08-12-2010 03:21 AM - edited 03-16-2019 12:12 AM
Hello Everyone,
This UC520 is working fine before I restart last week. After restarting the system, three of ip phones(7961) are not working.
It only show registration at the button of ip phone lcd screen. Today, I reset one of ip phone pressing 1-9*0# after power recycle.
After that 1) it shows MAC address of phone
2) ip address of phone, term61.default and upgrading
These two processing are keeping on running.
So, I used new ip phone(7940) and plugged in to that switch port. It runs with the following procedure,
Even I plugged in the new ip phone to live phone's switch port and did a testing, it also end up with TFTP time out.
I used the debug tftp packet and ephone register but no errors. Any idea?
Would be really appreciate for your help.
Solved! Go to Solution.
09-12-2010 09:35 PM
Check the dhcp ip address range for both excluded and included range.
Cheer!
Andrew
08-12-2010 04:34 AM
Try doing a factory reset for your IP Phone & check the TFTP IP address is correct and it has reachability..
Thanks..
08-12-2010 06:34 AM
I did factory reset but after that even cannot choose phone setting.
please read my first page again.
Sincerely,
09-12-2010 09:35 PM
Cheer!
Andrew
09-12-2010 10:03 PM
WOW..
After checking and changing the dhcp pool range, my ip phones are woking now.
I just reduced the excluded dhcp range.
Thank you so much Mr.Andrew.
Sincerely,
PK
