Security error
Siva chinap
Level 7
Level 7
Befor applying license i am able to synchronize to the instances,once i uploaded license file to ELM i am facing the security error?
20 Replies 20
Hi Aman,
Due to NTP the problem occurs,i have configure exact Date & time in VG ,once it synchronize it will not through security error
Hi ,
It is a learning.
[+5] to you.
regds,
aman
I know this is an old post.  What ended up being the fix?  I'm having the exact same problem.
Huth,
Due to NTP the problem occurs,i have configure exact Date & time in VG ,once it synchronize it will not through security error.
John Huthmaker
Level 7
Level 7
Sometimes you miss obvious things.  I found the solution.  Although everything was pointing to my NTP, my NTP reference's date was off.
Hath,
I didn't configured Ntp that time,when i configured  issue was resolved,in your case reference date,so you mean to tell that because of reference date settings.
