Remote user disconnect beep signal
apartyka
Hi Everybody!
Some of our users would like to hear an audible sound after remote end disconnects the call.
Is there any way achieving it without any third party applications (just CUCM)?
Thanks!
Jaime Valencia
Not AFAIK
java
if this helps, please rate
Java,
Thanks for reply. You confirmed my knowledge :-(
I thought that maybe there is kind of workaround.
It seems like is has to be done with a third party XML app. Maybe we could add it to a wishlist?
Adam
Submit a PER via your SE/AM along with the business case.
java
