Maximum number of route groups, route lists and route patterns
Karla Lopez
Hi guys!:
I need to know is there is a maximum number of:
Route groups
Route lists
Route patterns
for CUCM 7.1.3 and 7.1.5. I already read the SRND and I could only find that there is a maximum of 500 route lists per server. Thank you in advance!
Karla
Jaime Valencia
There are no hard numbers for any of what you're asking and the limit you mention is not even CUCM's as clearly explained in the SRND.
That is a CUOMs limitation.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
