One-way-Audio, What should the RTP source address be set as?
ken.kopp
We have a Callmanager 6.x deployment performed by an engineer that struggled with the task, so all is suspect.
We have a problem with frequent one-way audio when calling an external number.
Packet captures reveal that we are sending our voice GW’s internal address in the RTP header.
This seems in keeping with the “h323-gateway voip bind srcaddr 172.0.1.252” statement in the FA 0/0 int (internal LAN)
The question is: What should the header contain as the source address? The External address of the GW I am thinking?
If not this statement is there a missing NAT function?
Thanks in advance!
Ken
version 12.4
hostname ISS_2811_voice_gw
boot-start-marker
boot system flash:c2800nm-spservicesk9-mz.124-15.T9.bin
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
logging buffered 51200 warnings
no aaa new-model
clock timezone Pacific -8
clock summer-time Pacific date Apr 6 2003 2:00 Oct 26 2003 2:00
dot11 syslog
ip cef
ip domain name xxxx.com
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.3
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  h225 h245-address on-connect
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice class h323 222
h225 timeout tcp establish 3
  no h225 h245-address on-progress
  no h225 h245-address on-alert
  h225 h245-address facility
  h225 h245-address progress
  h225 h245-address sync
  no h225 h245-address listen-on-setup
  no h225 h245-address on-setup
  telephony-service ccm-compatible
  ccm-compatible
crypto pki trustpoint TP-self-signed-3792167899
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3792167899
revocation-check none
rsakeypair TP-self-signed-3792167899
crypto pki certificate chain TP-self-signed-3792167899
certificate self-signed 01
-    SNIP -
username administrator privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxxxxx
archive
log config
  hidekeys
class-map match-any SDM-Transactional-1
match  dscp af21
match  dscp af22
match  dscp af23
class-map match-any SDM-Signaling-1
match  dscp cs3
match  dscp af31
class-map match-any SDM-Routing-1
match  dscp cs6
class-map match-any SDM-Voice-1
match  dscp ef
class-map match-any SDM-Management-1
match dscp cs2
policy-map SDM-QoS-Policy-1
class SDM-Voice-1
  priority percent 50
class SDM-Signaling-1
  bandwidth percent 5
class SDM-Routing-1
  bandwidth percent 5
class SDM-Management-1
  bandwidth percent 5
class SDM-Transactional-1
  bandwidth percent 5
class class-default
  fair-queue
  random-detect
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address 172.0.1.252 255.255.255.0
ip accounting output-packets
ip nat inside
no ip virtual-reassembly
duplex full
speed 100
h323-gateway voip interface
service-policy output SDM-QoS-Policy-1
interface FastEthernet0/1
description $ETH-WAN$
bandwidth 4000
bandwidth receive 20000
ip address 75.151.xxx.xxx 255.255.255.240
ip nat outside
duplex auto
speed auto
router eigrp 255
network 172.0.1.0 0.0.0.255
auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 75.151.115.142 permanent
ip route 216.82.224.202 255.255.255.255 75.151.115.142
ip route 216.82.225.202 255.255.255.255 75.151.115.142
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool VOICE 75.151.xxx.xxx 75.151.xxx.xxx netmask 255.255.255.0
ip nat inside source list 1 pool VOICE overload
ip nat inside source static 172.0.1.1 75.151.115.130
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.0.0 0.0.0.255
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 172.0.1.0 0.0.0.255
access-list 1 permit 172.0.2.0 0.0.0.255
access-list 1 permit 172.0.254.0 0.0.0.255
access-list 1 permit 10.0.2.0 0.0.0.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 192.168.0.0 0.0.0.255
access-list 2 permit 172.0.1.0 0.0.0.255
access-list 23 remark SDM_ACL Category=16
access-list 23 permit 10.1.0.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 172.0.1.0 0.0.0.255
access-list 23 permit 10.0.1.0 0.0.0.255
access-list 100 remark Auto generated by SDM Management Access feature
access-list 100 remark SDM_ACL Category=1
access-list 100 permit tcp 10.1.0.0 0.0.0.255 host 172.0.1.252 eq telnet
access-list 100 permit tcp 10.0.1.0 0.0.0.255 host 172.0.1.252 eq telnet
access-list 100 permit tcp 10.1.0.0 0.0.0.255 host 172.0.1.252 eq 22
access-list 100 permit tcp 10.0.1.0 0.0.0.255 host 172.0.1.252 eq 22
access-list 100 permit tcp 10.1.0.0 0.0.0.255 host 172.0.1.252 eq www
access-list 100 permit tcp 10.0.1.0 0.0.0.255 host 172.0.1.252 eq www
access-list 100 permit tcp 10.1.0.0 0.0.0.255 host 172.0.1.252 eq 443
access-list 100 permit tcp 10.0.1.0 0.0.0.255 host 172.0.1.252 eq 443
access-list 100 permit tcp 10.1.0.0 0.0.0.255 host 172.0.1.252 eq cmd
access-list 100 permit tcp 10.0.1.0 0.0.0.255 host 172.0.1.252 eq cmd
access-list 100 deny   tcp any host 172.0.1.252 eq telnet
access-list 100 deny   tcp any host 172.0.1.252 eq 22
access-list 100 deny   tcp any host 172.0.1.252 eq www
access-list 100 deny   tcp any host 172.0.1.252 eq 443
access-list 100 deny   tcp any host 172.0.1.252 eq cmd
access-list 100 deny   udp any host 172.0.1.252 eq snmp
access-list 100 permit ip any any
access-list 101 remark SDM_ACL Category=1
access-list 101 permit ip 10.1.0.0 0.0.0.255 any
access-list 101 permit ip 10.10.10.0 0.0.0.7 any
access-list 101 permit ip 172.0.1.0 0.0.0.255 any
access-list 101 permit ip 10.0.1.0 0.0.0.255 any
access-list 102 remark SDM_ACL Category=1
access-list 102 permit ip 10.1.0.0 0.0.0.255 any
access-list 102 permit ip 10.10.10.0 0.0.0.7 any
access-list 102 permit ip 172.0.1.0 0.0.0.255 any
access-list 102 permit ip 10.0.1.0 0.0.0.255 any
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
ring frequency 50
voice-port 0/2/0
timing hookflash-out 50
connection plar 8250
caller-id enable
voice-port 0/2/1
caller-id enable
voice-port 0/2/2
caller-id enable
voice-port 0/2/3
caller-id enable
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 172.0.1.1
ccm-manager config
mgcp
mgcp call-agent 172.0.1.1 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
sccp local FastEthernet0/0
sccp ccm 172.0.1.1 identifier 1 priority 1
sccp ip precedence 1
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
associate profile 2 register CFB0022900cc0a0
associate profile 1 register MTP0022900cc0a0
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
associate application SCCP
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 999011 pots
service mgcpapp
port 0/1/1
dial-peer voice 999012 pots
service mgcpapp
port 0/1/2
dial-peer voice 999013 pots
service mgcpapp
port 0/1/3
dial-peer voice 1 pots
description ** incoming dial peer **
incoming called-number .%
direct-inward-dial
port 0/2/0
dial-peer voice 2 pots
direct-inward-dial
port 0/2/1
dial-peer voice 3 pots
direct-inward-dial
port 0/2/2
dial-peer voice 4 pots
direct-inward-dial
port 0/2/3
dial-peer voice 4251 pots
description ** FXO pots dial-peer **-Emergency dial-peer
destination-pattern 9911
port 0/2/0
forward-digits 3
dial-peer voice 4252 pots
preference 1
port 0/2/1
forward-digits 3
dial-peer voice 4253 pots
preference 2
port 0/2/2
forward-digits 3
dial-peer voice 4254 pots
preference 2
port 0/2/3
forward-digits 3
dial-peer voice 4255 pots
destination-pattern 911
port 0/2/0
forward-digits 3
dial-peer voice 4256 pots
preference 1
port 0/2/1
forward-digits 3
dial-peer voice 4257 pots
preference 2
port 0/2/2
forward-digits 3
dial-peer voice 4258 pots
preference 2
port 0/2/3
forward-digits 3
dial-peer voice 4259 pots
destination-pattern 91[2-9].........
port 0/2/0
forward-digits 11
dial-peer voice 4260 pots
preference 1
port 0/2/1
forward-digits 11
dial-peer voice 4261 pots
preference 2
port 0/2/2
forward-digits 11
dial-peer voice 4262 pots
preference 2
port 0/2/3
forward-digits 11
dial-peer voice 8250 voip
preference 1
destination-pattern 8250
voice-class h323 222
session target ipv4:172.0.1.1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 4263 pots
destination-pattern 9425.......
port 0/2/0
forward-digits 7
dial-peer voice 4264 pots
preference 1
port 0/2/1
forward-digits 7
dial-peer voice 4265 pots
preference 2
port 0/2/2
forward-digits 7
dial-peer voice 4266 pots
preference 3
port 0/2/3
forward-digits 7
dial-peer voice 4267 pots
destination-pattern 9011T
port 0/2/0
forward-digits all
prefix 011
dial-peer voice 4268 pots
preference 1
port 0/2/1
forward-digits all
prefix 011
dial-peer voice 4269 pots
preference 2
port 0/2/2
forward-digits all
prefix 011
dial-peer voice 4270 pots
preference 2
port 0/2/3
forward-digits all
prefix 011
dial-peer voice 4271 pots
destination-pattern 9T
port 0/2/0
forward-digits all
dial-peer voice 4272 pots
preference 1
port 0/2/1
forward-digits all
dial-peer voice 4273 pots
preference 2
port 0/2/2
forward-digits all
dial-peer voice 4274 pots
preference 3
port 0/2/3
forward-digits all
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999030 pots
service mgcpapp
port 0/3/0
dial-peer voice 999031 pots
service mgcpapp
port 0/3/1
gateway
timer receive-rtp 600
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 3
ip source-address 172.0.1.252 port 2000
max-ephones 42
max-dn 125
system message primary CallManager Fallback
banner login _C
This is a private system. Use by unathorized persons is prohibited.
All accesses to this service are logged. Anyone found using this
device or its information for any unauthorized purpose will be subject
to prosecution.
-----------------------------------------------------------------------_
line con 0
login local
line aux 0
line vty 0 4
access-class 101 in
exec-timeout 120 0
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 102 in
exec-timeout 120 0
privilege level 15
login local
scheduler allocate 20000 1000
end
David Hailey
The config with binding to the internal interface is pretty standard.  So, I would ask to dig into the details a bit more to work on this.  Some more call details would help.  Such as:
1) Is this a standard call to an "external" number - i.e., call to PSTN via gateway (PRI and/or POTS)
2) Same number everytime or doesn't matter - in other words, do you get one way audio on calls the same number frequently or just on PSTN calls in general
Hailey
Please rate helpful posts!
The problem only occurs when a call is placed through the gateway and when connecting to another (3rd party) VOIP carrier yes"external".
Our service is 100% Internet based, all calls are carried via our TCP/IP ISP (Docsis) & Internet VIOP Provider, so our gateway is to the Internet.
I agree an internal address would be "standard" for a deployment using say a PRI or POTS for instance, but does still hold true for an "external" IP VOIP Peer scenario?
It's not so much the same number as it is the same carriers, There are multiple carriers that we have the problem with.
Packet captures show that the SIP exchange is OK, however the RTP Stream fails either outbound or both ways.
I have located : One-way audio on calls placed across the PIX Firewall with NAT or PAT
This seems to describe our issue, would an expert care to comment please?
Thanks again in advance!
Ken
Good info regarding the various VoIP ISP's as opposed to standard PRI/POTS gateways attached to the local router.  I don't think it could hurt to add the workaroudn command to your config (I'd go with after hours) and then do some testing to/from the various carriers.  Just make plenty of test calls with decent duration (e.g., 30 seconds) before you determine whether or not things have cleared up.
Hailey
