Reinstall Cisco 7911G phone firmware
tommy.theriault
I have 3 7911G Cisco phones that are unable to reset. I need to install «cmterm-7911_7906-sccp.9-1-1SR1» firmware.
I use tftpd32 and this is my setting (I tried 3 differents versions of the utility and 2 differents procedures for this):
https://supportforums.cisco.com/sites/default/files/attachments/discussion/config2.png
https://supportforums.cisco.com/sites/default/files/attachments/discussion/setting_0.png
I also tried 192.168.1.108 for the computer IP but that doesn't work. Same thing for checkbox: Ping addresse before assignation And Persistant leases. Checked or not, it doesn't work.
This is my Logs message:
Rcvd DHCP inform Msg for IP 192.168.1.1, Mac 00:50:FC:A9:D8:63 [27/01 11:43:33.645]
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:1C:58:F0:3F:CA [27/01 11:44:14.411]
Client requested address 0.0.68.0 [27/01 11:44:14.412]
no more address or address previously allocated by another server [27/01 11:44:14.412]
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:1C:58:F0:3F:CA [27/01 11:44:14.413]
Client requested address 0.0.68.0 [27/01 11:44:14.413]
no more address or address previously allocated by another server [27/01 11:44:14.413]
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:1C:58:F0:3F:CA [27/01 11:44:15.402]
Client requested address 0.0.68.0 [27/01 11:44:15.402]
no more address or address previously allocated by another server [27/01 11:44:15.402]
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:1C:58:F0:3F:CA [27/01 11:44:15.403]
Client requested address 0.0.68.0 [27/01 11:44:15.403]
no more address or address previously allocated by another server [27/01 11:44:15.403]
Rcvd DHCP inform Msg for IP 192.168.1.1, Mac 00:50:FC:A9:D8:63 [27/01 11:44:16.708]
Do you have an idea about what goes wrong?
Thank you.
Try binding the dhcp to the IP address 192.168.1.1 or deactivate the windows fw.
I tried and this is the log Viewer that I got.
For the Windows firewall, it is disable.
tommy.theriault
I need to precise that this is the only way I can reinstall a firmware to our 7911g phones because the reset proceedure broke the installed firmware.
UP
UP
