11-18-2014 02:05 AM - edited 03-17-2019 12:59 AM
I have 2 cisco 1760 routers with FXS and FXO card installed in each. I have to transport 2 PSTN lines from Head Office to remote loaction using FXS and FXO cards and these lines will be used for voice calls and FAX( one line each for FAX and voice). I have configured the router for voice lines and it is working fine. Now I am using the same config for running fax machine but it is not working. Can anyone help me out how to configure FAX in this scenario also if anyone can share any sample config. I am attaching my config for both routers. Right now both routers are connected with a cross-over cable for lab test but we will connect them later using satellite connection.
HO Router (FXO card)
Current configuration : 1718 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
voice-card 2
voice-card 3
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip domain lookup
no ftp-server write-enable
voice class codec 10
interface FastEthernet0/0
ip address 10.10.10.1 255.255.255.248
speed auto
h323-gateway voip bind srcaddr 10.10.10.1
ip classless
no ip http server
control-plane
voice-port 2/0
output attenuation 0
echo-cancel coverage 32
no vad
no comfort-noise
timeouts interdigit 3
timeouts call-disconnect 3
connection plar opx 2001
description Remote PSTN#:35296913
music-threshold -70
voice-port 2/1
no vad
no comfort-noise
connection plar opx 2002
description Remote PSTN#:35296914
music-threshold -70
voice-port 3/0
voice-port 3/1
dial-peer voice 2000 voip
destination-pattern 200.
no modem passthrough
voice-class codec 10
session target ipv4:10.10.10.2
incoming called-number .
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
fax-relay ecm disable
fax rate 7200
fax nsf 000000
no vad
dial-peer voice 1321 pots
description line 1
huntstop
destination-pattern 1321
port 2/0
dial-peer voice 1322 pots
description line 2
huntstop
destination-pattern 1322
port 2/1
line con 0
password cisco
line aux 0
line vty 0 4
password cisco
login
end
Remote Router (FXS Card):
version 12.3
hostname Router
boot-start-marker
boot-end-marker
no mmi pvc
voice-card 2
voice-card 3
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip address 10.10.10.2 255.255.255.248
speed auto
h323-gateway voip bind srcaddr 10.10.10.2
interface Ethernet1/0
no ip address
shutdown
half-duplex
ip classless
no ip http server
control-plane
voice-port 2/0
description PSTN#:
voice-port 2/1
description PSTN#:
voice-port 3/0
voice-port 3/1
dial-peer voice 2001 pots
description Remote
huntstop
destination-pattern 2001
port 2/0
dial-peer voice 2002 pots
description Remote
huntstop
destination-pattern 2002
port 2/1
dial-peer voice 1320 voip
destination-pattern 132.
session target ipv4:10.10.10.1
fax rate 7200
fax nsf 000000
no vad
line con 0
password cisco
line aux 0
line vty 0 4
password cisco
login
end
11-18-2014 04:34 AM
we are running fax machine on one of our remote site on fxs port but the outbound line is sip,
so i think it is not much helpful to share my full config... but i am giving the fxs port config pretty much same as yours, but the ext number you assigned to fax machine might causing the issue,
try to provide the full number instead of extension
dial-peer voice 100 pots
description " local Inbound Fax"
destination-pattern XXXXXXX
port 0/2/0
dial-peer voice 103 voip
description (for incoming FAX)
voice-class codec 1
fax-relay sg3-to-g3
no vad
for out bound faxes it uses the dial-peers configured for voice calls...
11-19-2014 10:50 AM
I have tried my config by connecting routers with cross-over cable in lab and fax works perfect. Now trying on satellite link but it is not working(latency is approximately 1200 ms). My local ISP' has blocked voice ports so unable to check fax on normal internet . Someone told me to use SIP configuration and it will work. It will be helpful if anyone can share SIP configuration for this scenario. Also let me know if there is any way I can defined ports for target IP's in my current configuration?
I tried your suggested config but was unable to execute command fax-relay sg3-to-g3 on my router. Kindly share your suggestions to resolve this issue.
11-20-2014 04:17 AM
if thats working in your lab, then it should work with your voice lines also, if not please speak to your telco,there is no difference in voice and fax lines
i suggest you to upgrade your router firmware to work the sg3 fax command
collect the debugs when the fax call fails
#debug voice ccapi inout
i think you should have sip line to work the sip configuration, anyway i am giving the sip conf here
dial-peer voice 9 voip
description "local Inbound Fax"
session protocol sipv2
session target ipv4:xxx.xxx.xxx.xxx
incoming called-number [fax number]
voice-class sip bind control source-interface FastEthernet0/0
voice-class sip bind media source-interface FastEthernet0/0
codec g711alaw
no vad
dial-peer voice 10 voip
description ***Out Going***
translation-profile outgoing OUT-SIP
destination-pattern .T
progress_ind progress enable 8
rtp payload-type nte 98
session target ipv4:xxx.xxx.xxx.xxx:5060
session transport udp
voice-class codec 1
dtmf-relay rtp-nte
no vad
define voice calss codecs before applying to dial-peers
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
define appropriate translation-rules and translation-profile accordingly
11-20-2014 08:58 AM
Many thanks for your continuous support. Today I have made a little change in previous configuration and has enabled following command on both FXS and FXO. This time my FXO card router is on fiber while FXS card router is on VSAT internet link. I am now able to receive fax on my fax machine connected to router but still unable to send fax.
modem passthrough nse codec g711ulaw
fax rate disable
Can you share config to use T.38 Fax relay? During fax call on checking voice call status it shows voice call but we receive error on fax machines like no fax detected, busy, no answer e.t.c
