Silent ringing from PSTN
willsupport
Hi all,
my customer asked me the following:
- He wants to mute the phone ring for the PSTN calls only. When a user do a internal call, the destination phone must ring with volume.
How can i do this?
Alessandro
Jaime Valencia
You'd need one line with the PSTN number and one line with the internal number for that.
You either configure a blank ringtone or set DND on the PSTN line, and leave the internal one to ring.
java
if this helps, please rate
Jaime Valencia
java
Thanks Jaime,
i will update the post after tests
Alessandro
Jinto Alakkal
Hi Alessandro,
Unfortunately there is no option in CUCM that I am aware of which we can configure based on on net/off net calls as Jaime suggested you can have two lines.
Jinto.
