Protocol application Invalid in cisco 7940 IP phone
aress1234
I am getting Protocol application Invalid in cisco 7940 IP phone . I am unable to enter the setting configuration by pressing the setting button.
When I power on the Cisco phone it immediately gives the error and I am not able to do any setting . I am also not able to telnet to Cisco 7940 Ip Phone. When I use telnet (IP address of Cisco 7940 IP phone)it gives error message "Could not open a connection to host: Connect failed".
gajolly
there r lot of bugs associated with this message so might need to check out the latest phone release avaialble for an upgrade.
joselo
Hello:
I had the same error.
My solution:
1.-Reset IP phone to factory defaults press the # key and hold ,then plugging in the CAT6 cable. When factory reset detected is displayed press 123456789*0# and choose NO to save network settings.
2.-Use a DHCP server Router in my case.
ip dhcp excluded-address 192.168.10.1 192.168.10.5
ip dhcp pool XYZ
network 192.168.10.0 255.255.255.248
default-router 192.168.10.1
option 150 ip 192.168.10.2 ….Callmanager
lease 10
3.-you can work with ip phone
ip phone : 192.168.10.6/29
JOSELITO
