SPA112 locked out of admin
faruk.master
Hello Support,
We recently installed some SPA112 2 port adapters and the default password was left it. Since then someone has hacked the unit and changed the admin password and also programmed a password for the IVR. I believe they may have changed the setting for the reset button so it won't do a factory default if holding the reset button in for 20 seconds.
Is there a way to recover the unit back to factory default.
Jaime Valencia
SPA endpoints are supported in the SMB area of CSC, might want to move your thread over there.
java
if this helps, please rate
