Problem - Unable to Hear the Unity Voicemail Prompts
Hi Cisco Support Community,
I'm Louis an IT Voice Analyst. Kindly see details of my issue below:
I'm having a problem with one of our center, wherein if an outside caller want to be transfered from a phone to another internal phone the caller cannot hear any rings but take not the one at the desk hears the rings. So the caller cannot also hear the voicemail prompt and the VM became useless. I have founded a Cisco Document which is:
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a0080093c11.shtmlhttp://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a0080093c11.shtmlhttp://www.cisco.com/en/US/products/sw/voicesw/ps2237/products...
Please share your insights with regards to my issue.
Platforms:
CUCM
7.1.3.32900-4
Unity
4.2(1.0)
Thank you very much.
18 Replies 18
Hi Alex,
thanks for your response. Its a weird issue as the other neighbor voice network is not experiencing this issue.
I am not sure if this is related as I am a firewall expert by any means.But I see your network is full of Firewalls.
I had major problems with a CUCM cluter that was split up via JUNIPER firewalls.
I had major issues with conferencing and tranfers which was located by TAC to the JUNIPER running AVG which was spoofing skinny (SCCP) tcp port 2000.
http://kb.juniper.net/InfoCenter/index?page=content&id=KB18226&actp=search&viewlocale=en_US&searchid=1318116714197
unset alg sccp enable
Just ignore if you are not using JUNIPER
Alex
Regards, Alex. Please rate useful posts.
Hi acampbell
Thanks for the tip. I'm planning to upgrade the IOS from IPBASE to ADVIP hope it would make a change.
Thanks guys.
Hi guys still experiencing the issue. I'm unable to hear the voicemail upon transfer. Thank you very much.
Louis
