10-13-2015 04:18 AM - edited 03-18-2019 11:40 AM
Hi all,
I need to have in my application a device with 100 lines (+/-), now I'm using a third-party SIP device (advanced) but I only can assign 8 lines to this device.
To achieve 100 lines I need to use 13 third-party SIP device (advanced), but I can't use the same digest user for all, so I have to create a user per device.
Is there a way to have a device (sip device preferably) with more than 8 lines? Or, how I can use the same digest user in multiple sip devices with different extensions?
Nuno Magalhães
10-13-2015 06:02 AM
That's the maximum you can have with SIP 3rd party devices, why do you need 100 lines??? You can probably solve this other way
10-13-2015 06:32 AM
I think that 100 lines doesn't make sense, but the client want to see all lines at once, this lines connects to meet me conferences and them are connected to clients outside. But now I have a doubt, it's possible 100 meetme conferences at same time?
10-13-2015 06:36 AM
Yes, assuming you have enough resources for that, depending on what's the max meetme participants, you might need to have ISRs with nothing but DSPs for that.
If they want to watch a 100 lines, they should be looking into something like ACs, even if you have x number of endpoints in the same machine, how could you possibly see all 100 lines at the same time??
10-13-2015 06:53 AM
It's simple, I have a form with squares, each square represents a line, and only make call for meetme previously configured on application settings, and depending of call state, they have different colors and informations.
I want only one device to support all needed lines or register all sip devices with same digest user, but seems that is impossible, I will use n sip devices and n digest users.
