Programming PSK/PLK using XML
HostedTrainer
Frequent Visitor
Frequent Visitor
I am STILL unable to find documentation or a clear answer on how to do this without someone asking "What CUCM? What version?" etc. Regardless of your provisioning software, the customized template CAN be pulled from the XML so CUCM is irrelevant.
This is a comment in the default XML for the 6851
<!-- Programmable Line Keys (PLK)
Note: Line Keys can be assigned as a
1) Extension/Multiple Line Appearance Key
2) Function Key
A) Speed Dial
Example)
fnc=sd;ext=*55@$PROXY;nme=Direct VM Transfer
B) BLF
C) Monitored Call Park
So it IS possible. Can someone please share with me where to make these changes in the XML and the syntax for them?
0 Replies 0
