13 18:02:01.243: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3956>
Content-Length: 447
      Open
      Open
054721: Feb 13 18:02:01.251: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <3902>
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 3600
Content-Length: 0
054722: Feb 13 18:02:01.255: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 SUBSCRIBE
Content-Length: 0
Contact: <3902>
Expires: 3600
054723: Feb 13 18:02:01.255: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <3804>
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 3600
Content-Length: 0
054724: Feb 13 18:02:01.255: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <3901>
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 3600
Content-Length: 0
054725: Feb 13 18:02:01.259: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 SUBSCRIBE
Content-Length: 0
Contact: <3804>
Expires: 3600
054726: Feb 13 18:02:01.259: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 SUBSCRIBE
Content-Length: 0
Contact: <3901>
Expires: 3600
054727: Feb 13 18:02:01.263: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3902>
Content-Length: 447
      Open
      Open
054728: Feb 13 18:02:01.263: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3804>
Content-Length: 447
      Open
      Open
054729: Feb 13 18:02:01.263: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3901>
Content-Length: 450
      Closed
      Closed
054730: Feb 13 18:02:01.271: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <3592>
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 3600
Content-Length: 0
054731: Feb 13 18:02:01.271: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 SUBSCRIBE
Content-Length: 0
Contact: <3592>
Expires: 3600
054732: Feb 13 18:02:01.271: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <3990>
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 3600
Content-Length: 0
054733: Feb 13 18:02:01.275: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
054734: Feb 13 18:02:01.275: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 SUBSCRIBE
Content-Length: 0
Contact: <3990>
Expires: 3600
054735: Feb 13 18:02:01.279: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3592>
Content-Length: 447
      Open
      Open
054736: Feb 13 18:02:01.279: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3990>
Content-Length: 451
      Closed
      Closed
054737: Feb 13 18:02:01.315: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
054738: Feb 13 18:02:01.315: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
054739: Feb 13 18:02:01.315: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
054740: Feb 13 18:02:01.315: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
054741: Feb 13 18:02:01.319: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
054742: Feb 13 18:02:01.495: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 0
Content-Length: 0
054743: Feb 13 18:02:01.495: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 SUBSCRIBE
Content-Length: 0
Contact: <3804>
Expires: 0
054744: Feb 13 18:02:01.495: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3804>
Content-Length: 447
      Open
      Open
054745: Feb 13 18:02:01.499: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 0
Content-Length: 0
054746: Feb 13 18:02:01.503: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 SUBSCRIBE
Content-Length: 0
Contact: <3592>
Expires: 0
054747: Feb 13 18:02:01.503: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3592>
Content-Length: 447
      Open
      Open
054748: Feb 13 18:02:01.511: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
054749: Feb 13 18:02:01.515: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
054750: Feb 13 18:02:01.935: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 0
Content-Length: 0
054751: Feb 13 18:02:01.935: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 SUBSCRIBE
Content-Length: 0
Contact: <3956>
Expires: 0
054752: Feb 13 18:02:01.939: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3956>
Content-Length: 447
      Open
      Open
054753: Feb 13 18:02:01.951: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
054754: Feb 13 18:02:02.947: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 0
Content-Length: 0
054755: Feb 13 18:02:02.947: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 SUBSCRIBE
Content-Length: 0
Contact: <3901>
Expires: 0
054756: Feb 13 18:02:02.951: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3901>
Content-Length: 450
      Closed
      Closed
054757: Feb 13 18:02:02.963: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
054758: Feb 13 18:02:04.247: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Event: presence
Expires: 0
Content-Length: 0
054759: Feb 13 18:02:04.287: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 SUBSCRIBE
Content-Length: 0
Contact: <3902>
Expires: 0
054760: Feb 13 18:02:04.287: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: presence
Contact: <3902>
Content-Length: 447
      Open
      Open
054761: Feb 13 18:02:04.299: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
054762: Feb 13 18:02:04.611: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <3902>
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <6221>
Expires: 180
Content-Length: 191
v=0
s=SIP Call
t=0 0
a=ptime:20
054763: Feb 13 18:02:04.623: //123342/CA5C1807B3C0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <3902>
CSeq: 101 INVITE
Content-Length: 0
054764: Feb 13 18:02:04.623: //123342/CA5C1807B3C0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 9013
Contact: <3902>
Content-Length: 0
054765: Feb 13 18:02:04.639: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 PRACK
Max-Forwards: 70
Content-Length: 0
054766: Feb 13 18:02:04.643: //123342/CA5C1807B3C0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
054767: Feb 13 18:02:07.731: //123342/CA5C1807B3C0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Contact: <3902>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 191
v=0
s=SIP Call
t=0 0
a=ptime:20
054768: Feb 13 18:02:07.755: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
054769: Feb 13 18:02:32.463: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 103 BYE
Content-Length: 0
054770: Feb 13 18:02:32.467: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 103 BYE
Content-Length: 0
054771: Feb 13 18:02:34.759: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <3902>
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <6221>
Expires: 180
Content-Length: 191
v=0
s=SIP Call
t=0 0
a=ptime:20
054772: Feb 13 18:02:34.771: //123345/DC798AABB3C6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <3902>
CSeq: 101 INVITE
Content-Length: 0
054773: Feb 13 18:02:34.771: //123345/DC798AABB3C6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 7094
Contact: <3902>
Content-Length: 0
054774: Feb 13 18:02:34.783: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 PRACK
Max-Forwards: 70
Content-Length: 0
054775: Feb 13 18:02:34.787: //123345/DC798AABB3C6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
054776: Feb 13 18:02:36.235: //123345/DC798AABB3C6/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 INVITE
Content-Length: 0
054777: Feb 13 18:02:36.251: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
054778: Feb 13 18:03:33.115: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:80103902@192.168.20.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.20.2:5060;branch=z9hG4bKPNQs9w9ljJ95Xox.Eup+dg~~18924
Max-Forwards: 70
To: <80103902>
Call-ID: 13607786131068163@192.168.20.2
CSeq: 100 INVITE
Content-Length: 132
Contact: <8000>
Cisco-Gcid: D4B9D172-013C-1000-476D-1D9A218E81C9
v=0
o=CUE 12177787 2 IN IP4 192.168.20.2
s=SIP Call
t=0 0
m=audio 47504 RTP/AVP 0
054779: Feb 13 18:03:33.127: //123347/839F0812B501/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <80103902>
Date: Wed, 13 Feb 2013 18:03:33 GMT
CSeq: 100 INVITE
Content-Length: 0
054780: Feb 13 18:03:33.127: //123347/839F0812B501/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <80103902>;tag=5DBFAEB8-20B0
CSeq: 100 INVITE
Remote-Party-ID: <80100000>;party=called;screen=no;privacy=off
Contact: <80103902>
Content-Length: 0
054781: Feb 13 18:03:38.127: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:80103902@192.168.20.1:5060;transport=udp SIP/2.0
Max-Forwards: 70
To: <80103902>
CSeq: 100 CANCEL
Content-Length: 0
054782: Feb 13 18:03:38.131: //123347/839F0812B501/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <80103902>
Date: Wed, 13 Feb 2013 18:03:38 GMT
CSeq: 100 CANCEL
Content-Length: 0
054783: Feb 13 18:03:38.131: //123347/839F0812B501/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 487 Request Cancelled
CSeq: 100 INVITE
Content-Length: 0
054784: Feb 13 18:03:38.143: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:80103902@192.168.20.1:5060;transport=udp SIP/2.0
Max-Forwards: 70
CSeq: 100 ACK
Content-Length: 0
Thanks again for looking at this.
