11-07-2012 02:58 PM - edited 03-16-2019 02:04 PM
HI there, we have following policy map applied to ingress of one of our router LAN interface (connected to internal network), can someone explain how to interpreter the last line in the blue? thanks...
Class-map: Restrict-To-TOW-ACL-CM (match-any)
7317390 packets, 3457964496 bytes
30 second offered rate 55000 bps, drop rate 2000 bps
Match: access-group name Restrict-To-TOW-ACL
30 second rate 55000 bps
police:
cir 512000 bps, bc 16000 bytes
conformed 7276608 packets, 3401664053 bytes; actions: transmit
exceeded 41434 packets, 56467339 bytes; actions:drop
conformed 29000 bps, exceed 0 bps
Solved! Go to Solution.
11-07-2012 03:57 PM
Hi Roy,
police:
cir 512000 bps, bc 16000 bytes --- Policing Traffic @ 512Kbps
conformed 7276608 packets, 3401664053 bytes; actions: transmit -- Total packets and bytes conformed so far
exceeded 41434 packets, 56467339 bytes; actions:drop -- Total packets and bytes dropped so far
conformed 29000 bps, exceed 0 bps -- Current conformed rate of traffic, if no traffic is flowing this would be 0bps. This shows you have 29kbps conformed and 0 bps exceeding.
If there is no matching traffic going through router conform would be 0, altrenatively if there is congestion and packets are dropped you can see the exceed\drop also rises to non-zero value. Packets and bytes are cumulative, they keep on adding (you can get idea from history there were drops or not) but bps is the current rate of traffic flow at a time you are looking on cli or troubleshooting any issue.
Hope That Helps.
11-07-2012 03:57 PM
Hi Roy,
police:
Hope That Helps.
