03-30-2015 03:16 AM - edited 03-17-2019 02:29 AM
Dear All,
i have ip phone 8945 series and router. i configure router as video conference bridge. i set maximum participant for 4 persons. i also configure separate audio conference bridge on the same router.
when the max video conf participant reached (4 persons), is it automatically add the new participant as audio only?
because in my customer, i can't add another participant.
Please advice.
Thank you,
Anju
Solved! Go to Solution.
03-30-2015 08:17 AM
No, you set the maximum participants to 4, you only get 4 participants on the CFB, either audio only, or video.
03-30-2015 08:17 AM
03-30-2015 08:56 AM
Adding to what jaime said, "Maximum Participants" define maximum number of participants per conference above which no more users can join the same conference.
Although you can have audio participants join the the video conference within the limit of maximum number of participants in a single conference.
03-31-2015 07:18 PM
Dear All,
Nice Share.
I'll try it first n update later.
Anju
