10-02-2014 03:15 AM - edited 03-17-2019 12:24 AM
Dears
i configure mobile voice access and i can hear the IVR when i call from a PSTN Line and i input my Remote destination number then it ask me for my PIN and i put it then it ask to press one for a call and after that i dialed the number but it give busy tone
here is my configuration
my MVA number is 7999
my IOS COnfiguration
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
voice translation-rule 3
rule 1 /^9\(\)/ /\1/
voice translation-rule 4
rule 4 /^22217/ /7/
rule 5 /^2217/ /7/
rule 6 /^022217/ /7/
rule 7 /^0122217/ /7/
voice translation-rule 5
rule 1 /^5/ /905/
rule 2 /^1/ /901/
rule 3 /^2/ /902/
rule 4 /^3/ /903/
rule 5 /^4/ /904/
rule 6 /^6/ /906/
rule 7 /^7/ /907/
rule 8 /^8/ /908/
rule 10 /^00/ /900/
rule 11 /'+'/ /900/
voice translation-rule 9
rule 1 /^5/ /05/
voice translation-profile MVA
translate calling 9
voice translation-profile OUT
translate called 3
voice translation-profile REDIAL
translate calling 5
voice translation-profile SIP-NEW
translate called 4
dial-peer voice 802 voip
description ** SIP TO STC **
translation-profile outgoing OUT
destination-pattern 9T
session protocol sipv2
session target ipv4:10.208.9.69:5060
session transport udp
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
voice-class sip profiles 1
dtmf-relay sip-notify rtp-nte sip-kpml
fax rate disable
no vad
voice-class codec 1
fax rate disable
no vad
dial-peer voice 811 voip
description ** SIP INCOMING FROM STC **
translation-profile incoming SIP-NEW
translation-profile outgoing REDIAL
destination-pattern 7...
session target ipv4:192.168.200.53
incoming called-number 022217...$
voice-class codec 1
fax rate disable
no vad
dial-peer voice 812 voip
incoming called-number 22217...$
codec g711alaw
dial-peer voice 7999 voip
Description "MVA"
service mva
incoming called-number 2217999
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 7991 voip
destination-pattern 7999
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
in the service parameter
False | ||
Complete Match | ||
Thanks in Advanced |
Solved! Go to Solution.
10-02-2014 05:16 AM
Hi.
Did you check that CSS of associated DN on Destination Profile an redirect CSS allows you to call out?
Let us know.
Carlo
10-02-2014 08:21 AM
dears yes my css is international and rerouting also an international
10-03-2014 04:59 AM
Yes it allow to reroute call to interntional, mobile, local & national
