Product ID
Burney Rogers
How do I locate the procuct ID on 6.1 cisco communication manager? Is it the product ID the same as the serial number located in the front of the server?
phooghen
You have to be more specific.
What do you mean by product id ?
Are you trying to find the product id of the server itself or of the CUCM ?
If this is the server, somewhere on the server you should find something similar to MCS-78xx
But it depends of the server type (IBM, HP)
You can also access the CLI of your CUCM 6.1 by doing a SSH of the CUCM IP address.
Then you issue the "show hardware" command and will get:
admin:show hardware
HW Platform       : 7835H2
Processors        : 1
Type              : Intel(R) Xeon(R) CPU            5140  @ 2.33GHz
CPU Speed         : 2333
Memory            : 2048 MBytes
Object ID         : 1.3.6.1.4.1.9.1.584
OS Version        : UCOS 2.0.1.0-70
RAID Details      :
Smart Array P400 in Slot 1
    Logical Drive: 1
    Fault Tolerance: 1+0
    Heads: 255
    Sectors Per Track: 32
    Cylinders: 17562
    Stripe Size: 64 KB
    Status: Ok
    Array Accelerator: Enabled
    Has Data On Drive: True
    Unique Identifier: 600508B100104439535558355A500001
    Preferred Controller Chassis Slot: 1
this server is a MCS-7835H2 server (HP) with 2 GigRAM and 2 drives configured in RAID 1.
Hope this will help.
Sorry it me so long to respond, They are asking for the product ID for the
CUCM and Unity Connection.
Burney Rogers
Senior Voice Network Engineer
CSC
22270 Pacific Blvd. Sterling, VA 20166 | Suite 300
MSS Americas | office 571-250-2163 | mobile 703.623.3994 |
brogers22@csc.com
This is a PRIVATE message. If you are not the intended recipient, please
delete without copying and kindly advise us by e-mail of the mistake in
delivery. NOTE: Regardless of content, this e-mail shall not operate to
bind CSC to any order or other contract unless pursuant to explicit
written agreement or government initiative expressly permitting the use of
e-mail for such purpose.
phooghen
To:
Burney L Rogers/USA/CSC@CSC
Date:
08/04/2011 03:46 PM
Subject:
- Re: Product ID
Re: Product ID
created by phooghen in IP Telephony - View the full discussion
similar to MCS-78xx
address.
admin:show hardware
Processors : 1
CPU Speed : 2333
RAID Details :
Logical Drive: 1
Heads: 255
Cylinders: 17562
Stripe Size: 64 KB
Status: Ok
Reply to this message by going to Cisco Support Community
Start a new discussion in IP Telephony at Cisco Support Community
