10-24-2014 11:18 AM - edited 03-17-2019 12:40 AM
Does anyone have a CM SIP trunk configuration example for getting this to work with our without a router? My customer wants to transfer a call from UCCX to a route pattern over a SIP trunk to this IVR. The IVR will handle the caller input for an AD password reset application. I have documents on configuring dial peers in a router to do this. However I cannot seem to find anything on configuring the Call Manager portion.
The CUCM - 7.1.3
UCCX - 7.X
Any assistance is greatly appreciated.
Solved! Go to Solution.
10-24-2014 01:48 PM
In all CUCM all you need is under device -> trunk -> add new -> SIP trunk, then you might need to tweak the SIP profiles and SIP trunk config depending on your needs.
10-24-2014 01:48 PM
10-27-2014 07:14 AM
I am trying to spend less time guessing what SIP settings this product needs. This is why I asked specifically for a configuration guide for this Voxeo Prophecy IVR product.
10-27-2014 07:16 AM
This is not the correct answer btw.
