03-22-2008 10:23 PM - edited 03-15-2019 09:35 AM
I am trying to trunk an asterisk and CCM 5.1 to each other. Inbound from the asterisk works, however outbound to the from CCM to asterisk does not :(. I was trying a normal route pattern and now I see SIP Route Pattern. WHen I try to add a SIP Route Pattern I get Add Failed -1. Anyone know why this happening and I can't add a SIP Route Pattern? Also does anyone know if its necessary to use a SIP route pattern or a will normal route pattern work like it did in 4.2
this is a 5.1.1
Chad
03-27-2008 12:34 PM
TRY - CSCsm61286
Symptom:
call from an Cisco IP Phone to certain carrier fails when after ringing the PSTN cell phone ((e.g T Mobile) , call is forwarded to Voicemail.
OR
calls from an Cisco IP Phone to certain PSTN carrier fails when after ringing the PSTN home phone , call is forwarded to Voicemail. (e.g Home phone with personal Answering machine )
caller gets disconnected and caller can not leave VM.
Conditions:
"SIP Rel1XX Enabled" service parameter on the CallManager is set to True.
SIP trunk in G729 Device Pool
Workaround:
none.
Further Problem Description:
CUCM 5.x , 6.x does not support 181 SIP message, This is an enhancement request.
03-27-2008 01:02 PM
Hi Chad,
A few months ago, I configured a SIP trunk and normal route-patterns between a CCM 4.1 and an Asterisk Server.
At the beginning my calls didn't work. I detected that the SIP Trunk Outgoing Transport Type in CCM was using TCP. I changed to UDP and calls start working.
Also, notice the CSS used in Inbound Calls in the SIP trunk.
-- adrián.
05-06-2008 08:00 AM
hi
did you ever get this working?
I get the same error and can;t can incoming or outgoing working on asterisk (it did work with CM4 using)
allow=ulaw&alaw
canreinvite=yes
context=from-pstn
disallow=all
dtmfmode=rfc2833
host=
insecure=port,invite
nat=no
port=5060
qualify=no
type=friend
