pri fast busy tone
SJ SJ
I hav 2 mgcp gateways with pri terminated on them. when publisher goes down i hear a fast busy tone on dialing the pri no. Attached is the capture of sh ccm-manager from both gateways when publisher and subscriber both r available. what is the reason for fast busy tone when pub is down.
Jaime Valencia
Do you have the fallback config for MGCP in the GW and also a route list with a CCM group that allows failover?
You need both for this to work.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
