sip 2.0 487 request cancelled ; Sip outoing call issue on CUBE
mohsin majeed
Level 2
Level 2
i am facing issue while dialing outside to a particular number but for other number it works well. Voice routing (Route pattern and Dial peer) is same for both success and unsuccessful call as attached
- Success Call to 4193193 (7digits) ; prefix already dicard as predot on CM. Calling number 2122902
- Unsuccessful Call to 4945316 (7digits) ; prefix already dicard as predot on CM. Calling number 2122902
Routepattern on CM is 011.[245678]XXXXXX where 011 discard on CM as mentioned
I can see sip 2.0 487 request cancelled message in unsuccessful call, didn't understand the reason.
Please find attached debugs: ccsip messages , ccapi voip inout , voip dialpeer inout
Sh run is also attached.
13 Replies 13
Invite is sent to other call leg from Gateway at 09:35:37.722 and after similar SIP signalling like successful call, there is a normal call disconnect received from CUCM at 09:35:49.554 [which is after 12 secs] withReason: Q.850;cause=16. Check below
Aug 15 09:35:37.722: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4945316@10.201.20.49:5060 SIP/2.0
Via: SIP/2.0/UDP 10.196.187.22:5060;branch=z9hG4bK4BE5DC1B9A
Remote-Party-ID: "Voice Eng Mohsin Majeed" <sip:2122902@10.196.187.22>;party=calling;screen=yes;privacy=off
From: "Voice Eng Mohsin Majeed" <sip:2122902@10.30.2.254>;tag=8EF4EC30-26DC
To: <sip:4945316@10.201.20.49>
Date: Tue, 15 Aug 2017 09:35:37 GMT
Call-ID: EDFAE833-80D311E7-844DB20C-BB639F8E@10.196.187.22
Aug 15 09:35:49.554: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:4945316@10.30.2.254:5060 SIP/2.0
Date: Tue, 15 Aug 2017 09:34:22 GMT
From: "Voice Eng Mohsin Majeed" <sip:2122902@10.30.16.10>;tag=87a6d10a-20b7-4ed4-b52f-40f63d01f911-24321532
Content-Length: 0
To: <sip:4945316@10.30.2.254>
Call-ID: ea0ae880-9921c01e-1866c1-a101e0a@10.30.16.10
Via: SIP/2.0/TCP 10.30.16.10:5060;branch=z9hG4bK1c1c703b4c0a7c
CSeq: 101 CANCEL
Max-Forwards: 70
Aug 15 09:35:49.554: //6609854/EDFA4B728447/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x1D57F94, Call Id=6609854
In order to figure which hop is sending the disconnect, kindly make another test call and do not disconnect the call manually, let it get disconnected automatically and collect the traces.
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Hi Abhay,
Thanks for your analysis, i will share as you suggested tomorrow during office hours.
What i noticed, after some progress call disconnect by CM announcement "Call cannot be completed as dialed". But for more understanding i will share debugs next working day.
Configure CUCM to send PRACK by setting the SIP Rel1xx Options drop down to 'Send PRACK for all 1xx messages'. As if now the CUBE is expecting a PRACK to be sent from CUCM, after sending 183 Session Progress. It does not receive it and hence sends 504 Server Time-out after 2 minutes and 8 seconds from the Initial invite.
Aug 16 09:48:57.134: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 504 Server Time-out
Via: SIP/2.0/UDP 10.196.187.22:5060;branch=z9hG4bK4BEED61F10
Record-Route: <sip:10.201.20.49:5060;transport=udp;lr>
Call-ID: A9164F28-819E11E7-A3C8B20C-BB639F8E@10.196.187.22
From: "Voice Eng Mohsin Majeed"<sip:2122902@10.30.2.254>;tag=94258ACC-DC6
To: <sip:4945316@10.201.20.49>;tag=sbc0807ueaheubc-CC-38
CSeq: 101 INVITE
Reason: Q.850;cause=102;text="recovery of timer expiry"
Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR"
Content-Length: 0
Abhay
Abhay Singh Reyal
i am using CUCM version 7.X and can't find this option in CUCM under sip profile. Is there any other way.
In CUCM version 7 it must be under the CUCM Service Parameters for the Cisco CallManager service, there will a field called SIP Rel1XX Enabled. Change it there and see if it makes any difference.
Abhay
Abhay Singh Reyal
I selected this option in service parameter and saved. I noticed, even it is selected but in suggested value it shows disabled. See attached
No success as well for call
Collect the debugs for this call now as you have changed the service parameter. Now we need to see what happens after CUCM sends PRACK. Now there should be a difference. Also reset the trunk. Do it in the same way as collected last time without disconnecting the call own your own and let it get disconnected. Also attach the file in the post rather than posting it here.
Abhay
Abhay Singh Reyal
calling and called number are same. Also the call behaviour is the same.
New debug is attached,
As per the debugs, now it is evident that CUCM sends PRACK in response to the the 183 session progress message. CUBE then receives 504 Server Time-out from the ITSP after 1 min and 52 secs from the initial invite
Aug 17 08:49:32.197: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.196.187.22:5060;branch=z9hG4bK4BF6231967
Call-ID: 867400A7-825F11E7-BA7DB20C-BB639F8E@10.196.187.22
From: "Voice Eng Mohsin Majeed"<sip:2122902@10.30.2.254>;tag=99158164-20E1
To: <sip:4945316@10.201.20.49>;tag=sbc0802dpekh2fh-CC-33
CSeq: 101 INVITE
Content-Length: 0
Can you raise this concern with ITSP and check why are they sending this Server Time-out message? Is there anything that they are expecting. As per the signalling all the messages have been exchanged.
Abhay
Abhay Singh Reyal
Thanks for your deep analysis,
Sure, i will engage ITSP to check as suggested and will update
Hi Abhay,
As checked more the number 4945316 itself is not active number. Call was failing by playing the cisco announcement "Call can't be completed as dialed'' . So, i suspect this could be the issue from CM.
But later on tested from my Mobile it plays the same announcemnet, i hope the issue is far end PBX.
Thanks for your help
I tested unsuccessful call today as ; called number 4945316, calling number 2122902
- After some process it play Announcement 3 times like "You're call cant be completed as dialed,......bla bla"
- After last announcement it wait almost 15 seconds and give fast busy signal for almost 15 to 20 seconds
- Then there is silence of almost 30 seconds and then busy tone again for 15 seconds
- Then disconnect
file was not being attached, so plz find below debugs
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2017.08.16 12:46:14 =~=~=~=~=~=~=~=~=~=~=~=
de    ebug voi   ccsip mess
RIY.EX17.DC.DR.01#debug ccsip messages
SIP Call messages tracing is enabled
RIY.EX17.DC.DR.01#debug voip dialpe
RIY.EX17.DC.DR.01#debug voip dialpeer inou
RIY.EX17.DC.DR.01#debug voip dialpeer inout
voip dialpeer inout debugging is on
RIY.EX17.DC.DR.01#debug voip ccap
RIY.EX17.DC.DR.01#debug voip ccapi inou
RIY.EX17.DC.DR.01#debug voip ccapi inout
voip ccapi inout debugging is on
RIY.EX17.DC.DR.01#
RIY.EX17.DC.DR.01#
RIY.EX17.DC.DR.01#ter mon
RIY.EX17.DC.DR.01#
Aug 16 09:46:49.967: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4945316@10.30.2.254:5060 SIP/2.0
Date: Wed, 16 Aug 2017 09:45:34 GMT
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: "Voice Eng Mohsin Majeed" <sip:2122902@10.30.16.10>;tag=87a6d10a-20b7-4ed4-b52f-40f63d01f911-24329849
Allow-Events: presence
P-Asserted-Identity: "Voice Eng Mohsin Majeed" <sip:2122902@10.30.16.10>
Supported: timer,resource-priority,replaces
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Min-SE:  1800
Remote-Party-ID: "Voice Eng Mohsin Majeed" <sip:2122902@10.30.16.10>;party=calling;screen=yes;privacy=off
Content-Length: 210
User-Agent: Cisco-CUCM7.1
Contact: <sip:2122902@10.30.16.10:5060;transport=tcp>
Expires: 180
Content-Type: application/sdp
Call-ID: a4ffb880-9941143e-1868bf-a101e0a@10.30.16.10
Via: SIP/2.0/TCP 10.30.16.10:5060;branch=z9hG4bK1c20673ef38c19
CSeq: 101 INVITE
Session-Expires:  1800
Max-Forwards: 70
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 10.30.16.10
s=SIP Call
c=IN IP4 10.30.16.11
t=0 0
m=audio 27408 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Aug 16 09:46:49.967: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=4945316, Called Number=4945316, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=4945316
   Result=Success(0) after DP_MATCH_DEST
Aug 16 09:46:49.967: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=4945316, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Aug 16 09:46:49.967: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=220
Aug 16 09:46:49.967: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2122902, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ANSWER; Incoming Dial-peer=2
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Aug 16 09:46:49.967: //-1/A915B300A3C2/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2122902, Called Number=4945316, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=5000
Aug 16 09:46:49.967: //-1/A915B300A3C2/DPM/dpMatchSafModulePlugin:
Aug 16 09:46:49.967: //6613054/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
Aug 16 09:46:49.967: //-1/A915B300A3C2/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=2122902
   ----- ccCallInfo IE subfields -----
   cisco-ani=2122902
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=4945316
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Aug 16 09:46:49.967: //-1/A915B300A3C2/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x1D57F94, Call Info(
   Calling Number=2122902,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=4945316(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=5000, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=6613054
Aug 16 09:46:49.967: //-1/A915B300A3C2/CCAPI/ccCheckClipClir:
   In: Calling Number=2122902(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=2122902(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Aug 16 09:46:49.967: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 16 09:46:49.967: :cc_get_feature_vsa malloc success
Aug 16 09:46:49.967:  cc_get_feature_vsa count is 8
Aug 16 09:46:49.967: :FEATURE_VSA attributes are: feature_name:0,feature_time:362410024,feature_id:6161582
Aug 16 09:46:49.967: //6613054/A915B300A3C2/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=2122902(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=4945316(TON=Unknown, NPI=Unknown))
Aug 16 09:46:49.967: //6613054/A915B300A3C2/CCAPI/cc_process_call_setup_ind:
   Event=0x1FB5068
Aug 16 09:46:49.967: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 4945316
Aug 16 09:46:49.967: //6613054/A915B300A3C2/CCAPI/ccCallSetContext:
   Context=0x11E21C80
   >>>>CCAPI handed cid 6613054 with tag 5000 to app "_ManagedAppProcess_Default"
Aug 16 09:46:49.967: //6613054/A915B300A3C2/CCAPI/ccCallProceeding:
Aug 16 09:46:49.967: //-1/A915B300A3C2/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=4945316, Peer Info Type=DIALPEER_INFO_SPEECH
   dialstring=4945316, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Aug 16 09:46:49.967: //-1/A915B300A3C2/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Result=SUCCESS(0)
   Calling Number=4945316, Called Number=, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=220
   Result=SUCCESS(0)
Aug 16 09:46:49.971: //-1/A915B300A3C2/DPM/dpMatchPeersCore:
Aug 16 09:46:49.971: //-1/A915B300A3C2/DPM/dpMatchSafModulePlugin:
Aug 16 09:46:49.971: //-1/A915B300A3C2/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Aug 16 09:46:49.971: //6613054/A915B300A3C2/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=220, Params=0x15656BC4, Progress Indication=NULL(0)
Aug 16 09:46:49.971: //6613054/A915B300A3C2/CCAPI/ccCheckClipClir:
   Destination Pattern=[24678]......, Called Number=4945316, Digit Strip=FALSE
   Redirect Number=, Display Info=Voice Eng Mohsin Majeed
   Account Number=2122902, Final Destination Flag=TRUE,
   Guid=A915B300-819E-11E7-A3C2-B20CBB639F8E, Outgoing Dial-peer=220
Aug 16 09:46:49.971: //6613054/A915B300A3C2/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=2122902
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=4945316
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Aug 16 09:46:49.971: //6613054/A915B300A3C2/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x1D57F94, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=2122902,(Calling Name=Voice Eng Mohsin Majeed)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=4945316(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=220, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Aug 16 09:46:49.971: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 16 09:46:49.971: :cc_get_feature_vsa malloc success
Aug 16 09:46:49.971:  cc_get_feature_vsa count is 9
Aug 16 09:46:49.971: :FEATURE_VSA attributes are: feature_name:0,feature_time:362397256,feature_id:6161583
Aug 16 09:46:49.971: //6613055/A915B300A3C2/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Aug 16 09:46:49.971: //6613055/A915B300A3C2/CCAPI/ccCallSetContext:
   Context=0x15656B74
Aug 16 09:46:49.971: //6613054/A915B300A3C2/CCAPI/ccSaveDialpeerTag:
Aug 16 09:46:49.971: //6613055/A915B300A3C2/CCAPI/cc_api_call_proceeding:
   Interface=0x1D57F94, Progress Indication=NULL(0)
Aug 16 09:46:49.971: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
From: "Voice Eng Mohsin Majeed" <sip:2122902@10.30.2.254>;tag=94258ACC-DC6
Date: Wed, 16 Aug 2017 09:46:49 GMT
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2836771584-2174620135-2747445772-3143868302
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1502876809
Contact: <sip:2122902@10.196.187.22:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 273
v=0
o=CiscoSystemsSIP-GW-UserAgent 807 4778 IN IP4 10.196.187.22
s=SIP Call
c=IN IP4 10.196.187.22
t=0 0
m=audio 27822 RTP/AVP 8 101 19
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Aug 16 09:46:49.975: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Aug 16 09:46:57.159: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Contact: <sip:4945316@10.201.20.49:5060;user=phone>
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Require: 100rel
RSeq: 1
Content-Length: 193
v=0
o=- 55303063 55303063 IN IP4 10.201.20.49
s=SBC call
c=IN IP4 10.201.20.49
t=0 0
m=audio 42276 RTP/AVP 8 101
a=fmtp:101 0-15
Aug 16 09:46:57.159: //6613055/A915B300A3C2/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=6613055,
   Caps(Codec=0x2, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Aug 16 09:46:57.159: //6613054/A915B300A3C2/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=6613054,
   Caps(Codec=g711alaw(0x2), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
Aug 16 09:46:57.159: //6613055/A915B300A3C2/CCAPI/cc_api_event_indication:
   Event=156, Call Id=6613055
   Event Is Sent To Conferenced SPI(s) Directly
Aug 16 09:46:57.159: //6613055/A915B300A3C2/CCAPI/cc_api_call_alert:
   Interface=0x1D57F94, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Aug 16 09:46:57.159: //6613054/A915B300A3C2/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Aug 16 09:46:57.159: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2122902, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2122902
Aug 16 09:46:57.159: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 16 09:46:57.159: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=11
     2: Dial-peer Tag=10
     3: Dial-peer Tag=220
Aug 16 09:46:57.159: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Aug 16 09:46:57.159: //6613054/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x1596E994, callID1=0x64E83E, callID2=0x64E83F, tag=0x0)
   (confID=0x1596E994, callID1=0x64E83E, gcid=A915B300-819E11E7-A3C5B20C-BB639F8E, tag=0x0)
Aug 16 09:46:57.159: //6613055/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x1596E994, callID2=0x64E83F, gcid=A915B300-819E11E7-A3C5B20C-BB639F8E, tag=0x0)
Aug 16 09:46:57.159: //6613054/A915B300A3C2/CCAPI/ccConferenceCreate:
   Conference Id=0x1596E994, Call Id1=6613054, Call Id2=6613055, Tag=0x0
Aug 16 09:46:57.159: ccConferenceCreate: ret1=0, codecMask1=2, bytes1=160, negot1=1, dtmf1=6
                    ret2=0, codecMask2=2, bytes2=160, negot2=1, dtmf2=6,
                    tx_dynamic_pt1=8, rx_dynamic_pt1=8, codec_mode1=0, params_bitmap1 =0
                    tx_dynamic_pt2=8, rx_dynamic_pt2=8, codec_mode2=0, params_bitmap2 =0
   delay media to slow start case, codec negotation is not done
Aug 16 09:46:57.159: //6613054/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 16 09:46:57.159: cc_api_get_xcode_stream : 4534
Aug 16 09:46:57.159: //6613054/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C1, Source Interface=0x1D57F94, Source Call Id=6613054,
   Destination Call Id=6613055, Disposition=0x0, Tag=0x0
Aug 16 09:46:57.159: //6613055/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 16 09:46:57.159: //6613055/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C1, Source Interface=0x1D57F94, Source Call Id=6613055,
   Destination Call Id=6613054, Disposition=0x0, Tag=0x0
Aug 16 09:46:57.159: //6613054/A915B300A3C2/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x2BC8C1, Destination Call Id=6613055)
Aug 16 09:46:57.159: //6613055/A915B300A3C2/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2BC8C1, Destination Call Id=6613054)
Aug 16 09:46:57.159: //6613054/A915B300A3C2/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2BC8C1, Call Id1=6613054, Call Id2=6613055
Sent:
PRACK sip:4945316@10.201.20.49:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.196.187.22:5060;branch=z9hG4bK4BEED7516
CSeq: 102 PRACK
RAck: 1 101 INVITE
Max-Forwards: 70
Content-Length: 0
Aug 16 09:46:57.163: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <sip:4945316@10.30.2.254>;tag=9425A6E0-D93
CSeq: 101 INVITE
Remote-Party-ID: <sip:4945316@10.30.2.254>;party=called;screen=no;privacy=off
Contact: <sip:4945316@10.30.2.254:5060;transport=tcp>
Supported: sdp-anat
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 6219 3230 IN IP4 10.30.2.254
s=SIP Call
c=IN IP4 10.30.2.254
t=0 0
m=audio 23480 RTP/AVP 8 101
a=fmtp:101 0-16
a=ptime:20
Aug 16 09:46:57.195: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
Aug 16 09:47:24.195: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4409410@10.30.2.254:5060 SIP/2.0
Date: Wed, 16 Aug 2017 09:46:08 GMT
From: "Ali Al-Qahtani Accountant" <sip:2122537@10.30.16.10>;tag=87a6d10a-20b7-4ed4-b52f-40f63d01f911-24329866
P-Asserted-Identity: "Ali Al-Qahtani Accountant" <sip:2122537@10.30.16.10>
Min-SE:  1800
Remote-Party-ID: "Ali Al-Qahtani Accountant" <sip:2122537@10.30.16.10>;party=calling;screen=yes;privacy=off
Content-Length: 210
To: <sip:4409410@10.30.2.254>
Contact: <sip:2122537@10.30.16.10:5060;transport=tcp>
Expires: 180
Call-ID: b943b580-99411460-1868c0-a101e0a@10.30.16.10
Via: SIP/2.0/TCP 10.30.16.10:5060;branch=z9hG4bK1c2068373b6a60
CSeq: 101 INVITE
Max-Forwards: 70
v=0
s=SIP Call
c=IN IP4 10.30.16.10
t=0 0
m=audio 29062 RTP/AVP 8 101
a=ptime:20
a=fmtp:101 0-15
Aug 16 09:47:24.195: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=4409410, Called Number=4409410, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=4409410
Aug 16 09:47:24.195: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=4409410, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Aug 16 09:47:24.195: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Aug 16 09:47:24.195: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2122537, Called Number=, Voice-Interface=0x0,
Aug 16 09:47:24.195: //-1/BD7C6C31A3C9/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2122537, Called Number=4409410, Voice-Interface=0x0,
Aug 16 09:47:24.195: //-1/BD7C6C31A3C9/DPM/dpMatchSafModulePlugin:
Aug 16 09:47:24.199: //6613056/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Aug 16 09:47:24.199: //-1/BD7C6C31A3C9/CCAPI/cc_api_display_ie_subfields:
   cisco-username=2122537
   cisco-ani=2122537
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=4409410
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Aug 16 09:47:24.199: //-1/BD7C6C31A3C9/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=2122537,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=4409410(TON=Unknown, NPI=Unknown),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=6613056
Aug 16 09:47:24.199: //-1/BD7C6C31A3C9/CCAPI/ccCheckClipClir:
   In: Calling Number=2122537(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=2122537(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Aug 16 09:47:24.199: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 16 09:47:24.199: :cc_get_feature_vsa malloc success
Aug 16 09:47:24.199:  cc_get_feature_vsa count is 10
Aug 16 09:47:24.199: :FEATURE_VSA attributes are: feature_name:0,feature_time:362409800,feature_id:6161584
Aug 16 09:47:24.199: //6613056/BD7C6C31A3C9/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=2122537(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=4409410(TON=Unknown, NPI=Unknown))
Aug 16 09:47:24.199: //6613056/BD7C6C31A3C9/CCAPI/cc_process_call_setup_ind:
   Event=0x1FB5068
Aug 16 09:47:24.199: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 4409410
Aug 16 09:47:24.199: //6613056/BD7C6C31A3C9/CCAPI/ccCallSetContext:
   Context=0x157C35E8
   >>>>CCAPI handed cid 6613056 with tag 5000 to app "_ManagedAppProcess_Default"
Aug 16 09:47:24.199: //6613056/BD7C6C31A3C9/CCAPI/ccCallProceeding:
Aug 16 09:47:24.199: //-1/BD7C6C31A3C9/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=4409410, Peer Info Type=DIALPEER_INFO_SPEECH
Aug 16 09:47:24.199: //-1/BD7C6C31A3C9/DPM/dpMatchSafModulePlugin:
   dialstring=4409410, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Aug 16 09:47:24.199: //-1/BD7C6C31A3C9/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Aug 16 09:47:24.199: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 16 09:47:24.199: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 16 09:47:24.199: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Aug 16 09:47:24.199: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=4409410, Called Number=, Voice-Interface=0x0,
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Aug 16 09:47:24.199: //6613056/BD7C6C31A3C9/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=220, Params=0x1565B7E4, Progress Indication=NULL(0)
Aug 16 09:47:24.199: //6613056/BD7C6C31A3C9/CCAPI/ccCheckClipClir:
   Destination Pattern=[24678]......, Called Number=4409410, Digit Strip=FALSE
   Redirect Number=, Display Info=Ali Al-Qahtani Accountant
   Account Number=2122537, Final Destination Flag=TRUE,
   Guid=BD7C6C31-819E-11E7-A3C9-B20CBB639F8E, Outgoing Dial-peer=220
Aug 16 09:47:24.199: //6613056/BD7C6C31A3C9/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=2122537
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=4409410
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Aug 16 09:47:24.199: //6613056/BD7C6C31A3C9/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=2122537,(Calling Name=Ali Al-Qahtani Accountant)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=4409410(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Aug 16 09:47:24.199:  cc_get_feature_vsa count is 11
Aug 16 09:47:24.199: :FEATURE_VSA attributes are: feature_name:0,feature_time:362395688,feature_id:6161585
Aug 16 09:47:24.199: //6613057/BD7C6C31A3C9/CCAPI/ccIFCallSetupRequestPrivate:
Aug 16 09:47:24.199: //6613057/BD7C6C31A3C9/CCAPI/ccCallSetContext:
   Context=0x1565B794
Aug 16 09:47:24.199: //6613056/BD7C6C31A3C9/CCAPI/ccSaveDialpeerTag:
Aug 16 09:47:24.203: //6613057/BD7C6C31A3C9/CCAPI/cc_api_call_proceeding:
Aug 16 09:47:24.203: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4409410@10.201.20.49:5060 SIP/2.0
Via: SIP/2.0/UDP 10.196.187.22:5060;branch=z9hG4bK4BEED8FDD
Remote-Party-ID: "Ali Al-Qahtani Accountant" <sip:2122537@10.196.187.22>;party=calling;screen=yes;privacy=off
From: "Ali Al-Qahtani Accountant" <sip:2122537@10.30.2.254>;tag=94261084-25E0
To: <sip:4409410@10.201.20.49>
Date: Wed, 16 Aug 2017 09:47:24 GMT
Call-ID: BD7D08F1-819E11E7-A3CFB20C-BB639F8E@10.196.187.22
Min-SE:  1800
Cisco-Guid: 3179047985-2174620135-2747904524-3143868302
CSeq: 101 INVITE
Timestamp: 1502876844
Contact: <sip:2122537@10.196.187.22:5060>
Expires: 180
Max-Forwards: 69
Content-Length: 274
v=0
o=CiscoSystemsSIP-GW-UserAgent 3290 5493 IN IP4 10.196.187.22
s=SIP Call
t=0 0
m=audio 16384 RTP/AVP 8 101 19
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Aug 16 09:47:24.207: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
From: "Ali Al-Qahtani Accountant"<sip:2122537@10.30.2.254>;tag=94261084-25E0
CSeq: 101 INVITE
Content-Length: 0
Aug 16 09:47:24.211: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x1E93ED4, Interface Type=9, Destination=0.0.0.0, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
Aug 16 09:47:24.211: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 16 09:47:24.211: :cc_get_feature_vsa malloc success
Aug 16 09:47:24.211:  cc_get_feature_vsa count is 12
Aug 16 09:47:24.211: :FEATURE_VSA attributes are: feature_name:0,feature_time:362405544,feature_id:6161586
Aug 16 09:47:24.211: //6613058/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
Aug 16 09:47:24.211: //6613058/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x11A6DBC0
   Interface=0x1ADD53C, Interface Type=25, Destination=, Mode=0x0,
Aug 16 09:47:24.211:  cc_get_feature_vsa count is 13
Aug 16 09:47:24.211: :FEATURE_VSA attributes are: feature_name:0,feature_time:362409576,feature_id:6161587
Aug 16 09:47:24.211: //6613059/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Interface=0x1ADD53C, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Aug 16 09:47:24.211: //6613059/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=25, FlowMode=1
Aug 16 09:47:24.211: //6613059/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x11A6D7C0
Aug 16 09:47:24.215: //6613058/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Interface=0x1E93ED4, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
Aug 16 09:47:24.215: //6613059/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x143C0DF8, callID1=0x64E843, callID2=0x64E842, tag=0x0)
   (confID=0x143C0DF8, callID1=0x64E843, gcid=0-0-0-0, tag=0x0)
Aug 16 09:47:24.215: //6613058/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x143C0DF8, callID2=0x64E842, gcid=0-0-0-0, tag=0x0)
   Conference Id=0x143C0DF8, Call Id1=6613059, Call Id2=6613058, Tag=0x0
Aug 16 09:47:24.215: //6613059/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C2, Source Interface=0x1ADD53C, Source Call Id=6613059,
   Destination Call Id=6613058, Disposition=0x0, Tag=0x0
Aug 16 09:47:24.215: //6613058/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C2, Source Interface=0x1E93ED4, Source Call Id=6613058,
   Destination Call Id=6613059, Disposition=0x0, Tag=0x0
Aug 16 09:47:24.215: //6613059/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x2BC8C2, Destination Call Id=6613058)
   Call Entry(Conference Id=0x2BC8C2, Destination Call Id=6613059)
Aug 16 09:47:24.215: //6613058/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x0, Params=0x143C08C0, Call Id=6613058
Aug 16 09:47:24.215: //6613059/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2BC8C2, Call Id1=6613059, Call Id2=6613058
Aug 16 09:47:24.215: //6613058/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x1E93ED4, Call Id=6613058
Aug 16 09:47:24.215: //6613058/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
   Nominator=0x143C0E20, Params=0x143C0DF0, Call Id=6613058
Aug 16 09:47:24.215: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:4409315@10.30.2.254:5060 SIP/2.0
From: "Fahad AlJailan" <sip:2122889@10.30.16.10>;tag=87a6d10a-20b7-4ed4-b52f-40f63d01f911-24329862
P-Asserted-Identity: "Fahad AlJailan" <sip:2122889@10.30.16.10>
Min-SE:  1800
Remote-Party-ID: "Fahad AlJailan" <sip:2122889@10.30.16.10>;party=calling;screen=yes;privacy=off
Content-Length: 210
To: <sip:4409315@10.30.2.254>
Contact: <sip:2122889@10.30.16.10:5060;transport=tcp>
Expires: 180
Call-ID: b943b580-99411460-1868c1-a101e0a@10.30.16.10
Via: SIP/2.0/TCP 10.30.16.10:5060;branch=z9hG4bK1c2069722b6c62
CSeq: 101 INVITE
Max-Forwards: 70
v=0
s=SIP Call
t=0 0
m=audio 19976 RTP/AVP 8 101
a=ptime:20
a=fmtp:101 0-15
Aug 16 09:47:24.215: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=4409315, Called Number=4409315, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=4409315
Aug 16 09:47:24.215: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=4409315, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Aug 16 09:47:24.215: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Aug 16 09:47:24.215: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2122889, Called Number=, Voice-Interface=0x0,
Aug 16 09:47:24.219: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Aug 16 09:47:24.219: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 16 09:47:24.219: //-1/BD7F7991A3D2/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2122889, Called Number=4409315, Voice-Interface=0x0,
Aug 16 09:47:24.219: //-1/BD7F7991A3D2/DPM/dpMatchSafModulePlugin:
Aug 16 09:47:24.219: //6613060/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Aug 16 09:47:24.219: //-1/BD7F7991A3D2/CCAPI/cc_api_display_ie_subfields:
   cisco-username=2122889
   cisco-ani=2122889
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=4409315
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Aug 16 09:47:24.219: //-1/BD7F7991A3D2/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=2122889,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=4409315(TON=Unknown, NPI=Unknown),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=6613060
Aug 16 09:47:24.219: //-1/BD7F7991A3D2/CCAPI/ccCheckClipClir:
   In: Calling Number=2122889(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=2122889(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Aug 16 09:47:24.219: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 16 09:47:24.219: :cc_get_feature_vsa malloc success
Aug 16 09:47:24.219:  cc_get_feature_vsa count is 14
Aug 16 09:47:24.219: :FEATURE_VSA attributes are: feature_name:0,feature_time:362398376,feature_id:6161588
Aug 16 09:47:24.219: //6613060/BD7F7991A3D2/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=2122889(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=4409315(TON=Unknown, NPI=Unknown))
Aug 16 09:47:24.219: //6613060/BD7F7991A3D2/CCAPI/cc_process_call_setup_ind:
   Event=0x1FB5068
Aug 16 09:47:24.219: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 4409315
Aug 16 09:47:24.219: //6613060/BD7F7991A3D2/CCAPI/ccCallSetContext:
   Context=0x11DC8990
   >>>>CCAPI handed cid 6613060 with tag 5000 to app "_ManagedAppProcess_Default"
Aug 16 09:47:24.219: //6613060/BD7F7991A3D2/CCAPI/ccCallProceeding:
Aug 16 09:47:24.219: //-1/BD7F7991A3D2/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=4409315, Peer Info Type=DIALPEER_INFO_SPEECH
   dialstring=4409315, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Aug 16 09:47:24.219: //-1/BD7F7991A3D2/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Aug 16 09:47:24.219: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 16 09:47:24.219: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Calling Number=4409315, Called Number=, Voice-Interface=0x0,
Aug 16 09:47:24.227: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.196.187.22:5060;branch=z9hG4bK4BEED9330
Call-ID: BD80B1E1-819E11E7-A3D8B20C-BB639F8E@10.196.187.22
From: "Fahad AlJailan"<sip:2122889@10.30.2.254>;tag=94261098-15D8
To: <sip:4409315@10.201.20.49>
CSeq: 101 INVITE
Content-Length: 0
Aug 16 09:47:28.231: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:4409410@10.201.20.49>;tag=sbc080472sptotd-CC-28
CSeq: 101 INVITE
Contact: <sip:4409410@10.201.20.49:5060;user=phone>
Require: 100rel
RSeq: 1
Content-Length: 193
v=0
o=- 46473687 46473687 IN IP4 10.201.20.49
s=SBC call
t=0 0
m=audio 42614 RTP/AVP 8 101
a=fmtp:101 0-15
Aug 16 09:47:28.231: //6613057/BD7C6C31A3C9/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=6613057,
Aug 16 09:47:28.231: //6613056/BD7C6C31A3C9/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=6613056,
Aug 16 09:47:28.231: //6613057/BD7C6C31A3C9/CCAPI/cc_api_event_indication:
   Event=156, Call Id=6613057
Aug 16 09:47:28.231: //6613057/BD7C6C31A3C9/CCAPI/cc_api_call_alert:
Aug 16 09:47:28.231: //6613056/BD7C6C31A3C9/CCAPI/ccCallAlert:
Aug 16 09:47:28.231: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2122537, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2122537
Aug 16 09:47:28.231: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 16 09:47:28.231: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
     2: Dial-peer Tag=220
Aug 16 09:47:28.231: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Aug 16 09:47:28.231: //6613056/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x156B7320, callID1=0x64E840, callID2=0x64E841, tag=0x0)
   (confID=0x156B7320, callID1=0x64E840, gcid=BD7C6C31-819E11E7-A3CCB20C-BB639F8E, tag=0x0)
Aug 16 09:47:28.231: //6613057/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x156B7320, callID2=0x64E841, gcid=BD7C6C31-819E11E7-A3CCB20C-BB639F8E, tag=0x0)
Aug 16 09:47:28.231: //6613056/BD7C6C31A3C9/CCAPI/ccConferenceCreate:
   Conference Id=0x156B7320, Call Id1=6613056, Call Id2=6613057, Tag=0x0
Aug 16 09:47:28.231: ccConferenceCreate: ret1=0, codecMask1=2, bytes1=160, negot1=1, dtmf1=6
Aug 16 09:47:28.231: //6613056/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 16 09:47:28.231: cc_api_get_xcode_stream : 4534
Aug 16 09:47:28.231: //6613056/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C3, Source Interface=0x1D57F94, Source Call Id=6613056,
   Destination Call Id=6613057, Disposition=0x0, Tag=0x0
Aug 16 09:47:28.231: //6613057/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 16 09:47:28.231: //6613057/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C3, Source Interface=0x1D57F94, Source Call Id=6613057,
   Destination Call Id=6613056, Disposition=0x0, Tag=0x0
Aug 16 09:47:28.231: //6613056/BD7C6C31A3C9/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x2BC8C3, Destination Call Id=6613057)
Aug 16 09:47:28.231: //6613057/BD7C6C31A3C9/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2BC8C3, Destination Call Id=6613056)
Aug 16 09:47:28.231: //6613056/BD7C6C31A3C9/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2BC8C3, Call Id1=6613056, Call Id2=6613057
Sent:
PRACK sip:4409410@10.201.20.49:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.196.187.22:5060;branch=z9hG4bK4BEEDA245D
CSeq: 102 PRACK
RAck: 1 101 INVITE
Max-Forwards: 70
Content-Length: 0
Sent:
To: <sip:4409410@10.30.2.254>;tag=94262040-298
CSeq: 101 INVITE
Remote-Party-ID: <sip:4409410@10.30.2.254>;party=called;screen=no;privacy=off
Contact: <sip:4409410@10.30.2.254:5060;transport=tcp>
Supported: sdp-anat
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 2415 3055 IN IP4 10.30.2.254
s=SIP Call
t=0 0
m=audio 19082 RTP/AVP 8 101
a=fmtp:101 0-16
a=ptime:20
Aug 16 09:47:28.287: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
Aug 16 09:47:28.319: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:4409315@10.201.20.49>;tag=sbc0804u2pbup42-CC-52
CSeq: 101 INVITE
Contact: <sip:4409315@10.201.20.49:5060;user=phone>
Require: 100rel
RSeq: 1
Content-Length: 193
v=0
o=- 67915137 67915137 IN IP4 10.201.20.49
s=SBC call
t=0 0
m=audio 42620 RTP/AVP 8 101
a=fmtp:101 0-15
Aug 16 09:47:28.319: //6613061/BD7F7991A3D2/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=6613061,
Aug 16 09:47:28.319: //6613060/BD7F7991A3D2/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=6613060,
Aug 16 09:47:28.319: //6613061/BD7F7991A3D2/CCAPI/cc_api_event_indication:
   Event=156, Call Id=6613061
Aug 16 09:47:28.319: //6613061/BD7F7991A3D2/CCAPI/cc_api_call_alert:
Aug 16 09:47:28.319: //6613060/BD7F7991A3D2/CCAPI/ccCallAlert:
Aug 16 09:47:28.319: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2122889, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2122889
Aug 16 09:47:28.319: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 16 09:47:28.319: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
Aug 16 09:47:28.319: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Aug 16 09:47:28.319: //6613060/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x156B77A0, callID1=0x64E844, callID2=0x64E845, tag=0x0)
   (confID=0x156B77A0, callID1=0x64E844, gcid=BD8015B9-819E11E7-A3D5B20C-BB639F8E, tag=0x0)
Aug 16 09:47:28.319: //6613061/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x156B77A0, callID2=0x64E845, gcid=BD8015B9-819E11E7-A3D5B20C-BB639F8E, tag=0x0)
Aug 16 09:47:28.319: //6613060/BD7F7991A3D2/CCAPI/ccConferenceCreate:
   Conference Id=0x156B77A0, Call Id1=6613060, Call Id2=6613061, Tag=0x0
Aug 16 09:47:28.319: ccConferenceCreate: ret1=0, codecMask1=2, bytes1=160, negot1=1, dtmf1=6
Aug 16 09:47:28.319: //6613060/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 16 09:47:28.319: cc_api_get_xcode_stream : 4534
Aug 16 09:47:28.319: //6613060/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C4, Source Interface=0x1D57F94, Source Call Id=6613060,
   Destination Call Id=6613061, Disposition=0x0, Tag=0x0
Aug 16 09:47:28.319: //6613061/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 16 09:47:28.319: //6613061/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C4, Source Interface=0x1D57F94, Source Call Id=6613061,
   Destination Call Id=6613060, Disposition=0x0, Tag=0x0
Aug 16 09:47:28.319: //6613060/BD7F7991A3D2/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x2BC8C4, Destination Call Id=6613061)
Aug 16 09:47:28.319: //6613061/BD7F7991A3D2/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2BC8C4, Destination Call Id=6613060)
Aug 16 09:47:28.319: //6613060/BD7F7991A3D2/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2BC8C4, Call Id1=6613060, Call Id2=6613061
Sent:
PRACK sip:4409315@10.201.20.49:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.196.187.22:5060;branch=z9hG4bK4BEEDB0
From: "Fahad AlJailan" <sip:2122889@10.30.2.254>;tag=94261098-15D8
CSeq: 102 PRACK
RAck: 1 101 INVITE
Max-Forwards: 70
Content-Length: 0
Sent:
To: <sip:4409315@10.30.2.254>;tag=94262098-1471
CSeq: 101 INVITE
Remote-Party-ID: <sip:4409315@10.30.2.254>;party=called;screen=no;privacy=off
Contact: <sip:4409315@10.30.2.254:5060;transport=tcp>
Supported: sdp-anat
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 1333 8465 IN IP4 10.30.2.254
s=SIP Call
t=0 0
m=audio 16386 RTP/AVP 8 101
a=fmtp:101 0-16
a=ptime:20
Aug 16 09:47:28.335: //6613058/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x18E00, Params=0x143C11C8, Call Id=6613058
Aug 16 09:47:28.335: //6613058/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Aug 16 09:47:28.335: //6613059/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x1000000, Params=0x143C11D8, Call Id=6613059
Aug 16 09:47:28.335: //6613058/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
Aug 16 09:47:28.335: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Aug 16 09:47:28.335: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 16 09:47:28.335: :cc_get_feature_vsa malloc success
Aug 16 09:47:28.335:  cc_get_feature_vsa count is 16
Aug 16 09:47:28.335: :FEATURE_VSA attributes are: feature_name:0,feature_time:362411592,feature_id:6161590
Aug 16 09:47:28.335: //6613062/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Aug 16 09:47:28.335: //6613062/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x11A6E520
Aug 16 09:47:28.339: //6613062/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Connection Handle=0
Aug 16 09:47:28.339: //6613059/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x143C0DF8, callID1=0x64E843, callID2=0x64E846, tag=0x0)
Aug 16 09:47:28.339: //6613062/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x143C0DF8, callID2=0x64E846, gcid=0-0-0-0, tag=0x0)
   Conference Id=0x143C0DF8, Call Id1=6613059, Call Id2=6613062, Tag=0x0
Aug 16 09:47:28.339: //6613062/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C5, Source Interface=0x1E93ED4, Source Call Id=6613062,
   Call Entry(Conference Id=0x2BC8C5, Destination Call Id=6613062)
   Call Entry(Conference Id=0x2BC8C5, Destination Call Id=6613059)
Aug 16 09:47:28.339: //6613059/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C5, Source Interface=0x1ADD53C, Source Call Id=6613059,
   Destination Call Id=6613062, Disposition=0x0, Tag=0x0
Aug 16 09:47:28.339: //6613059/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
Aug 16 09:47:28.339: //6613062/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x0, Params=0x143C08C0, Call Id=6613062
Aug 16 09:47:28.339: //6613059/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2BC8C5, Call Id1=6613059, Call Id2=6613062
Aug 16 09:47:28.339: //6613062/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x1E93ED4, Call Id=6613062
Aug 16 09:47:28.339: //6613062/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
   Nominator=0x143C0E20, Params=0x143C0DF0, Call Id=6613062
Aug 16 09:47:28.355: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
Aug 16 09:47:28.379: //6613062/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x18E00, Params=0x143C11C8, Call Id=6613062
Aug 16 09:47:28.379: //6613062/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Aug 16 09:47:28.379: //6613062/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
Aug 16 09:47:38.235: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 0
Aug 16 09:47:38.235: //6613061/BD7F7991A3D2/CCAPI/cc_api_call_connected:
   Interface=0x1D57F94, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
Aug 16 09:47:38.235: //6613060/BD7F7991A3D2/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
Aug 16 09:47:38.235: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 16 09:47:38.235: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 16 09:47:38.235: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
Aug 16 09:47:38.235: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Call Entry(Connected=TRUE, Responsed=TRUE)
Aug 16 09:47:38.239: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Aug 16 09:47:38.239: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 16 09:47:38.239: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Content-Length: 244
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
Sent:
Via: SIP/2.0/UDP 10.196.187.22:5060;branch=z9hG4bK4BEEDC79D
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Aug 16 09:47:38.243: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:4409315@10.30.2.254:5060;transport=tcp SIP/2.0
Content-Length: 0
Via: SIP/2.0/TCP 10.30.16.10:5060;branch=z9hG4bK1c206a6027ad3d
CSeq: 101 ACK
Max-Forwards: 70
Aug 16 09:47:38.275: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:2122889@10.196.187.22:5060 SIP/2.0
Via: SIP/2.0/UDP 10.201.20.49:5060;branch=z9hG4bKbpob2ku24akhh42puacosa4sbT04230
From: <sip:4409315@10.201.20.49>;tag=sbc0804u2pbup42-CC-52
To: "Fahad AlJailan"<sip:2122889@10.30.2.254>;tag=94261098-15D8
CSeq: 1 OPTIONS
Accept: application/sdp
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
To: "Fahad AlJailan" <sip:2122889@10.30.2.254>;tag=94261098-15D8
Date: Wed, 16 Aug 2017 09:47:38 GMT
CSeq: 1 OPTIONS
Supported: 100rel,resource-priority,replaces,sdp-anat
Content-Length: 273
v=0
o=CiscoSystemsSIP-GW-UserAgent 4976 648 IN IP4 10.196.187.22
s=SIP Call
t=0 0
m=audio 18270 RTP/AVP 8 101 19
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Aug 16 09:47:48.747: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Content-Length: 0
Aug 16 09:47:48.747: //6613057/BD7C6C31A3C9/CCAPI/cc_api_call_connected:
   Connection Handle=0
Aug 16 09:47:48.747: //6613056/BD7C6C31A3C9/CCAPI/ccCallConnect:
Aug 16 09:47:48.747: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 16 09:47:48.747: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 16 09:47:48.747: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
Aug 16 09:47:48.747: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Content-Length: 244
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
Sent:
Via: SIP/2.0/UDP 10.196.187.22:5060;branch=z9hG4bK4BEEDD2128
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Aug 16 09:47:48.751: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:4409410@10.30.2.254:5060;transport=tcp SIP/2.0
Content-Length: 0
Via: SIP/2.0/TCP 10.30.16.10:5060;branch=z9hG4bK1c206b45eeaf22
CSeq: 101 ACK
Max-Forwards: 70
Aug 16 09:47:48.787: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:2122537@10.196.187.22:5060 SIP/2.0
Via: SIP/2.0/UDP 10.201.20.49:5060;branch=z9hG4bKkpbcc4kaufuaoucactaepsuoaT04809
From: <sip:4409410@10.201.20.49>;tag=sbc080472sptotd-CC-28
To: "Ali Al-Qahtani Accountant"<sip:2122537@10.30.2.254>;tag=94261084-25E0
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
To: "Ali Al-Qahtani Accountant" <sip:2122537@10.30.2.254>;tag=94261084-25E0
Date: Wed, 16 Aug 2017 09:47:48 GMT
CSeq: 1 OPTIONS
Content-Length: 274
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Aug 16 09:48:04.394: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.196.187.22:5060 SIP/2.0
Via: SIP/2.0/UDP 10.201.20.49:5060;branch=z9hG4bKoukduc72kobtcuttadstd2daeT31073
Call-ID: isbcck27effshhh2scb7kcdse4tos7k7s2su@SoftX3000
To: <sip:10.196.187.22>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Aug 16 09:48:04.394: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Result=NO_MATCH(-1) After All Match Rules Attempt
Aug 16 09:48:04.394: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Aug 16 09:48:04.394: //-1/D57262E2A3DA/DPM/dpAssociateIncomingPeerCore:
Aug 16 09:48:04.394: //-1/D57262E2A3DA/DPM/dpMatchSafModulePlugin:
Sent:
SIP/2.0 200 OK
To: <sip:10.196.187.22>;tag=9426AD84-1857
Date: Wed, 16 Aug 2017 09:48:04 GMT
CSeq: 1 OPTIONS
Content-Length: 170
v=0
o=CiscoSystemsSIP-GW-UserAgent 1660 9985 IN IP4 10.196.187.22
s=SIP Call
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
Aug 16 09:48:18.002: //6613058/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x143C1178, Call Id=6613058
Aug 16 09:48:18.002: //6613058/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Aug 16 09:48:18.002: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:4409315@10.30.2.254:5060;transport=tcp SIP/2.0
Content-Length: 0
Via: SIP/2.0/TCP 10.30.16.10:5060;branch=z9hG4bK1c206c43512241
CSeq: 102 BYE
Max-Forwards: 70
Aug 16 09:48:18.002: //6613061/BD7F7991A3D2/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=6613061
Aug 16 09:48:18.002: //6613060/BD7F7991A3D2/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x1D57F94, Call Id=6613060
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Aug 16 09:48:18.002: //6613060/BD7F7991A3D2/CCAPI/ccConferenceDestroy:
   Conference Id=0x2BC8C4, Tag=0x0
Aug 16 09:48:18.002: //6613060/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Aug 16 09:48:18.002: //6613061/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Aug 16 09:48:18.002: //6613060/BD7F7991A3D2/CCAPI/cc_generic_bridge_done:
Aug 16 09:48:18.002: //6613059/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x1000000, Params=0x143C11E0, Call Id=6613059
Aug 16 09:48:18.002: //6613060/BD7F7991A3D2/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Aug 16 09:48:18.002: //6613061/BD7F7991A3D2/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Aug 16 09:48:18.002: //6613060/BD7F7991A3D2/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x1D57F94, Tag=0x0, Call Id=6613060,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Aug 16 09:48:18.002: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 16 09:48:18.002: :cc_free_feature_vsa freeing 1599C2A0
Aug 16 09:48:18.002:  vsacount in free is 15
Aug 16 09:48:18.006: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 16 Aug 2017 09:48:18 GMT
CSeq: 102 BYE
Content-Length: 0
Aug 16 09:48:18.006: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Aug 16 09:48:18.006: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Sent:
BYE sip:4409315@10.201.20.49:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.196.187.22:5060;branch=z9hG4bK4BEEDE18CF
Max-Forwards: 70
Timestamp: 1502876898
CSeq: 103 BYE
Content-Length: 0
Aug 16 09:48:18.006: //6613058/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
Aug 16 09:48:18.006: //6613059/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy:
   Conference Id=0x2BC8C2, Tag=0x0
Aug 16 09:48:18.006: //6613059/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Aug 16 09:48:18.006: //6613058/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Aug 16 09:48:18.006: //6613059/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
Aug 16 09:48:18.006: //6613062/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x143C1178, Call Id=6613062
Aug 16 09:48:18.006: //6613062/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Aug 16 09:48:18.006: //6613058/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
   Cause Value=0, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=0, Call Entry(Responsed=TRUE, Cause Value=0)
Aug 16 09:48:18.006: //6613062/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
   Conference Id=0x2BC8C5, Tag=0x0
Aug 16 09:48:18.006: //6613062/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Aug 16 09:48:18.006: //6613058/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x1E93ED4, Tag=0x0, Call Id=6613058,
   Call Entry(Disconnect Cause=0, Voice Class Cause Code=0, Retry Count=0)
Aug 16 09:48:18.006: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 16 09:48:18.006: :cc_free_feature_vsa freeing 1599DEA0
Aug 16 09:48:18.006:  vsacount in free is 14
Aug 16 09:48:18.006: //6613062/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
Aug 16 09:48:18.006: //6613062/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x1E93ED4, Tag=0x0, Call Id=6613062,
Aug 16 09:48:18.006: :cc_free_feature_vsa freeing 1599F640
Aug 16 09:48:18.006:  vsacount in free is 13
Aug 16 09:48:18.006: //6613059/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
Aug 16 09:48:18.006: //6613059/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x1ADD53C, Tag=0x0, Call Id=6613059,
Aug 16 09:48:18.006: :cc_free_feature_vsa freeing 1599EE60
Aug 16 09:48:18.006:  vsacount in free is 12
Aug 16 09:48:18.054: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 BYE
Content-Length: 0
Aug 16 09:48:18.054: //6613061/BD7F7991A3D2/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x1D57F94, Tag=0x0, Call Id=6613061,
Aug 16 09:48:18.054: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 16 09:48:18.054: :cc_free_feature_vsa freeing 1599F800
Aug 16 09:48:18.054:  vsacount in free is 11
Aug 16 09:48:18.058: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=[24678]......, Called Number=, Voice-Interface=0x0,
Aug 16 09:48:18.058: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 16 09:48:30.566: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0112122781@10.196.187.22;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.201.20.49:5060;branch=z9hG4bK27ueabdefpeuf2aetsub2dapbT32438
Call-ID: isbceuddskukpessfat77sek2a7dkftoeph7@SoftX3000
From: <sip:112214222@10.196.187.22;user=phone>;tag=sbc0802opua77d4-CC-22
To: <sip:0112122781@10.196.187.22;user=phone>
CSeq: 1 INVITE
Max-Forwards: 29
Contact: <sip:112214222@10.201.20.49:5060;user=phone>
User-Agent: Huawei SoftX3000 V300R010
Supported: 100rel
Content-Length: 262
v=0
o=- 65678108 65678108 IN IP4 10.201.20.49
s=SBC call
t=0 0
m=audio 43222 RTP/AVP 8 0 18 97
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:97 telephone-event/8000
a=fmtp:97 0-15
a=fmtp:18 annexb=yes
Aug 16 09:48:30.566: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=0112122781, Called Number=0112122781, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=0112122781
Aug 16 09:48:30.566: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=0112122781, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Aug 16 09:48:30.566: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2200
Aug 16 09:48:30.566: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=112214222, Called Number=, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_ANSWER; Incoming Dial-peer=3
Aug 16 09:48:30.566: //-1/E50BDED9A3DB/DPM/dpAssociateIncomingPeerCore:
   Calling Number=112214222, Called Number=0112122781, Voice-Interface=0x0,
Aug 16 09:48:30.566: //-1/E50BDED9A3DB/DPM/dpMatchSafModulePlugin:
Aug 16 09:48:30.566: //6613064/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Aug 16 09:48:30.566: //-1/E50BDED9A3DB/CCAPI/cc_api_display_ie_subfields:
   cisco-username=112214222
   cisco-ani=112214222
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=0112122781
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Aug 16 09:48:30.566: //-1/E50BDED9A3DB/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=112214222,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=0112122781(TON=Unknown, NPI=Unknown),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=6613064
Aug 16 09:48:30.566: //-1/E50BDED9A3DB/CCAPI/ccCheckClipClir:
   In: Calling Number=112214222(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=112214222(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Aug 16 09:48:30.566: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 16 09:48:30.566: :cc_get_feature_vsa malloc success
Aug 16 09:48:30.566:  cc_get_feature_vsa count is 12
Aug 16 09:48:30.566: :FEATURE_VSA attributes are: feature_name:0,feature_time:362412040,feature_id:6161591
Aug 16 09:48:30.566: //6613064/E50BDED9A3DB/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=112214222(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=0112122781(TON=Unknown, NPI=Unknown))
Aug 16 09:48:30.566: //6613064/E50BDED9A3DB/CCAPI/cc_process_call_setup_ind:
   Event=0x1FB6E80
Aug 16 09:48:30.566: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 0112122781
Aug 16 09:48:30.566: //6613064/E50BDED9A3DB/CCAPI/ccCallSetContext:
   Context=0x157C0FD8
   >>>>CCAPI handed cid 6613064 with tag 5000 to app "_ManagedAppProcess_Default"
Aug 16 09:48:30.566: //6613064/E50BDED9A3DB/CCAPI/ccCallProceeding:
Aug 16 09:48:30.566: //-1/E50BDED9A3DB/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2122781, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2122781
   dialstring=2122781, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Aug 16 09:48:30.566: //-1/E50BDED9A3DB/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Calling Number=2122781, Called Number=2122781, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
   Calling Number=2122781, Called Number=, Voice-Interface=0x0,
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
Aug 16 09:48:30.570: //-1/E50BDED9A3DB/DPM/dpMatchPeersCore:
Aug 16 09:48:30.570: //-1/E50BDED9A3DB/DPM/dpMatchSafModulePlugin:
   dialstring=2122781, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Aug 16 09:48:30.570: //-1/E50BDED9A3DB/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=10
Aug 16 09:48:30.570: //6613064/E50BDED9A3DB/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=10, Params=0x11E36058, Progress Indication=NULL(0)
Aug 16 09:48:30.570: //6613064/E50BDED9A3DB/CCAPI/ccCheckClipClir:
   Destination Pattern=212...., Called Number=2781, Digit Strip=FALSE
   Called Number=2781(TON=Unknown, NPI=Unknown),
   Account Number=112214222, Final Destination Flag=TRUE,
   Guid=E50BDED9-819E-11E7-A3DB-B20CBB639F8E, Outgoing Dial-peer=10
Aug 16 09:48:30.570: //6613064/E50BDED9A3DB/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=112214222
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=2781
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Aug 16 09:48:30.570: //6613064/E50BDED9A3DB/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=112214222,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=2781(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=10, Call Count On=FALSE,
Aug 16 09:48:30.570: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 16 09:48:30.570: :cc_get_feature_vsa malloc success
Aug 16 09:48:30.570:  cc_get_feature_vsa count is 13
Aug 16 09:48:30.570: :FEATURE_VSA attributes are: feature_name:0,feature_time:362409576,feature_id:6161592
Aug 16 09:48:30.570: //6613065/E50BDED9A3DB/CCAPI/ccIFCallSetupRequestPrivate:
Aug 16 09:48:30.570: //6613065/E50BDED9A3DB/CCAPI/ccCallSetContext:
   Context=0x11E36008
Aug 16 09:48:30.570: //6613064/E50BDED9A3DB/CCAPI/ccSaveDialpeerTag:
Aug 16 09:48:30.570: //6613065/E50BDED9A3DB/CCAPI/cc_api_call_proceeding:
Aug 16 09:48:30.570: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 16 Aug 2017 09:48:30 GMT
CSeq: 1 INVITE
Content-Length: 0
Sent:
INVITE sip:2781@10.30.16.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.30.2.254:5060;branch=z9hG4bK4BEEDFD61
Remote-Party-ID: <sip:112214222@10.30.2.254>;party=calling;screen=no;privacy=off
From: <sip:112214222@10.30.2.254>;tag=942713C4-154B
To: <sip:2781@10.30.16.10>
Call-ID: E50C7B01-819E11E7-A3E1B20C-BB639F8E@10.30.2.254
Min-SE:  1800
Cisco-Guid: 3842760409-2174620135-2749084172-3143868302
CSeq: 101 INVITE
Timestamp: 1502876910
Contact: <sip:112214222@10.30.2.254:5060>
Call-Info: <sip:10.30.2.254:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Max-Forwards: 28
Content-Length: 188
v=0
o=CiscoSystemsSIP-GW-UserAgent 1780 5037 IN IP4 10.30.2.254
s=SIP Call
t=0 0
m=audio 17070 RTP/AVP 8
a=ptime:20
Received:
SIP/2.0 100 Trying
Date: Wed, 16 Aug 2017 09:47:14 GMT
Content-Length: 0
CSeq: 101 INVITE
Aug 16 09:48:30.578: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
P-Asserted-Identity: "Missra Aldosri" <sip:2781@10.30.16.10>
Remote-Party-ID: "Missra Aldosri" <sip:2781@10.30.16.10>;party=called;screen=yes;privacy=off
Content-Length: 0
To: <sip:2781@10.30.16.10>;tag=87a6d10a-20b7-4ed4-b52f-40f63d01f911-24329881
Contact: <sip:2781@10.30.16.10:5060>
CSeq: 101 INVITE
Aug 16 09:48:30.578: //6613065/E50BDED9A3DB/CCAPI/cc_api_call_alert:
   Interface=0x1D57F94, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Aug 16 09:48:30.578: //6613064/E50BDED9A3DB/CCAPI/ccCallAlert:
Aug 16 09:48:30.578: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=112214222, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=112214222
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Aug 16 09:48:30.578: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 16 09:48:30.578: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
Aug 16 09:48:30.578: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2781, Called Number=, Voice-Interface=0x0,
Sent:
SIP/2.0 180 Ringing
To: <sip:0112122781@10.196.187.22;user=phone>;tag=942713CC-260
CSeq: 1 INVITE
Require: 100rel
RSeq: 1836
Remote-Party-ID: "Missra Aldosri" <sip:2781@10.196.187.22>;party=called;screen=no;privacy=off
Contact: <sip:2781@10.196.187.22:5060>
Record-Route: <sip:10.201.20.49:5060;transport=udp;lr>
Content-Length: 0
Aug 16 09:48:30.706: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:2781@10.196.187.22:5060 SIP/2.0
Via: SIP/2.0/UDP 10.201.20.49:5060;branch=z9hG4bKtatcuf74ouf7cfdddpetau2stT32440
CSeq: 2 PRACK
Max-Forwards: 70
RAck: 1836 1 INVITE
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 2 PRACK
Content-Length: 0
Aug 16 09:48:33.734: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Aug 16 09:48:33.734: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 16 09:48:33.734: :cc_get_feature_vsa malloc success
Aug 16 09:48:33.734:  cc_get_feature_vsa count is 14
Aug 16 09:48:33.734: :FEATURE_VSA attributes are: feature_name:0,feature_time:362411592,feature_id:6161593
Aug 16 09:48:33.734: //6613066/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Aug 16 09:48:33.734: //6613066/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x11A6DB80
Aug 16 09:48:33.734:  cc_get_feature_vsa count is 15
Aug 16 09:48:33.734: :FEATURE_VSA attributes are: feature_name:0,feature_time:362405544,feature_id:6161594
Aug 16 09:48:33.734: //6613067/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Connection Handle=0
Aug 16 09:48:33.734: //6613067/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Aug 16 09:48:33.734: //6613067/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x11A6D880
Aug 16 09:48:33.734: //6613066/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Connection Handle=0
Aug 16 09:48:33.738: //6613067/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x143C0DF8, callID1=0x64E84B, callID2=0x64E84A, tag=0x0)
   (confID=0x143C0DF8, callID1=0x64E84B, gcid=0-0-0-0, tag=0x0)
Aug 16 09:48:33.738: //6613066/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x143C0DF8, callID2=0x64E84A, gcid=0-0-0-0, tag=0x0)
   Conference Id=0x143C0DF8, Call Id1=6613067, Call Id2=6613066, Tag=0x0
Aug 16 09:48:33.738: //6613067/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C6, Source Interface=0x1ADD53C, Source Call Id=6613067,
   Destination Call Id=6613066, Disposition=0x0, Tag=0x0
Aug 16 09:48:33.738: //6613066/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C6, Source Interface=0x1E93ED4, Source Call Id=6613066,
   Destination Call Id=6613067, Disposition=0x0, Tag=0x0
Aug 16 09:48:33.738: //6613067/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x2BC8C6, Destination Call Id=6613066)
   Call Entry(Conference Id=0x2BC8C6, Destination Call Id=6613067)
Aug 16 09:48:33.738: //6613066/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x0, Params=0x143C08C0, Call Id=6613066
   Nominator=0x18E00, Params=0x143C08A0, Call Id=6613066
Aug 16 09:48:33.738: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Aug 16 09:48:33.738: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 16 09:48:33.738: :cc_get_feature_vsa malloc success
Aug 16 09:48:33.738:  cc_get_feature_vsa count is 16
Aug 16 09:48:33.738: :FEATURE_VSA attributes are: feature_name:0,feature_time:362398376,feature_id:6161595
Aug 16 09:48:33.738: //6613068/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Aug 16 09:48:33.738: //6613068/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x11A6DEE0
Aug 16 09:48:33.738: //6613067/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2BC8C6, Call Id1=6613067, Call Id2=6613066
Aug 16 09:48:33.738: //6613066/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x1E93ED4, Call Id=6613066
Aug 16 09:48:33.738: //6613068/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Connection Handle=0
Aug 16 09:48:33.738: //6613066/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
   Nominator=0x143C0E20, Params=0x143C0DF0, Call Id=6613066
   (confID=0x143C0DF8, callID1=0x64E84B, callID2=0x64E84C, tag=0x0)
Aug 16 09:48:33.738: //6613068/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x143C0DF8, callID2=0x64E84C, gcid=0-0-0-0, tag=0x0)
   Conference Id=0x143C0DF8, Call Id1=6613067, Call Id2=6613068, Tag=0x0
Aug 16 09:48:33.738: //6613068/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C7, Source Interface=0x1E93ED4, Source Call Id=6613068,
   Call Entry(Conference Id=0x2BC8C7, Destination Call Id=6613068)
   Call Entry(Conference Id=0x2BC8C7, Destination Call Id=6613067)
   Conference Id=0x2BC8C7, Source Interface=0x1ADD53C, Source Call Id=6613067,
   Destination Call Id=6613068, Disposition=0x0, Tag=0x0
Aug 16 09:48:33.738: //6613068/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x0, Params=0x143C08C0, Call Id=6613068
   Conference Id=0x2BC8C7, Call Id1=6613067, Call Id2=6613068
Aug 16 09:48:33.738: //6613068/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x1E93ED4, Call Id=6613068
Aug 16 09:48:33.742: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Allow-Events: presence
Supported: replaces
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Content-Length: 154
Require:  timer
Content-Type: application/sdp
CSeq: 101 INVITE
Session-Expires:  1800;refresher=uas
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 10.30.16.10
s=SIP Call
t=0 0
m=audio 18526 RTP/AVP 8
a=rtpmap:8 PCMA/8000
a=ptime:20
Aug 16 09:48:33.742: //6613065/E50BDED9A3DB/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=6613065,
Aug 16 09:48:33.742: //6613064/E50BDED9A3DB/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=6613065, Source Call Id=6613064,
Aug 16 09:48:33.742: //6613065/E50BDED9A3DB/CCAPI/cc_api_event_indication:
   Event=156, Call Id=6613065
Aug 16 09:48:33.742: //6613065/E50BDED9A3DB/CCAPI/cc_api_call_connected:
   Interface=0x1D57F94, Data Bitmask=0x80000001, Progress Indication=NULL(0),
   Connection Handle=0
Aug 16 09:48:33.742: //6613068/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
   Nominator=0x143C0E20, Params=0x143C0DF0, Call Id=6613068
Aug 16 09:48:33.742: //6613064/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x1596EB44, callID1=0x64E848, callID2=0x64E849, tag=0x0)
   (confID=0x1596EB44, callID1=0x64E848, gcid=E50BDED9-819E11E7-A3DEB20C-BB639F8E, tag=0x0)
Aug 16 09:48:33.742: //6613065/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x1596EB44, callID2=0x64E849, gcid=E50BDED9-819E11E7-A3DEB20C-BB639F8E, tag=0x0)
Aug 16 09:48:33.742: //6613064/E50BDED9A3DB/CCAPI/ccConferenceCreate:
   Conference Id=0x1596EB44, Call Id1=6613064, Call Id2=6613065, Tag=0x0
Aug 16 09:48:33.742: ccConferenceCreate: ret1=0, codecMask1=2, bytes1=160, negot1=1, dtmf1=6
                    ret2=0, codecMask2=2, bytes2=160, negot2=1, dtmf2=8,
Aug 16 09:48:33.742: //6613064/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 16 09:48:33.742: cc_api_get_xcode_stream : 4534
Aug 16 09:48:33.742: //6613064/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C8, Source Interface=0x1D57F94, Source Call Id=6613064,
   Destination Call Id=6613065, Disposition=0x0, Tag=0x0
Aug 16 09:48:33.742: //6613065/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 16 09:48:33.742: //6613065/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2BC8C8, Source Interface=0x1D57F94, Source Call Id=6613065,
   Destination Call Id=6613064, Disposition=0x0, Tag=0x0
Aug 16 09:48:33.742: //6613064/E50BDED9A3DB/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x2BC8C8, Destination Call Id=6613065)
Aug 16 09:48:33.742: //6613065/E50BDED9A3DB/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2BC8C8, Destination Call Id=6613064)
Aug 16 09:48:33.742: //6613064/E50BDED9A3DB/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2BC8C8, Call Id1=6613064, Call Id2=6613065
Sent:
ACK sip:2781@10.30.16.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.30.2.254:5060;branch=z9hG4bK4BEEE02506
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Aug 16 09:48:33.742: //6613064/E50BDED9A3DB/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x80000001
Aug 16 09:48:33.742: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Aug 16 09:48:33.742: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 16 09:48:33.742: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
Aug 16 09:48:33.742: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ANSWER; Incoming Dial-peer=2
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Aug 16 09:48:33.746: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Contact: <sip:0112122781@10.196.187.22:5060>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 194
v=0
o=CiscoSystemsSIP-GW-UserAgent 3830 2529 IN IP4 10.196.187.22
s=SIP Call
t=0 0
m=audio 29938 RTP/AVP 8
a=ptime:20
Aug 16 09:48:33.826: //6613068/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x18E00, Params=0x143C11C8, Call Id=6613068
Aug 16 09:48:33.826: //6613068/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Aug 16 09:48:33.826: //6613068/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
Aug 16 09:48:33.842: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Aug 16 09:48:33.842: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 16 09:48:33.842: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 194
v=0
s=SIP Call
t=0 0
a=ptime:20
Aug 16 09:48:34.042: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Aug 16 09:48:34.042: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 16 09:48:34.042: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 194
v=0
s=SIP Call
t=0 0
a=ptime:20
Aug 16 09:48:34.082: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0112122781@10.196.187.22:5060 SIP/2.0
Via: SIP/2.0/UDP 10.201.20.49:5060;branch=z9hG4bK4ktot4thubudfohuoe47u2et2T32611
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
Aug 16 09:48:34.086: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:0112122781@10.196.187.22:5060 SIP/2.0
Via: SIP/2.0/UDP 10.201.20.49:5060;branch=z9hG4bKohbed7hkopaue4f2ee7oaaeu2T32612
CSeq: 3 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
Date: Wed, 16 Aug 2017 09:48:34 GMT
CSeq: 3 OPTIONS
Content-Length: 194
v=0
s=SIP Call
t=0 0
a=ptime:20
Aug 16 09:48:57.134: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 504 Server Time-out
Via: SIP/2.0/UDP 10.196.187.22:5060;branch=z9hG4bK4BEED61F10
Call-ID: A9164F28-819E11E7-A3C8B20C-BB639F8E@10.196.187.22
From: "Voice Eng Mohsin Majeed"<sip:2122902@10.30.2.254>;tag=94258ACC-DC6
To: <sip:4945316@10.201.20.49>;tag=sbc0807ueaheubc-CC-38
CSeq: 101 INVITE
Reason: Q.850;cause=102;text="recovery of timer expiry"
Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR"
Content-Length: 0
Aug 16 09:48:57.134: //6613055/A915B300A3C2/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x1D57F94, Call Id=6613055
   Call Entry(Responsed=TRUE, Cause Value=102, Retry Count=0)
Aug 16 09:48:57.134: //6613054/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Aug 16 09:48:57.134: //6613055/A915B300A3C2/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=6613055
Aug 16 09:48:57.134: //6613054/A915B300A3C2/CCAPI/ccConferenceDestroy:
   Conference Id=0x2BC8C1, Tag=0x0
Aug 16 09:48:57.134: //6613054/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Aug 16 09:48:57.134: //6613055/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Aug 16 09:48:57.134: //6613054/A915B300A3C2/CCAPI/cc_generic_bridge_done:
Sent:
ACK sip:4945316@10.201.20.49:5060 SIP/2.0
From: "Voice Eng Mohsin Majeed" <sip:2122902@10.30.2.254>;tag=94258ACC-DC6
Date: Wed, 16 Aug 2017 09:46:49 GMT
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: telephone-event
Content-Length: 0
Aug 16 09:48:57.134: //6613055/A915B300A3C2/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=102)
   Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
Aug 16 09:48:57.134: //6613055/A915B300A3C2/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x1D57F94, Tag=0x0, Call Id=6613055,
   Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
Aug 16 09:48:57.138: //6613055/A915B300A3C2/CCAPI/cc_api_call_disconnect_done:
Aug 16 09:48:57.138: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 16 09:48:57.138: :cc_free_feature_vsa freeing 1599BE40
Aug 16 09:48:57.138:  vsacount in free is 15
Aug 16 09:48:57.138: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Aug 16 09:48:57.138: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Aug 16 09:48:57.138: //6613054/A915B300A3C2/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Aug 16 09:48:57.138: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 408 Request Timeout
Via: SIP/2.0/TCP 10.30.16.10:5060;branch=z9hG4bK1c20673ef38c19
From: "Voice Eng Mohsin Majeed" <sip:2122902@10.30.16.10>;tag=87a6d10a-20b7-4ed4-b52f-40f63d01f911-24329849
Call-ID: a4ffb880-9941143e-1868bf-a101e0a@10.30.16.10
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Received:
ACK sip:4945316@10.30.2.254:5060 SIP/2.0
Date: Wed, 16 Aug 2017 09:45:34 GMT
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
Aug 16 09:48:57.138: //6613054/A915B300A3C2/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x1D57F94, Tag=0x0, Call Id=6613054,
Aug 16 09:48:57.138: :cc_free_feature_vsa freeing 1599F020
Aug 16 09:48:57.138:  vsacount in free is 14
RIY.EX17.DC.DR.01#
RIY.EX17.DC.DR.01#
RIY.EX17.DC.DR.01#
RIY.EX17.DC.DR.01#u all
All possible debugging has been turned off
RIY.EX17.DC.DR.01#ter no mon
RIY.EX17.DC.DR.01#
is your issue has resolved
