Please give me an example about B-ACD in CME 4.1
deadlock2011
Hi, I was try to build an example with cme version 4.1, cme-bacd-2.1.0.0 on Router 2800 and Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(15)T1, RELEASE SOFTWARE (fc2) follow emxample in http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/bacd/configuration/guide/40bacd.html but I can't do like that. Some config not availble.
R(config-app-param)#param ?
  Parameters registered under app-b-acd-aa namespace:
  name                 type  default value   description
  uid-len              I     10              the number of digits in UID
  warning-time         I     30              the time (in secs) within which a user is warned before the calling time expires (call terminates)
  pin-len              I     4               the number of digits in PIN
  retry-count          I     3               the number of attempts to reenter PIN
  redirect-number      S                     the telephone number where a call is redirected to
  WORD  Parameter name
I don't see
param number-of-hunt-grps
param aa-pilot
and something like in cisco's example.
What should I do for write an example on cme? My script is: I have a public number 123456, when customer call to 123456, it will forward to my private number 1111 and play file welcome (en_bacd_welcome.au). And next, it play file en_bacd_options_menu.au, customer listen and follow that, press button 1 foward to number 1001, press button 2 forward to number 1002, press button 3 forward to number 1003. I don't know what should I do. I was config to my cisco ip phone can calling outbound and mobile phone can calling inbound to cisco ip phone. Now I want use cme-bacd but I don't see any example availble with my situation. I hope you can help me an example, thank you very much!
2 Accepted Solutions
By looking at your config, it seems your incoming call to number 0873005686 comes on SIP.
If you only want to play welcome prompt which says "thank you for calling" when anyone calls 0873005686 and then directly go to 1001 pilot number then your config should like below:
application
service app-b-acd
param number-of-hunt-grps 1  <<<<<<
param aa-hunt1 1001    <<<<<<<<
param queue-len 15
param queue-manager-debugs 1
service app-b-acd-aa
paramspace english index 1
paramspace english language en
paramspace english location flash:
param service-name app-b-acd
param handoff-string app-b-acd-aa
param aa-pilot 0873005686    <<<<<<<<
param drop-through-prompt _bacd_welcome.au   <<<<<<<<
param drop-through-option 1 <<<<<<<<
param second-greeting-time 60
param call-retry-timer 15
param max-time-call-retry 700
param max-time-vm-retry 2
param voice-mail 5003
dial-peer voice 222 voip
incoming called-number 8005550123        <<<<<<<<
If 1001 is not a pilot number but actually a DN assigned to a phone then you need to create a dummy pilot(eg. 1111) and associate 1001 DN as the line for that dummy pilot...
service app-b-acd
param aa-hunt1 1111
ephone-hunt 1 longest
pilot 1111
list 1001
I have marked important parameters for you to take care of..
Also make sure that you have all the prompts in flash root directory...
Piyush
Ok now i have understood your requirement..  you have two ip phone with dn 1001 and 1002..
First of all you dont need to use any translation profile on the incoming dial-peer..
simply create a separate dial-peer for incoming call to your number 0873005686.
Just copy and paste below config example and it should work as required...
application
service app-b-acd
param number-of-hunt-grps 2
param aa-hunt1 1111
param aa-hunt2 2222
param queue-len 15
param welcome-prompt _bacd_welcome.au
param dial-by-extension-option 1
incoming called-number 0873005686
pilot 1111
list 1001
ephone-hunt 2 longest
pilot 2222
list 1002
for more understanding follow this link:
Cheers !!
Piyush
5 Replies 5
Jorge Armijo
Level 4
Level 4
What about this one?
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080566c4a.shtml
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
application
service app-b-acd
param queue-len 15
service app-b-acd
param aa-hunt1 1111
pilot 1111
list 1001
Piyush
application
service app-b-acd
param aa-hunt1 1111
param aa-hunt2 2222
param queue-len 15
pilot 1111
list 1001
pilot 2222
list 1002
Cheers !!
Piyush
Thank you! I have solved this problem
Great !!! And thanks for rating 5 my answer.
