Multiple instance of IP Communicator on same PC
kayih
hi,
I would like to setup a voice lab, I don't have ip phone. I would like to know if it is possible to run many instance of IP COmmunicator on same PC in other to simulate many phone ???
thank in advance.
5 Replies 5
gogasca
Level 10
Level 10
Afaik only 1 will run at the sametime.
Try also IP Softphone and maybe some 3rd party phones like IP Blue.
I think if you can install multiple Virtual PC on either VMWARE or Microsoft Virtual PC then you can run multiple instance of IP communicator from same PC
Revert me
if you have any problem
try IP Blue
KandyOtero
Works for me with a Virtual Box, I installed two ip communicator, one on the virtual machina and another in the fisical machine.
Best Regards Kandy
smmarcx
We can have two Cisco IPC intances simultaneosuly, the one installed and another one running with a sandboxed software. A third instance can be a 3rd party software.
MicroSIP  > CIPC1 > CIPC2 on conference.
