PRI unable to register to CUCM after CMM IOS upgrade
Percy Morillo
I upgraded a CMM from 12.4(25c) to 12.4(15)T14 and one of my PRIs in port 1/0 is not registering to CUCM. I have another PRI in 1/1 and it’s working fine.  It looks like the voice port (voice-port 1/0:23) disappeared from the configuration. I configured the PRI on a different port (1/2) but the voice port (voice-port 1/2:23) did not show in the configuration. I reseated and I replaced the CMM with new hardware and I got the exact same problem even with the new CMM- the same PRI is not able to register to CUCM. I moved the PRI to a different CMM in a different 6509 switch and it works fine. Has anyone experienced this weird issue?
Here are some relevant configs…
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
description ckt01
interface Serial1/0:23
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
T1 1/0 is up.
  Applique type is Channelized T1
  Cablelength is long gain36 0db
  Description: ckt01
  No alarms detected.
               Gateway#sh isdn status
ISDN Serial1/0:23 interface
        dsl 0, interface ISDN Switchtype = primary-ni
        L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 2
Jaime Valencia
Layer 2 is down:
    Layer 2 Status:
It's expected for it not to register until the link is up.
You need to fix the layer 2 issue and then once you get the MULTIPLE_FRAME_ESTABLISHED message instead of TEI_ASSIGNED it will register.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
