02-07-2011 06:01 AM - edited 03-16-2019 03:18 AM
We have a UCM 7.5 install here. Recently we have seen a couple of RTMT alerts related to Media list
exhausted, based on a MOH audio source. However, RTMT is lacking ALOT of info when it comes to troubleshooting.
So, I am tring to run a report through the Bulk Admin -> Phones -> Generate Phone Reports to show me all the phones settings for the User Hold MOH Audio Source - but its not in the list.
I can report on the NETWORK MOH Audio source, but not the USER.
Does anyone have a way to generate a report that will show me the device name and USER MOH Settings? (Not on the line, but the device).
TIA!
Solved! Go to Solution.
02-07-2011 06:32 AM
Don,
To get details of just the phones you could to an Bulk>Export>Phones>All Details
Other than that it is possible to do an SQL query, run this on the CLI of your CUCM and it will list all devices, the GUID of the MGRL and the audio file numbers.
run sql select name,fkmediaresourcelist,networkholdmohaudiosourceid,userholdmohaudiosourceid from device
Give you an output like:-
SEP001DA2674A00 70d9ea77-5cc5-478c-915f-b282db0bad35 1 1
SEPACA016FCE3AA 9dcb9fc5-6d4e-4662-9dbc-32f8539a7481 NULL NULL
As I guess your only looking for missing items I haven't cross referenced the tables to get meaningful names.
Craig
PLEASE RATE HELPFUL POSTS
02-07-2011 07:12 AM
You can do the following :
Line :
run sql select dnorpattern, userholdmohaudiosourceid, networkholdmohaudiosourceid from numplan
Device :
run sql select name, userholdmohaudiosourceid, networkholdmohaudiosourceid from device
Common Device Config :
run sql select pkid, holdpartyuserholdmohaudiosourceid, holdpartynetworkholdmohaudiosourceid from commondeviceconfig
Copy these ouptuts into a text file, rename it to .csv, and then sort based on 'userholdmohaudiosourceid' and 'networkholdmohaudiosourceid' columns separately. From the CCM admin page, you can see the list of MOH audiosourceid's available of your system. Looking at the csv files, you should be able to confirm which entities on the system are referencing a MOH audiosourceid which doesn't exist in the system.
- Sriram
Please rate helpful posts !
02-07-2011 06:28 AM
You can use sql queries to find out which devices are using a particular MOH audio source :
Order of preference (descending) :
Line
Device
Service Parameter
Let's say you want to find out where MOH audiosourceid is used in the system :
Line :
run sql select dnorpattern from numplan where userholdmohaudiosourceid = '2'
run sql select dnorpattern from numplan where networkholdmohaudiosourceid = '2'
Device :
run sql select name from device where userholdmohaudiosourceid = '2'
run sql select name from device where networkholdmohaudiosourceid = '2'
run sql select pkid from commondeviceconfig where holdpartyuserholdmohaudiosourceid = '2'
run sql select pkid from commondeviceconfig where holdpartynetworkholdmohaudiosourceid = '2'
Service Parameters
- Default User Hold MOH Audio source
- Default Network Hold MOH Audio source
In your case, if you are looking for only devices using MOH audiosourceid 'x' on the device config page, you would run :
run sql select name from device where userholdmohaudiosourceid = 'x'
- Sriram
02-07-2011 06:34 AM
Sriram,
You beat me there. 5*
Have a good day,
Craig
02-07-2011 07:05 AM
thanks for the sql tips. Ill try to modify those to my needs - the problem isnt what phones are assigned to a particular MOH Source, but rather, which one
s are assigned to one that does NOT exist?.
02-07-2011 07:12 AM
Line :
Device :
- Sriram
02-07-2011 06:32 AM
Don,
Craig
