Outbound calls via FXO fails CUCM 7.1.5 H323 GW
Najeeb Mohammad
I am doing a POC with the following
CUCM  - 7.1.5.31900-3
2821 - (C2800NM-SPSERVICESK9-M), Version 12.4(25d)
2821 is loaded with VIC2-4FXO. 2821 is configured  as H323 gw with the CUCM
The issue is i m not able to make any outbound pstn calls via the FXO, but incoming calls are working fine via fxo. Please find the attached config files and debug messages
Steven Holl
Check CM.  It looks like CM is sending 'incompatible destination:'
Dec  6 06:22:59.521: H225.0 INCOMING PDU ::=
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body releaseComplete :
          protocolIdentifier { 0 0 8 2250 0 5 }
          callIdentifier
            guid '806545424081C1CF050014010A64C123'H
        h245Tunneling FALSE
Dec  6 06:24:48.032: //14/007A3D830700/CCAPI/ccCallDisconnect:
   Cause Value=88, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
