Modifing VG3745 configuration
Camélia
Hello everyone;
I have a cisco 3745 voice gateway already configured and working.
I want to modify the configuration for one directory number ( for example replacing 1000  by  2000).
what are the modification that must be done, using witch commands.
N.B : by showing the running config, i know already that i should change the voice translation rule, voice translation profile, translate called , voice port and  the dial peer, but what are the commands and is it all ??!!
Thanks for help.
11 Replies 11
Hi.
If your running CME on 3745, you should also go un ephone-dn configuration and change there the number.
Eg.
you should find
ephone-dn 10
number 1000
just go in configuration mode and..
ephone-dn 10
number 2000
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo and thanks for your quick reply.
No, i don't have CME, but i know that i should make some changes on my CUCM under device>phone>directory number.
What i need the most are the commands that should be introduced on the VG, while i had never manipulate it, i have no idea about the commands.
Thanks again.
Regards.
Soumia.
Hi Soumia.
If you can upload here your VG config, we can better elaborate an answer and suggest you more specific commands you need.
Anyway..
if you have, for example, a dialpeer configured as follow:
Assume your DDI is 555XXXX
dial-peer voice 10 pots
incoming called-number 555T
direct-inward-dial
...and someone calls 5551000..
You basically have a couple of solutions
-Applying translation profile on DP
-Configuring Translation Pattern on CUCM..
For first solution you could have:
voice translation-rule 10
rule 1 /555\(....\)/ /\1/
voice translation-profile IN
translate called 10
translation-profile incoming IN
Than You should have diapeers voip to CUCM configured accordingly.
The other option could be configured as follow.
On CUCM define a Translation Pattern eg:
555XXXX as Pattern
Put it on a valid partition (which could be reached by CSS configured as Incoming CSS on VG configuration page)
Add a valid CSS that can reach internal extensions
As Called Party Transform Mask  define : XXXX
In both cases you should be able to reach extensions starting from 0000 to 9999
Carlo
Hi Carlo;
Thanks again for your reply.
Here below the current config :
voice translation-rule 1000
 rule 1 /^02/ /3002/
 rule 2 /^03/ /3003/
 rule 3 /^04/ /3004/
 rule 4 /^00/ /3000/
 rule 5 /^05/ /3005/
 rule 6 /^06/ /3006/
 rule 7 /^07/ /3007/
 rule 8 /^00/ /3000/
 voice translation-profile Reception
 translate called 1000
 voice-port 1/0/0
 supervisory disconnect dualtone mid-call
 supervisory custom-cptone
 input gain 6
 output attenuation -4
 cptone FR
 timeouts initial 0
 timeouts interdigit 4
 timeouts call-disconnect 0
 timeouts ringing 5
 timeouts wait-release 5
 connection plar opx 1000
 impedance complex2
 description Reception
 caller-id enable
 dial-peer voice 110 voip
 translation-profile incoming Reception
 answer-address 1000
 dial-peer voice 150 pots
 destination-pattern 30T
 port 1/0/0
and i want to replace the directory number 1000 by 2000.
Regards.
Hi Suomia.
What I understood is that you want to redirect incoming calls to extension 2000 instead of 1000.
If I am right, substitute
with
connection plar opx 2000
Carlo
Hi;
Yes, exactly, what are the commands that should be introduced to replace
1000 by 2000 in all the fields above.
Regards.
Hi Soumia.
In my previous post I already mention commands you need.
Under voice port 1/0/0
Carlo
What about the voice translation rule, voice translation profile and the dial peer,  are these fields gonna change automaticly when i'll change the connection plar opx under voice port ?
Regards.
Hi Suomia.
In your configuration translation pattern are used by extension 1000 to translate what that extension calls.
To apply the same rule to extension 2000 , just modify dial-peer 110 as follows
answer-address 2000
Carlo
Hi;
Thanks a lot Carlo, i'll try it soon and keep you informed.
Regards.
hi carlo,
hope y're fine
i introduced the command u said, it work only for receiving calls, i can't forward calls from the ip phone.
do u have an idea.
regards
camélia
