phone extension
Patricio Araya
I'm new to uc500, and im wonder to know if you can get extension numbers like 93xx, it is my old pbx dial plan, and would like to keep it. How you set that?
Thank you
Jaime Valencia
It's your UC500, you can configure whatever dial plan you want.
Use CCA or CLI to get that done.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Yes, im using cca, but I cannot modify dial plan, the system show me an error, and cannot put any other number that 2xxx range.
